Re: a body front end suspension kits
[Re: Sasquatch4406]
#186222
01/07/09 02:21 AM
01/07/09 02:21 AM
RapidRobert
Moog on the ball joints & tie rod ends, rubber on the LCA bushing & poly everywhere else. The offset UCA bushings will give you more positive caster. You might check rock auto's prices.
[Re: RapidRobert]
#186223
01/07/09 10:08 AM
01/07/09 10:08 AM
Posts: 3,318 Southern Maryland
klunick
Southern Maryland
Use the Moog stuff. I bought mine from Mancini as a kit. If I remember correctly, I did order the Idler and Pitman arms seperately as well as getting the heavier strut rods and bushings from Just Suspension.
67 Barracuda FB
69 Superbee
"Southern Maryland: If you want a good looking woman, you had better bring her with you"
[Re: Sasquatch4406]
#186225
01/08/09 05:47 PM
01/08/09 05:47 PM
klunick
Southern Maryland
I do not believe that it would make a difference. You are still keeping your front suspension right? I am not familiar with the scarebird swap. Perhaps your ball joints might end up being different for the LCA and UCA. Anyone done the conversion and have any input?
67 Barracuda FB
69 Superbee
