Re: 4l80E in a 68 Charger
[Re: hudsonhornet7x]
#1869193
07/13/15 02:34 AM
07/13/15 02:34 AM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
Blasphemy, of course, but I can certainly see the point. The only Mopar option is to use a 727 with a Gear Vendors OD or a 518 with an adapter and the OD unit on them is weak. But if you were to go with a 5.7 Hemi you could use one of the 8 speed truck automatics which are better than any of the GM offerings.
Back to the question...cut as much as you need to cut and as long as you are at it ditch the torsion bars for a modern suspension...there that ought to stir the wrath of the righteous faithful.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
#1869250
07/13/15 09:08 AM
07/13/15 09:08 AM
Posts: 208 Norrland, Sweden
Swedcharger67
Norrland, Sweden
I can't tell you how much has to go, but the electronic control it offers is, as you say, very attractive. Will be interesting to see eventual info received.
Martin, 67 Charger, 512 cui, E85, MegaSquirt MS3X sequential ignition & injection
#1869314
07/13/15 11:27 AM
07/13/15 11:27 AM
Posts: 984 San Diego CA
65 Hemi
San Diego CA
I had one in a 65 Belvedere that needed the support cut out in the trans tunnel, trans mount modified and the collector on the TTI headers moved. I love it behind the a 500" motor. It was a Phoenix trans and computer and adapter. I sold the car but still have the trans set up and 500" that will be going in another 65 Coronet. The best part about it is you can set the shift points and the trans would shift itself bracket racing. It was considered No E because all the new cars use the same computer.
Doug
MOPAR or NO CAR!!! 1965 Dodge Coronet soon a 6.1 Hemi with a Magnson blower 810 hp on pump gas 1964 Dodge Polara 582" Indy alum Block 426-1RA heads, 1933 Plymouth PE all Steel, LT1 4L60E 1959 Plymouth Savoy 33,000 mile survivor Old cars are never done. They are ongoing projects!
[Re: 65 Hemi]
#1869449
07/13/15 03:42 PM
07/13/15 03:42 PM
Polarapete
Graham, WA
I had one in a 65 Belvedere that needed the support cut out in the trans tunnel, trans mount modified and the collector on the TTI headers moved. I love it behind the a 500" motor. It was a Phoenix trans and computer and adapter. I sold the car but still have the trans set up and 500" that will be going in another 65 Coronet. The best part about it is you can set the shift points and the trans would shift itself bracket racing. It was considered No E because all the new cars use the same computer. I love it!!! Another pioneer not afraid to think outside the "Mopar or No Good" Box
[Re: Polarapete]
#1869979
07/14/15 04:17 AM
07/14/15 04:17 AM
65 Hemi
San Diego CA
I had one in a 65 Belvedere that needed the support cut out in the trans tunnel, trans mount modified and the collector on the TTI headers moved. I love it behind the a 500" motor. It was a Phoenix trans and computer and adapter. I sold the car but still have the trans set up and 500" that will be going in another 65 Coronet. The best part about it is you can set the shift points and the trans would shift itself bracket racing. It was considered No E because all the new cars use the same computer. I love it!!! Another pioneer not afraid to think outside the "Mopar or No Good" Box Yeah, Im pretty messed up. I also run 9" stuff in 4 of my cars and enjoy the ease of swapping the different 3rd members. When mopar guys start hassling me about a ford rear end I ask them to find a ford part on it. The only Ford part is the bolt pattern.
Doug
