Two options for front brake line... which one do I need? #1866769
07/08/15 06:02 PM
07/08/15 06:02 PM
NorCal
fatsat Offline OP
fatsat  Offline OP
NorCal
I'm looking at a catalog to purchase front brake lines for a 70 b body.
There's two options for passenger side routing... one is that the line goes under the frame rail to the hose. The other routes over the frame rail to the hose by going through the splash guard.
What determines which is correct?
Re: Two options for front brake line... which one do I need? [Re: fatsat] #1866856
07/08/15 08:41 PM
07/08/15 08:41 PM
CA
70-AAR Offline
70-AAR  Offline
CA
Good question. If they know that maybe the know the same information for an E body same year.
Re: Two options for front brake line... which one do I need? [Re: 70-AAR] #1866864
07/08/15 08:50 PM
07/08/15 08:50 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Re: Two options for front brake line... which one do I need? [Re: Alaskan_TA] #1866942
07/08/15 10:31 PM
07/08/15 10:31 PM
Mass
charge70 Offline
charge70  Offline
Mass
If originality isn't a concern you could use either one as the flex line bracket on the frame is in the same spot for either.I work mostly on 70 chargers and I've never seen a brake line come in from the top,they take the under and around route. John.
1970 Dodge Charger R/T S.E. 1969 Dodge Dart GTS 440 M-Code 1970 Dodge Charger 500 383/4-speed w/A.C.
