Re: Converting dash lights to superbright LEDs - Questions..
[Re: OLD318]
#1867334
07/09/15 06:55 PM
07/09/15 06:55 PM
Posts: 956 Chicago
PurpleBeeper
Chicago
OK, I haven't done this swap, but I believe your dash voltage limiter is 5-volts, so if the bulbs are 5V, no problem.
70 Roadrunner convt. street car
440+6, NOS, 4-spd, SS springs
'96 Mustang GT convt. street car
'04 4.6 SOHC, NOS, auto, lowered
"Officer, that button is for short on-ramps"
[Re: Pynzo]
#1867583
07/10/15 04:35 AM
07/10/15 04:35 AM
Posts: 1,805 ky hills
thehemikid
ky hills
Yep, the voltage limiter has to do with the function of the gauges not the lighting of the gauges.
In my 70RR I changed all my dash lights to the SuperbrightLEDs brand bulbs. There are a few different ones to choose from. Study their different brightness & light out put angles well before you buy.
Off hand I don't remember which ones I used. Do think I used different ones for the blinker indicators & bright lights indicator than for the gauges.
I've bought some blinker indicators before for my "true" pro street Cuda (not sure what brand)that where a bit too bright & had to replace & tone then down, that was more than 10 yrs ago.
I'm a bit picky on dash lighting. I put a lot of time in on superbright's site (a good while back though)studying & comparing to only order 1-2 bulbs. Put it in & see if it's what I'm looking for then order the others of the same if needed. Yes I have a few rejects from doing so. I'm on my 3rd Gen back-up lights on the 70, lol! When I see a better focus or brighter I update till I get to the level of what I want.
In my 70 B-body rallye dash I have a blue tent lighting that I'm fairly happy with. Though it's not perfect, there seems to be a very slight tent difference on 1 bulb, or it's the distance that bulb is from the gauge.
I think there is only 1 bulb in my whole interior that's not LED, & that's the back-up indicator, & that's because it was a sealed unit & that's only on for short spurts. All my exterior lights are LED except the head lights.
Something I've just noticed though about the tail lights. They have a small twitching at low idle (small roller cam, but big alternator) last Saturday of the 4th. But it's the 1st time the cars been out in 32 yrs,...so, I'll worry about that a little later, lol.
[Re: OLD318]
#1867657
07/10/15 11:59 AM
07/10/15 11:59 AM
Posts: 15,836 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
I did the dash lights on my 80's Diplomat several years ago, which had a green tint. They were so bright it no longer looked green and was too bright. Mainly, I didn't like how it changed the tint and ended up removing them. I also don't remember which ones, but would also caution you on not going too bright.
Facts are stubborn things.
[Re: OLD318]
#1867694
07/10/15 01:12 PM
07/10/15 01:12 PM
Posts: 28,067 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
The LEDs I put in my 92 D250 dim properly. The LEDs in my Imperial don't dim properly.
I never really dug into it to find out why.
[Re: Pynzo]
#1867820
07/10/15 05:31 PM
07/10/15 05:31 PM
Posts: 1,526 North Carolina
cjskotni
North Carolina
Do they dim with the stock dimmer switch? Yes they dim almost to the bottom but cut off maybe with 10% left of the switch travel. Not an issue since I don't ever use the dimmer near that low.
[Re: Sxrxrnr]
#1868240
07/11/15 02:30 PM
07/11/15 02:30 PM
Posts: 3,277 West Coast, USA
jbc426
West Coast, USA
Anyone have thoughts on overly dim "light bars" on E Body's. I have a thought. Buy 2 sets of green LED's, install one set and if they are any good give me the remaining set.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
