1942 plymouth P14C club coupe #1868226
07/11/15 01:59 PM
07/11/15 01:59 PM
O
otter440 Offline OP
otter440  Offline OP
O
I know this has probably been asked before but am new to this forum. I am looking at keeping the stock front suspension but would like to go to a different steering column and rack and pinion steering just wondering if anybody else has gone to this and what they used or suggestions Please. I restore mopar muscle cars and have done so for 20 years. maybe a stub frame??? Just want a low budget rat rod as I have a charger r/t and would like something to just play Thanks for your help.
Re: 1942 plymouth P14C club coupe [Re: otter440] #1868233
07/11/15 02:23 PM
07/11/15 02:23 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Not sure how you can keep the stock suspension and use a sub frame, but here's something that might assit you
http://www.crankshaftcoalition.com/wiki/Swapping_to_rack_and_pinion_steering
Don't be the exception.
Re: 1942 plymouth P14C club coupe [Re: Supercuda] #1868243
07/11/15 02:37 PM
07/11/15 02:37 PM
O
otter440 Offline OP
otter440  Offline OP
O
I did not mean both just if rack and pinion is not an option then maybe go to stub frame Thanks for the info
Re: 1942 plymouth P14C club coupe [Re: otter440] #1868362
07/11/15 06:51 PM
07/11/15 06:51 PM
moparx Offline
moparx  Offline
what do you have now ? what year ? if a straight axle, rack-n-pinion steering takes a giant turn from stock. if original independent style,[34-50 ????? something] racks can sometimes be used. what are you starting with ?
beer
Re: 1942 plymouth P14C club coupe [Re: otter440] #1868392
07/11/15 07:59 PM
07/11/15 07:59 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
I have a tough time understanding the mentality of keeping the stock suspension but the steering needs to be upgraded.
I see it a lot though, so I guess I'm the weird one. Like I need another example of that! laugh2
There are kits that use a GM econobox rack (cavalier?) to replace the worm and sector and slightly strange linkage. It's had mixed reviews, you should be able to find it and the reviews out there with a search.
I plan on getting my '40 running with the disc brakes, lowered uprights and shock relocation then see if the steering is bad enough to warrant looking at an upgrade.
P.S. Would like to see pics of yours. A 42 is darn rare, as I'm sure you know.
Re: 1942 plymouth P14C club coupe [Re: otter440] #1869127
07/13/15 12:29 AM
07/13/15 12:29 AM
Freeport IL USA
poorboy Online content
poorboy  Online Content
Freeport IL USA
I did a Caviler rack on a 39 Plymouth several years ago (maybe 10?) The article above would have solve the few issues I encountered. I also upgraded to disc brakes (my original drum setup was toast). Also move the upper shock mount. If you want to lower the front end, the front spring uses a mounting plate on the lower control arm, the plate is riveted to the top side of the control arm. If you remove the rivets, you can move the spring bracket to the bottom instead of on the top of the the control arm and effectively shorten the springs without cutting them, by 1". You will need to replace the removed rivets for plate on the underside of the control arm with grade 8 bolts.
I know you were requesting info for the front suspension, but also consider updating the rear axle, brakes, and possibly the rear springs as well. Gene
Re: 1942 plymouth P14C club coupe [Re: poorboy] #1869288
07/13/15 10:55 AM
07/13/15 10:55 AM
O
otter440 Offline OP
otter440  Offline OP
O
The car has the stock front suspension in it know the only thing that I have changed so far is I installed a 83/4 rearend in it. I have a 360 I would like to put in but am looking for suggestions of what other people have done to the frt end. I would consider anything to upgrade it for a daily driver.
Re: 1942 plymouth P14C club coupe [Re: otter440] #1869333
07/13/15 11:58 AM
07/13/15 11:58 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Biggest issue with the stock suspension is how the shock is mounted. Relocate the upper mount to the frame and it's pretty good.
The add discs to the front, be advised with your 8 3/4 rear you have better rear brakes than front brakes.
Re: 1942 plymouth P14C club coupe [Re: Supercuda] #1869783
07/13/15 10:34 PM
07/13/15 10:34 PM
dogdays Offline
dogdays  Offline
The real answer is start looking for Dakotas. It kills a number of birds with one stone to do a frame swap or at least a front clip.
It's not romantic, but it gets the job done fast and relatively easily.
R.
Re: 1942 plymouth P14C club coupe [Re: otter440] #1869857
07/14/15 12:17 AM
07/14/15 12:17 AM
Freeport IL USA
Freeport IL USA
The cars original suspension was light years ahead of everyone else at that time, it is fairly modern. Moving the upper shock mount from the upper control arm to the frame is a huge improvement. A front disc brake conversion would be a requirement from me. I would also update to the dual well master as well. A sway bar off a newer jeep will stiffen up he front end even more.
The Dakota option is a very good option (I have one under my 48 Plymouth coupe), it is a lot more work then adding a disc brake conversion, moving the shock mount, and updating the master. Depending on the condition of the brakes & suspension of the doner Dakota, your probably even money by time you rebuild the Dakota stuff.
If you keep the original frame, mount your 360 1 1/2" to 2" towards the passenger side off center. Keep the motor & trans in line with the frame, there is enough movement in the u joints to allow this. Then everything will clear the driver side exhaust. I usually put a notch in the crossmember to clear the crank pulleys, then box it back in. I've done 6 of these cars (5 39-48 Plymouth & 1 Dodge) 4 were original frames, 1 a Dakota clip, & 1 a full Dakota frame. 1 was just the disc brake upgrade & frame notch (360), 2 were disc brake & shock (318 & 360) 1 was disc brake, rack & pinion, sway bar (no shock move) (V6), 1 was a Dakota clip sold off before complete, and the current one is a complete Dakota frame. All of them got the master moved to the firewall. Gene
Re: 1942 plymouth P14C club coupe [Re: otter440] #1870107
07/14/15 02:34 PM
07/14/15 02:34 PM
O
otter440 Offline OP
otter440  Offline OP
O
Gene I like the idea of yours. A couple of questions. I have found a place to get the steering gear rebuilt are they fine to use? Also where do you get the shock mounts and disc brake conversion kit as I want to be sure and get good stuff. Thanks for your help Bob
Re: 1942 plymouth P14C club coupe [Re: otter440] #1870484
07/14/15 11:36 PM
07/14/15 11:36 PM
Freeport IL USA
Freeport IL USA
I'm not going to be much help today.
Steering box. The 3 steering boxes I reused were in very good condition, The one I replaced with the rack was junk, and the Dakota has rack & pinion. I've not had any boxes rebuilt.
Upper shock mounts. I'm a welder by trade, I made my own mounts. They are pretty simple. You need an eye for the shock to mount to, and an arm that extends up and out away from the frame about 2", then a way to attach it to the frame, either weld on to or bolt to the frame at the outside edge of coil spring pocket. The shock just needs to clear everything as it moves, and the bracket needs to be strong enough to do the job. Nothing radical required, unless you intend to be going off road.... Fatman Fabrication (should show up on a Google search) makes the brackets that you weld on the frame for the shocks, and some early 50s Ford trucks used bolt on brackets the are suppose to work on these cars.
Disc brake conversion. Let me start out saying its been many years since I've done the disc brake conversions. Back then there were very few options, and most were petty costly (for me anyway). I always used www.rustyhope.com disc brake conversions. His "kits" come with a couple machined parts, a couple bolts, some instructions and a list of parts you source from whom ever you choose to deal with. His kit requires drilling and re-tapping 2 bolt holes in your spindles. These days there are disc brake conversions that use off the shelf parts that are a simple bolt on. Some even use your cars bearing hubs.
Some days we can help, some days we can't. Gene
Re: 1942 plymouth P14C club coupe [Re: poorboy] #1872084
07/17/15 12:56 AM
07/17/15 12:56 AM
mn
flyman Offline
flyman  Offline
mn
Otter if you want to keep the stock stuff, I have a complete Rusty hope disc brake conversion that I have for sale. PM me here.. Thanks
Re: 1942 plymouth P14C club coupe [Re: flyman] #1876504
07/23/15 12:12 PM
07/23/15 12:12 PM
O
otter440 Offline OP
otter440  Offline OP
O
flyman can you send me some pics and what you need for it thanks Bob radicalresto@gmail.com
