Re: Largest streetable cam in 440 with A/C?
[Re: 808CUDA]
#1868382
07/11/15 07:39 PM
07/11/15 07:39 PM
dogdays
Lumpy idle? means the engine isn't working very well at idle. Hearing that in a street car I always think the engine builder paid less attention to performance and more to giving the appearance of performance.
Run an air conditioner? Engine should make decent low end torque.
How to get both? I'd lean towqrds 220 at 50 lift on intake, one or two steps longer duration on the exhaust, have to crutch those stock manifolds. Build the cam on a narrow LSA.
Like a Hughes 2024 ground on a 107LSA. That's what I'd start with.
The torque converter I'd leave stock, or use the higher stall TC from a smallblock like a 340. You don't know what the other converter you have is. Later on, both high and low stall converters used the same smaller diameter case. A good converter doesn't have to behave poorly.
R.
R.
[Re: 808CUDA]
#1868535
07/12/15 12:08 AM
07/12/15 12:08 AM
Posts: 1,134 Lost in Time
Iowan
Lost in Time
My favorite over the years has been the mopar street hemi purple shaft, #P3690214, I've had it in several vehicles including a 77 Dodge Royal Monaco. The cam has a beautiful sounding idle that clears out with the least bit of throttle and works with a stock converter.
cam specs from DC Engine book
lift .471 Duration .284 @ .050 .222
Not sure if the cam is still offered but it should not be hard to find one very close.
Have a great day Iowan
"obsolete is neat"
[Re: 808CUDA]
#1869166
07/13/15 01:35 AM
07/13/15 01:35 AM
dogdays
HERE'S THE THING...the camshaft is the brains of the engine. It is not the place to save money. BUT, having a cam ground with a custom LSA isn't going to break the bank. As a matter of fact, it shouldn't cost very much more at all and shouldn't take a lot of extra time either.
I'd strongly suggest either calling Hughes or else Bullet Cams. Either should be able to get you fixed up, and I believe Bullet will surprise you with prices. Hughes might be a little more, but they specialize in Mopar, that's all they do. If you do go Hughes follow their directions exactly.
Nothing wrong with Comp, but I'd rather not go with a one-size-fits-all cam for your specialized desires. Comp will custom grind a cam for not much more too, most of the guys custom specing cams use Comp. So that's another choice, but the person you talk to may not know much about Mopars. Be aware that Hughes has their own Mopar-specific rough idle cam line. What I've put out there is about one step smaller than their smaller offering.
I've known guys to use cams in stock 440s that were 230 at 50 intake duration and they were disappointed because it softened up the bottom end. These were just regular driver cars, not drag racers.
R.
[Re: gch]
#1869171
07/13/15 01:44 AM
07/13/15 01:44 AM
Posts: 21,847 Kirkland, Washington
Pacnorthcuda
I think the street hemi grind is long gone.The 280-.474 purple cam was it's replacement IIRC,I love that cam but it likes 3.55 gears and a little stall to really wake it up.You could advance it 2-4 degrees and probably be ok.
Agreed. I ran that cam for over 10 years in a 70 'Cuda 440 auto, 3.55 gears, LOW compression. Great idle lope, great street manners.
[Re: Pacnorthcuda]
#1869291
07/13/15 10:59 AM
07/13/15 10:59 AM
Posts: 4,587 Motor City
6PKRTSE
Motor City
I run a Comp Cams XE294 in my charger with power brakes and a/c. I have over 10,000 trouble free miles on it so far. I do run a vac can under my battery tray though for the brakes. Also run a 10" 3500 converter, headers and 4.10 gears.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: elmor353]
#1869340
07/13/15 12:07 PM
07/13/15 12:07 PM
DaytonaTurbo
Manitoba, Canada
It also has a bit of a lope to it and great street manners. A little bit of lope to it. The "big" summit cam kit still doesn't have what I would call a real lumpy idle. Just enough to know it's not stock.
