Downside to vacuum dizzy on street/strip car ?
#1866802
07/08/15 06:54 PM
07/08/15 06:54 PM
Posts: 155 Tulsa oklahoma USA
2734bbl
Tulsa oklahoma USA
I'm looking at replacing my Pro Comp mechanical distributor because the bearing is getting noisey with one from Firecore50.
Are there any disadvantages to using a vacuum advance dist on a street/strip car ? I drive my car as much as I feasibly can around town including 15-20 mile runs on the hiway.
67 Dart 440 10.4 comp Old grind .509 OOTB sidewinders RPM intake 750 DP Holley TTI headers 3500 PTC 3.91 gears 275 DRs
Re: Downside to vacuum dizzy on street/strip car ?
[Re: 2734bbl]
#1866826
07/08/15 07:31 PM
07/08/15 07:31 PM
Posts: 2,356 Kentucky
dfsmopars
Kentucky
For a street car vacuum advance is for me. For street I have no down side.
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring ‘14 Big Horn, Quad Cab, 4x4, 1500
[Re: 2734bbl]
#1866931
07/08/15 10:08 PM
07/08/15 10:08 PM
RapidRobert
tune the systems to get the most out of it & there's alot to be gained. initial/total/springs/can in that order
[Re: 2734bbl]
#1867134
07/09/15 11:29 AM
07/09/15 11:29 AM
2734bbl
Tulsa oklahoma USA
Thanks for all your replies.
I was just curious as I've seen a lot of vacuum distributors plugged or not present on a lot of cars and wondered at what point there is a reason to eliminate it.
[Re: 2734bbl]
#1867135
07/09/15 11:35 AM
07/09/15 11:35 AM
Posts: 9,066 Eugene, Oregon
minivan
Eugene, Oregon
Too many reading "Hot Rod" magazine...
[Re: minivan]
#1867163
07/09/15 12:55 PM
07/09/15 12:55 PM
Posts: 6,563 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
Too many reading "Hot Rod" magazine... From 1966... Kevin
[Re: 2734bbl]
#1867184
07/09/15 01:39 PM
07/09/15 01:39 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
I was just curious as I've seen a lot of vacuum distributors plugged or not present on a lot of cars and wondered at what point there is a reason to eliminate it. Alot of iron headed engines built from the 60's to the 90's (no aluminum out there yet for most mopars) were built with open chamber iron heads and no quench. When these guys added alot of mechanical advance they were getting pinging at part throttle with the vacum advance hooked up as they could be seeing up to almost 60 degrees advance at part throttle about 3000 rpm. Problem was with iron heads and no quench and the cheap gas many people just unhooked the vacum advance to stop the pinging. But today with aluminum heads and quench and with custom cams to keep cyl press low enough for pump most can get away with 50 or more degrees at part throttle even on pump and of course at wide open throttle they only have the mech advance around 32 to 38. I saw that alot. As for me I got a great deal on a race dist with no vacum advance so I cant run one or I would if I had it. But my car runs good since I have alot of very fast mech advance but I could get better part throttle milage with a vacum advance as I would just have to tune it in. Also race cars dont use the vacum advance since they are mainly at full throttle most of the time and many saw that race cars did not use the vacum advance so they thought they would be faster without it. Ron
[Re: Twostick]
#1867215
07/09/15 02:44 PM
07/09/15 02:44 PM
Posts: 3,916 usa
lewtot184
usa
Too many reading "Hot Rod" magazine... From 1966... Kevin can we get an amen here? i was in the '60's and we, as kids, were taught that a vacuum advance was a power loss; nonsense! glad i grew up, or sorta grew up.
[Re: lewtot184]
#1867307
07/09/15 05:47 PM
07/09/15 05:47 PM
minivan
Eugene, Oregon
Too many reading "Hot Rod" magazine... From 1966... Kevin can we get an amen here? i was in the '60's and we, as kids, were taught that a vacuum advance was a power loss; nonsense! glad i grew up, or sorta grew up. AMEN
[Re: 383man]
#1867329
07/09/15 06:40 PM
07/09/15 06:40 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Whole lotta words to say that some can't tune an engine. I drove my 64 300 with a warm 413 all across the US with vacuum advance. No aluminum heads, at the time I think only Koffel made them and those heads were overkill for anything with plates. So I ran 906 heads on my 413. Wiht minimal tuning it ran just fine on 93 octane.
