Anorher Isky Rocker ? #1861819
07/02/15 04:13 AM
07/02/15 04:13 AM
W
Wagonman1967 Offline OP
W
So I picked up a set of heads and they have Isky ductile rockers on them. Question is when setting up for push rod length checking with a hydraulic cam . Should the lifter be preloaded and how much. I have an adj rod and dial indicator. Just keep the rocker adj screw threads ant a minimum ? Probably over kill for a hyd, but hey why not? Is there a thread on this?? Thanks..
1968 Bronze Metalic Road Runner
!967 Malibu Wagon Original 4sd w/air
2001 Dodge Ram 4wd
1985 GMC K1500 4in lift
1993 Honda Civic W 350k Beater
2003 Honda VTX 1800 Bagger
Re: Anorher Isky Rocker ? [Re: Wagonman1967] #1861822
07/02/15 04:42 AM
07/02/15 04:42 AM
That rocker should have a 3/8 x24 thread per inch adjuster in it scope If it does set the rocker up so you can get zero preload and then add from 1/3 turn(1/3 of .042 ) to 3/4 turn to get the preload length needed. I would shoot for between 1 to 3 full threads expose under the rocker arm with the preload set up
Re: Anorher Isky Rocker ? [Re: Wagonman1967] #1861995
07/02/15 01:57 PM
07/02/15 01:57 PM
W
W
thanks Cab.
2001 Dodge Ram 4wd
