So I pulled the intake, replaced gaskets, new sparkplugs, reinstalled everything, plugged in the usual TPS, IAC, Air inlet temp, all the connectors to the coil/plugs and she won't fire.
First suspect was the total lack of fuel since I did remove the fuelrail and it basically emptied itself in the process. Squirted a healthy amount of fuel in there and got nothing.
It cranks steady but not a single pulse like a spark is occurring (even after squirting the gas in). Any ideas as to what I've missed here????
I appreciate any input. Thanks.
Dean
