I purchased a 5.2 Magnum to install in my '84 Ram. I am keeping the serpentine drive. Is there a carb intake available that allows the A/C compressor to stay in the stock location?
I just did this with a 5.9 in my '79 Magnum. The only issue I have is the tapped port for the heater hose is under the Magnum's A/C pump and bracket.
Soulition? No problem.
The Edelbrock intake has 2 tapped holes for a temp sending unit. Choose one and drill and tap. I went to the local machine surely shop and purchased a tap and drill to do the job.
It took 20 minutes with a cig brake.
I choose the hole to tap behind the Alt. as to for surely clear the A/C pump. It may clear the A/C pump but I'm not sure. You'll also need a plug for the hole under the Magnums acc. bracket.
