crank & water pump pulley compatibility question #1868999
07/12/15 08:42 PM
07/12/15 08:42 PM
Indiana
Chryco69 Offline OP
Missing my hose
Chryco69  Offline OP
Missing my hose
Indiana
Will a single groove crank & water pump pull from a 1966 383 fit a 1972 440?
Re: crank & water pump pulley compatibility question [Re: Chryco69] #1869014
07/12/15 09:41 PM
07/12/15 09:41 PM
yes they will. EDIT I forgot about that (1) hole in the crank pattern may (or may not) be slightly offset but elongating the hole in the pulley is acceptable
Re: crank & water pump pulley compatibility question [Re: Chryco69] #1869180
07/13/15 01:55 AM
07/13/15 01:55 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
the water pump pulley and the crank pulley will fit , BUT as mentioned there my be one hole that is off because chrysler changed the bolt patterns so the pulley only bolts on in one orientation , you can just elongate that one hole with a rat tail file .
Re: crank & water pump pulley compatibility question [Re: Chryco69] #1869306
07/13/15 11:17 AM
07/13/15 11:17 AM
Indiana
Chryco69 Offline OP
Missing my hose
Chryco69  Offline OP
Missing my hose
Indiana
