After-market cruise on 69 GTX #1865351
07/06/15 07:26 PM
07/06/15 07:26 PM
Palmyra, NY
63stabamatic Offline OP
Palmyra, NY
I would like to add cruise to my automatic 69 GTX, anybody know of a good kit?
Thanks,
Re: After-market cruise on 69 GTX [Re: 63stabamatic] #1865370
07/06/15 08:10 PM
07/06/15 08:10 PM
West Central Wisconsin
DeMopuar Offline
DeMopuar  Offline
I haven't done it yet, but I am going to try it once the body work and paint is done on my 1971 Cuda. I will be installing a Rostra 250-1223 Universal electronic cruise to the Cuda. I can use the 4 wire Mopar cruise control lever (you may be able to use a Mopar cruise lever too -- it all depends how it attaches to the turn signal switch) with the Rostra setup, so it will look factory in the passenger's cabin at least. I'm also going to use the factory cruise stuff at the carb end as well -- so I'm hoping that it will work well but I really can't tell you. Here's a link to the Rostra site:
Rostra Cruise Control Servo
I've also attached a photo of a C body cruise lever. The B and E bodies work exactly the same, but the way it attaches to the turn signal switch is different is all. Also, DON'T cut the wires to install the lever. Get the right tool to release the pins out of the plastic connector and then reinsert them all back in -- it works and looks so much better than butchering the wiring for the cruise levers. Also, don't forget, you need the 4 wire setup to work with the Rostra. The earlier 3 wire levers are useless.
Good luck!!!
Re: After-market cruise on 69 GTX [Re: DeMopuar] #1865385
07/06/15 08:39 PM
07/06/15 08:39 PM
Dandridge TN
Dabee Offline
Dabee  Offline
Dandridge TN
I used these on my 69 Bee. Easy to install and works great. The only draw back is you need to cut the turn signal lever to install the control switch.
http://www.summitracing.com/parts/dak-crs-2000-3
http://www.summitracing.com/parts/rpc-250-3032
Re: After-market cruise on 69 GTX [Re: Dabee] #1865710
07/07/15 09:10 AM
07/07/15 09:10 AM
Palmyra, NY
Palmyra, NY
Thanks for the ideas guys. Got some different ones to look at now. Trying to decide whether to go with a drive-shaft magnetic pick-up for speed sense or the in-series cable sensor.
