Re: Trunk mount battery cable
[Re: 62maxwgn]
#1872243
07/17/15 11:33 AM
07/17/15 11:33 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
how did you test your starter to know it's good? could the starter be getting heat soak from the headers? I've read lots of problems on here where a starter works great when cold, but cranks very slow when warm/hot; regardless of where the battery is located.
**Photobucket sucks**
[Re: stateroadhog]
#1872291
07/17/15 01:11 PM
07/17/15 01:11 PM
RapidRobert
(1) get it good and hot (2) disconnect the trunk batt cables (3) set a known good batt by the Dr front wheel on the ground (4) connect jumper cables, black to batt neg/starter case ear and clamp large/small starter terminals with one end of the red cable & last connection, other red end to batt positive post & see if it cranks normal. work fast for a valid test (while it is still very hot) and secure the red cable on the starter two terminals tight so the clamp dont move a bit when it cranks & contact the starter case. Yes I dont think 2AWG is enough & you've covered everything else ex tight eng & thats pretty rare
[Re: stateroadhog]
#1872353
07/17/15 03:39 PM
07/17/15 03:39 PM
Posts: 25,894 Rio Linda, CA
John_Kunkel
Rio Linda, CA
when motor was hot used co2 to cool starter. If that cured the problem, I'd say the starter is the problem. You say "the starter is good"...how do you know?
[Re: stateroadhog]
#1872357
07/17/15 03:56 PM
07/17/15 03:56 PM
Posts: 21,079 Niles , Ohio
therocks
Niles , Ohio
I run 1 gauge and my battery is in front.No way would I run less than 1 gauge in the trunk.My 12.5 440 with the mini captured in the headers fires like a /6 even hot.Rocky
Chrysler Firepower
[Re: stateroadhog]
#1872428
07/17/15 06:04 PM
07/17/15 06:04 PM
Posts: 1,436 Oklahoma City OK
Cudajon
Oklahoma City OK
I found some 2/0 jumper cables at a truck stop. Red and Black. Thats what I used to mount my batteries (2) in my trunk. Never had a problem. Here a site that has some good info on cable sizes and amperage that can be handled. http://www.directwireusa.com/What-Welding-Cable-Size-Chart/ also be aware if you're running headers heat soak is a big problem on our cars. If anybody knows a good mini starter that wont heat soak I'd sure like to know.
[Re: stateroadhog]
#1872859
07/18/15 01:41 PM
07/18/15 01:41 PM
therocks
Niles , Ohio
My mini is a reman from Advance.Its been in at least 15 years and the 2 inch TTIs capture it real good with the Lakewood.It always starts easy even when in the 90s here.I run the biggets battery CCA wise that fits and 1 gauge cables.12.5 domes in the 440 and it spins like a /6.Rocky
Chrysler Firepower
[Re: therocks]
#1872883
07/18/15 02:12 PM
07/18/15 02:12 PM
RapidRobert
Rock has a good point, even tho his cables are small he might need more battery (or a combo of both issues). They ain't cheap but it'd be easier than changing out your cables. maybe he could borrow a bigger/higher CCA one from a friend just for a quick test.
[Re: stateroadhog]
#1873061
07/18/15 06:25 PM
07/18/15 06:25 PM
therocks
Niles , Ohio
You dont say how old the cables are.I had a set that was about 8 years old and had slow crank.Cables looked new on the outside but under the sheath they were corroded.Thats when I went 1 gauge.Just remember the bigger the wire the less resistance and less voltage drop.Rocky
Chrysler Firepower
[Re: stateroadhog]
#1873249
07/18/15 11:55 PM
07/18/15 11:55 PM
RapidRobert
good battery high CCA battery fresh mini fresh cables. about all that is left is the cables ain't big enough
[Re: stateroadhog]
#1873274
07/19/15 12:55 AM
07/19/15 12:55 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
I ran 4/0 cables when I had a trunk mount battery. Overkill? Probably, but I had it and it was free.
[Re: Supercuda]
#1873285
07/19/15 01:26 AM
07/19/15 01:26 AM
RapidRobert
welding cable is a good choice since by design the insulation is thick cuz the cables are getting moved constantly & flexible/multiple small strands of wire & it's reasonable & here at least when you buy some cable and terminals they'll crimp em on for free (not a dealbreaker but every little bit helps) & I would also solder em also. EDIT just mockup/measure the exact length you need ahead of time
