Re: Should 500" stroker start easily on 91 pump gas
[Re: 68charger440strk]
#1871374
07/16/15 03:32 AM
07/16/15 03:32 AM
Posts: 5,163 CT
GTX MATT
CT
The engine should still start like normal. Normally I would say your initial timing is probably off, but most engines will start happily at 18.
What are you running for an ignition system? And what spark plugs? Are you running a really cold plug to combat the detonation?
I'm sure you were told last year, but your pinging problem is 10.5:1 compression with (what I assume is) no question.
#1871466
07/16/15 11:30 AM
07/16/15 11:30 AM
Posts: 102 Colo
PJ68RT
Colo
Have you checked that you are getting good spark at start up? Do you know what fuel pressure to the carb? Is that the regular performer cam (204 @ .050) or the RPM cam (238 @ .050)?
Just curious...what's your actual (not corrected) cranking compression?
#1871489
07/16/15 11:59 AM
07/16/15 11:59 AM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
I have a 500" low deck with 10.5:1 compression, MP 557 cam, MW Eddy heads, Pertronix Ignitor3 distributor, and a ProSystems 950hp carb. It starts, runs, and drives like a new car. I locked out the timing so it's always about 32 degrees, it's a street only car.
#1871510
07/16/15 12:41 PM
07/16/15 12:41 PM
Thumperdart
State of confusion
I`ve been modifying many carbs but prefer modern billet ones since the base plates don`t warp(4150)like the alum. ones and the blocks are WAY less porous and easier to drill and tap for my tunes. Even the new carbs are in need of mods to clean up the idle/transition and cruise........
#1872081
07/17/15 12:55 AM
07/17/15 12:55 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
The lower octane rated fuel will burn faster and should be easier to start the eng on. I know in the colder weather in the winter my buddies 68 Cuda thats an 11.5 Indy headed 440 will start easier on the pump then it does on race fuel since the race fuel is slower burning. Course my 63 always starts easy on the 92 pump I run. Ron
#1872158
07/17/15 03:31 AM
07/17/15 03:31 AM
Posts: 4,209 New York
polyspheric
New York
Where is your choke indexed? Vacuum break?
Boffin Emeritus
[Re: 383man]
#1872196
07/17/15 09:01 AM
07/17/15 09:01 AM
Posts: 8,166 Plymouth, MI
Blusmbl
Plymouth, MI
The lower octane rated fuel will burn faster and should be easier to start the eng on. I know in the colder weather in the winter my buddies 68 Cuda thats an 11.5 Indy headed 440 will start easier on the pump then it does on race fuel since the race fuel is slower burning. Course my 63 always starts easy on the 92 pump I run. Ron It's not just the octane- fuel purchased from a pump in the colder months in northern climates has better cold start characteristics than summer blend fuel. It's more volatile, even for the same octane rating.
#1872576
07/17/15 10:14 PM
07/17/15 10:14 PM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
I'd be interested to see how that e-85 carb works out for you. I see you are from Aurora. I'm at 225 and iliff. I have had the electric choke set all over the place and I do have a spacer on it too. Once it warms up the plugs look clean and it runs pretty good. No stumble or pinging anymore; it's the starting/idle circuit that is killing me. If it doesn't start up easily at first then it quickly fuel fouls the plugs and then won't start without cleaning or replacing the plugs. That is why I'm wondering of the slop in the butterfly shaft is causing problems with the idle circuit transfer slots being exposed at varying amounts. I'm running ngk xr5 plugs. You guys don't think a 950 would be too much for my mild build? I think the NGK "5" heat range plugs are a hot plug, and should be fine. I would remove the carb to check how far open the throttle blades are at idle and if they are exposing too much of the transition slot. It sounds like you have a pretty mild cam, so I don't think it would need a bunch of throttle opening at idle? I'll send you a PM, You live pretty close by.
