Re: Fisheyes in paint but not in the primer. Huh?
[Re: Kern Dog]
#1868617
07/12/15 01:48 AM
07/12/15 01:48 AM
RapidRobert
I ain't a paint guy so this is strickly a BTT for ya since you ain't getting any love on this Q but I'm thinking contamination of some sort on the surface being painted (tack rag or???) & they always say prep is 90% (or more) of a successfull outcome. the little bit of rattle can painting I do I prep the surface like I'm doing surgery, nothing touches that ain't supposed to & I brake kleen/wax grease remover everything squeaky clean. Holler how it turns out
[Re: Kern Dog]
#1868636
07/12/15 02:56 AM
07/12/15 02:56 AM
Posts: 12,043 State of Confusion
hp383
Just a normal tag again
State of Confusion
Are you using a filter at the air supply to the paint gun to catch any oils that may be in the air line?
I always use a disposable in line filter right at the gun, and change it for each paint job.
I am by no means an expert at painting, but to date I have never had any fisheye issues.
It sounds like you are cleaning and tack clothing the body before painting, and taking all the other precautions.
Join the Penguin Liberation Front!! Stop the Hippo Occupation!
[Re: Sxrxrnr]
#1868646
07/12/15 04:01 AM
07/12/15 04:01 AM
Posts: 3,319 Chicago Burbs
sthemi
Chicago Burbs
fisheyes are not noticeable or common in primer, It dries fast and the paint doesn't have time to move away from the contaminate, like it does in topcoat.
Things that cause them are many... oil or water in air line, silicone anywhere in the area, antifreeze, etc...
It is very difficult to repair as well. Try cleaning the area with solvent, the wet-sand until the water stops beading up in that area. You are also going to need to use a sealer paint ( 2 part), then refinish.
start with light dry coats, let each coat dry, then bump up the paint quantity if it looks good, until it is fixed.
[Re: Kern Dog]
#1868829
07/12/15 02:33 PM
07/12/15 02:33 PM
RapidRobert
but fisheyes were never a problem with the PPG or Omni stuff I sprayed. what about shooting some of that stuff that came out good on prior cars on a test panel? wouldn't that tell you if the contamination is coming from the inside (the equipment) or externally on the surface prep
[Re: Kern Dog]
#1868830
07/12/15 02:38 PM
07/12/15 02:38 PM
Posts: 3,315 West Coast, USA
jbc426
West Coast, USA
Add a few drops of Fisheye Eliminator to your topcoat. Problem solved.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: Kern Dog]
#1870029
07/14/15 10:22 AM
07/14/15 10:22 AM
Posts: 2,112 New Jersey, US of A
PlumCrazy73Dodge
New Jersey, US of A
99% of the time its something on that surface or getting onto the surface. examples as mentioned. oils, touching it after prime, oil in lines. If it was worse on the first than the second I would say its already on the surface or mixed in with your primer from the hose, compressor or gun. I would scuff that area re apply primer, and paint. Is it isolated to one area or the whole car?
73 plumcrazy challenger - 318/904, edelbrock performer 600cfm carb, performer intake and cam. Eddy Alum. Heads 3.91 locker, Doug's headers, accurate ltd. exhaust 73 Cuda - Triple Black 340 4 speed MIKE
[Re: dan9]
#1870476
07/14/15 10:27 PM
07/14/15 10:27 PM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
With the help of the paint sales guy, I may have found the cause. He asked about the procedures I've been using, then told me the exact order of what to do.
Prime vehicle. If vehicle sits for very long or needs to be sanded, FIRST wipe off car with wax and grease remover. I never thought to wipe the bare primer down first, but it does make sense. I could have been driving contaminants deeper into the primer by just jumping in to sand on it, then the reducer in the paint reacts to it.
He really discouraged the use of the fisheye eliminator, claiming that it contaminates the paint gun, mixing cups, air line and requires the user to KEEP using the stuff with any future work on the car.
[Re: Kern Dog]
#1870483
07/14/15 10:36 PM
07/14/15 10:36 PM
Posts: 4,996 new berlin wisconsin
Mr T2U
I agree with this statement. it can contaminate the entire shop depending on how the air flows thru the shop. it can contaminate the gun washer also. also every time you paint car that have eliminator in them you will get fish eyes unless you add eliminator to the paint. fish eye eliminator is like a highly additive drug. you start out using a little bit. before you know it you will be using it every time you paint something. also if the car has ben waxed recently, and you didn't completely remove the way it will give you fish eyes. also if someone armor alls the rubber in the jambs they can get some on the outside of the car. also if you remove the stuff on the outside, every time you open the door it can contaminate the paint job.
perception is 90% of reality
[Re: Mr T2U]
#1871175
07/15/15 09:01 PM
07/15/15 09:01 PM
Kern Dog
Granite Bay CA
Great info guys, I appreciate everything you have contributed so far. The thing is, I'm just confused because I haven't had any fisheye problems until recently. I've painted 13 cars in the past 10 years and this is the first time I've had to deal with this. Maybe I've just been lucky until now?
