04 Durango 4.7 - No Spark!
#1869730
07/13/15 10:12 PM
07/13/15 10:12 PM
Posts: 8,943 Holly/MI
Dean_Kuzluzski
Holly/MI
So I pulled the intake, replaced gaskets, new sparkplugs, reinstalled everything, plugged in the usual TPS, IAC, Air inlet temp, all the connectors to the coil/plugs and she won't fire.
First suspect was the total lack of fuel since I did remove the fuelrail and it basically emptied itself in the process. Squirted a healthy amount of fuel in there and got nothing.
It cranks steady but not a single pulse like a spark is occurring (even after squirting the gas in). Any ideas as to what I've missed here????
I appreciate any input. Thanks. Dean
Re: 04 Durango 4.7 - No Spark!
[Re: Dean_Kuzluzski]
#1869991
07/14/15 08:24 AM
07/14/15 08:24 AM
Posts: 4,848 Memphis
HemiRick
Memphis
Dont have any advice except for the fact that I think these engines have crappy computer diagnostics. I too have a 4.7 that wont start after being worked on and the computer will not set a code as to why....
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: HemiRick]
#1870006
07/14/15 09:52 AM
07/14/15 09:52 AM
Dean_Kuzluzski
Holly/MI
Rick, Ok, thanks. I figured some of the service techs here would have encountered this in the past. My brother has access to a service manual, I'll see what he can find out. I'll let you know what we find. Thanks again. Dean
#1871539
07/16/15 01:31 PM
07/16/15 01:31 PM
Posts: 198 Stinnett, Tx
rumblebee4232
Stinnett, Tx
I appreciate any input. Thanks. Dean first thing I would look at is the cam position sensor to make sure the plug didn't knocked loose or otherwise unplugged..
