Best big block drag cooling system options
#1863619
07/04/15 03:00 PM
07/04/15 03:00 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
500" stroker still on engine stand. Very tall filled stock block .060" overbore. Indy -1 heads. What is the best way to cool this thing for drag racing. Aluminum housing and mechanical pump, aluminum housing and electric pump, full electric pump & housing, reverse flow kit from Indy with an in-line electric pump? Since block is filled, thinking also that putting an oil cooler might help a lot.
[image][/image]
Re: Best big block drag cooling system options
[Re: sgcuda]
#1863683
07/04/15 04:15 PM
07/04/15 04:15 PM
sgcuda
Wow. That looks sweet. Are they available on your website? Is there a Y or Tee block before the pump or do you have a crossover tube?
[image][/image]
[Re: AndyF]
#1863886
07/04/15 08:30 PM
07/04/15 08:30 PM
Posts: 582 Livermore, CA
Dduster
Livermore, CA
Andy, do You have a hardware/pulley(s) combo that will work for an alternator, crank trigger and vacuum pump mandrel? That is the direction I want to go with my new motor but I concerned as to the three pulleys necessary (one each?) and the overall depth of the combo to bump into the radiator cooling fan.
[Re: sgcuda]
#1863993
07/04/15 10:18 PM
07/04/15 10:18 PM
Posts: 31,333 Oregon
AndyF
Wow. That looks sweet. Are they available on your website? Is there a Y or Tee block before the pump or do you have a crossover tube? Here is a setup that we ran for awhile on one engine. It worked okay but was a bit of a pain to put together. I recommend the newer design with two input and two exit lines.
[Re: Dduster]
#1864001
07/04/15 10:25 PM
07/04/15 10:25 PM
AndyF
Andy, do You have a hardware/pulley(s) combo that will work for an alternator, crank trigger and vacuum pump mandrel? That is the direction I want to go with my new motor but I concerned as to the three pulleys necessary (one each?) and the overall depth of the combo to bump into the radiator cooling fan. I use a spline drive setup from Peterson. You can stack v groove and Gilmer pulleys as many as you need. To make it easier on your self you should get the ATI damper with the Chevy bolt pattern. There are a lot more choices for Chevy mandrels than Mopar ones. I also use the Chevy trigger wheel.
[Re: sgcuda]
#1864094
07/05/15 01:16 AM
07/05/15 01:16 AM
Posts: 289 Lowes
steve660
Lowes
Ive ran a 1/2 fill 496 with Performer heads, Meziere pump in alum housing and a Be Cool radiator for 9 yrs, no problems. Also ran it with mech pump, no problems. Car ran 9.8s at 3600 lbs. Drove it to the track and back home too.
PSO headed 632 from MM. Cracked cylinder, loose valve seats, low oil pressure, low cylinder pressure. ..... Now its a door stop....
[Re: AndyF]
#1864348
07/05/15 03:08 PM
07/05/15 03:08 PM
Posts: 1,131 Thigh-Gap Junction
New user name, Same old jerk!
Thigh-Gap Junction
My junk has been this way for over 20 years. An electric pump is needed so you can circulate the coolant without running the engine. Combined with an electric fan you can cool down quite quickly if needed. You can't be consistent if you can't go the staging lanes with consistent temperatures. I use a Jabsco Centri-Puppy (centrifugal!) pump from a local marine store, brass nipples, 3/4" heater hose, etc. Just plumb it up. Thermostatic control can be used to cool down to a chosen temp unattended, very handy. I have the CSR coolant thermometer with thermostatic output, enabled with a switch. For a new build I highly recommend using a remote water pump. You can mount the pump down low in the chassis near the radiator and then run a couple of hoses up to the engine. This frees up some space on the front of the engine. ...
[Re: sgcuda]
#1865743
07/07/15 09:33 AM
07/07/15 09:33 AM
Posts: 13,627 Marion, South Carolina [><]
an8sec70cuda
Kenny...depends on how much you want to spend. You def. need an electric pump. I use a Meziere electric pump (45 gpm) in a stock housing and it works great. They make a big 55 gpm pump, but it's over $500. I have a big Griffin radiator, but you don't need one this big since you don't street drive. One of the cheap aluminum radiators from the classifieds here is what I'd use. From what I've heard, the Indy reverse cooling plate isn't worth it.
CHIP '69 road runner, 440-6, 4 speed, Dana 60 '70 'cuda, 575" Hemi, 727, Dana 60 '71 Demon 340, no drivetrain, on blocks behind the barn '73 Chrysler New Yorker, 440, 727, 8.75....................FOR SALE '90 Chevy 454SS Silverado, 476" BBC, TH400, 14 bolt '06 GMC 2500HD LBZ Duramax '17 Ram 1500 5.7 Hemi
