Edelbrock Thunder AVS carb help
#1872181
07/17/15 07:21 AM
07/17/15 07:21 AM
Posts: 921 Long Island, NY
shocktrp
Long Island, NY
73 Charger SE 400/727. Had carb rebuilt, car still ran like crap when I got it back. Noticed fuel pooling on top of the accelerator pump & spilling onto the manifold, called a mechanic, he said the accelerator pump was probably bad. Ordered another pump & gasket set, changed it myself because carb guy was on vacation (pump spring looked a little weak but was still working). Put everything back together, still have a fuel leak, car not running at all. Had a buddy come over to help me determine where it was coming from, it is definitely coming from these little tubes (on both sides), & it is pouring out from both sides every time the gas pedal is depressed. What are these tubes & what could be the problem (floats, blockage, or something else)?
Re: Edelbrock Thunder AVS carb help
[Re: shocktrp]
#1872183
07/17/15 07:31 AM
07/17/15 07:31 AM
RapidRobert
I'd check the floats (saturation/setting/no mechanical interference) needle/seat condition and fuel psi. recent prob? If so that'd point more to float/needle/seat rather than the fuel psi being too high all of a sudden. I like to lube the bowl screws as they go into delicate alum as I'm in & out of the carb alot in addition to lubing the bowl gasket with WD40 to keep it from sticking/tearing
[Re: shocktrp]
#1873183
07/18/15 10:21 PM
07/18/15 10:21 PM
RapidRobert
Got a new set of (brass) floats. The new floats have a significantly different bend in them that will make the new ones sit much lower in the bowls when it is reassembled. Sumpin ain't right there, can you post pics? when closed (inverted) the tang should be contacting the needle at pretty close to a right (90 deg) angle for ideal leverage and float should be roughtly horizontle but aside from that what is different between the two sets
[Re: shocktrp]
#1873206
07/18/15 10:49 PM
07/18/15 10:49 PM
RapidRobert
especially the new float "float drop" pic the float needs to be bent so it is more inline with the lever arm (you have some leeway as you are working with that amount of bend plus the tang that contacts the needle) to end up with the float pretty horizontle & the right height. You might bend the lever arm some & see where this makes you bend the tang so you get the correct float setting along with that tang close to 90 deg. You're measuring toward the end of the top of the float which is now on bottom since it is inverted down to the gasket
[Re: WO23Coronet]
#1873330
07/19/15 03:18 AM
07/19/15 03:18 AM
Posts: 10,218 Someplace you aren't
SomeCarGuy
Abit OT, but what psi do the Edelbrock carbs like? I've got a a Thunder 800 going on a 440 6 psi is the max. They work great with 6. The edelbrock fuel pumps make 6.
I want my fair share
[Re: RapidRobert]
#1874024
07/20/15 12:53 AM
07/20/15 12:53 AM
shocktrp
Long Island, NY
especially the new float "float drop" pic the float needs to be bent so it is more inline with the lever arm (you have some leeway as you are working with that amount of bend plus the tang that contacts the needle) to end up with the float pretty horizontle & the right height. You might bend the lever arm some & see where this makes you bend the tang so you get the correct float setting along with that tang close to 90 deg. You're measuring toward the end of the top of the float which is now on bottom since it is inverted down to the gasket Done. No more fuel leaks & car starts now, but it just dies as soon as you take your foot off the gas. I figured it's a vacuum leak but I can't find one.
[Re: shocktrp]
#1874096
07/20/15 03:12 AM
07/20/15 03:12 AM
RapidRobert
take out the carb idle mixture screws and blast a 2 second blast of starting fluid into each carb port. hog out the plastic nozzle on the starting fluid can so you can insert one of those thin red straws so you can get a good blast up in there. I'm assuming the initial timing and the idle speed adj screw are in the ballpark
[Re: shocktrp]
#1874295
07/20/15 01:42 PM
07/20/15 01:42 PM
RapidRobert
can you put it in neutral & unscrew the idle speed screw & see if it will slow to a reasonable speed? and hookup your light & see what you have & want no less than 15 initial & see what you do have/& at what speeds
[Re: shocktrp]
#1875563
07/22/15 03:20 AM
07/22/15 03:20 AM
RapidRobert
might be more than 1 prob (backfiring). I'd see if you can get a reasonable idle speed in neutral then check/set the initial on 15 on ported (20 if a hot cam) then put it in drive & see if it'll maintain that
