How often do you drain your racecar fuel cell (gas only)? #1872377
07/17/15 04:30 PM
07/17/15 04:30 PM
Dallas, TX
440Brian Offline OP
440Brian  Offline OP
Dallas, TX
I've always left the fuel in the cell during and between races (LODRS mostly now). I just fill it before the run. I noticed the fuel drum says not to store it in the vehicle. I wonder if the fuel is changing due to venting. Is there any consistency gains by draining or any practical way to seal the cell?
Re: How often do you drain your racecar fuel cell (gas only)? [Re: 440Brian] #1872380
07/17/15 04:36 PM
07/17/15 04:36 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
After every race we drain ours. The vent will allow air to get to the fuel. Oxygen is the enemy of race fuel. When we race over an weekend like an LODRS deal we actually plug the vent with a rubber cap to keep air out. But it is drained after every weekend and always stored in metal cans as many plastic jugs are pourous enough to allow light or oxygen in. Sunlight can also have an affect on race fuel.
Re: How often do you drain your racecar fuel cell (gas only)? [Re: Al_Alguire] #1872393
07/17/15 05:06 PM
07/17/15 05:06 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
iagree
Design your fuel system so it can be drained out on Sunday afternoon, hopefully late Sun night in the pits which would mean you went into the late rounds or even won it!
Re: How often do you drain your racecar fuel cell (gas only)? [Re: 440Brian] #1872402
07/17/15 05:20 PM
07/17/15 05:20 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I designed mine with a drain but never drain it. May not be the thing to do but even after the winter I've run the car on it. Performance has always been what the weather says it should be. The inside of the carbs look like new. Fuel is Renegade 114.
Doug
Re: How often do you drain your racecar fuel cell (gas only)? [Re: Al_Alguire] #1872404
07/17/15 05:22 PM
07/17/15 05:22 PM
Dallas, TX
440Brian Offline OP
440Brian  Offline OP
Dallas, TX
I added a shut off valve to the vent line (on top of the roll over valve) when I installed a new aluminum fuel cell. Will that work with overnight temperature and atmospheric pressure changes or is a rubber cap/plug a better choice because it will flex?
(sorry if I'm worried about ridiculous problems)
Re: How often do you drain your racecar fuel cell (gas only)? [Re: 440Brian] #1872516
07/17/15 08:19 PM
07/17/15 08:19 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
only time I drain the regular racing fuel is when I put the car away for the winter, but I also fill it to the top after a race to keep the amount of air in the cell to a minimum.
Re: How often do you drain your racecar fuel cell (gas only)? [Re: dartman366] #1872570
07/17/15 10:03 PM
07/17/15 10:03 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Not sure about today's fuel. Back in the day we used cam 2 purple, left it in the cell all week, come race day it was almost empty. I thought it was evaporating so I put some in an open container and sure enough after a couple days it was gone, so I looked at the Cam 2 blue specks, it cost more but it didn't evaporate. I honestly think it was a marketing trick to sell more fuel, since every bracket racer used purple at that time.
Re: How often do you drain your racecar fuel cell (gas only)? [Re: 440Brian] #1872588
07/17/15 10:41 PM
07/17/15 10:41 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
FWIW I run nothing but VP fuels. From our experience the extra insurance of draining the fuel after a race is cheap easy insurance and yes I have had fuel go bad.
Re: How often do you drain your racecar fuel cell (gas only)? [Re: 440Brian] #1872623
07/17/15 11:21 PM
07/17/15 11:21 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
wave
Re: How often do you drain your racecar fuel cell (gas only)? [Re: 440Brian] #1872667
07/18/15 12:43 AM
07/18/15 12:43 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Its a good idea IF you let the temp cool down before closing
the valve... if you have a 100+ degree day and you close the
valve and it drops to about 30* or so... it will collapse a
plastic tank... its the thermo change along with the fuel...
when I was testing burst pressure in stock tanks it took about
55-60 psi to blow a tank open(we always use water so it wouldnt
literally blow up
EDIT
These were on steel tanks... plastic ones we were always concerned
with temp
wave
Re: How often do you drain your racecar fuel cell (gas only)? [Re: MR_P_BODY] #1872681
07/18/15 01:04 AM
07/18/15 01:04 AM
Az
Crizila Offline
Crizila  Offline
Az
literally blow up
EDIT
with temp
wave
If you can't control the environment you store it in, you better vent it - even if you store it in your enema bag! Good luck if you are storing E85 for any length of time.
Fastest 300
Re: How often do you drain your racecar fuel cell (gas only)? [Re: 440Brian] #1872735
07/18/15 02:55 AM
07/18/15 02:55 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
You should never leave fuel in your cell. If you do, it should only be enough to warm the car on at the next race. In a plastic jug, or in a vented cell, the fuel will loose it aromatics package very quickly. Being able to close the vent off MIGHT work, provided the cell is not plastic
Re: How often do you drain your racecar fuel cell (gas only)? [Re: 440Brian] #1872782
07/18/15 10:06 AM
07/18/15 10:06 AM
Jerry Kathe Offline
Jerry Kathe  Offline
FWIW, I agree with the above - BUT do NOT store it in a unlined steel drum, or the potential for condensation development will get you and that's worse than the fuel boiling off from atmospheric exposure or UV deterioration.
