welding perchs. procedure Q's
#1860505
06/30/15 02:06 PM
06/30/15 02:06 PM
RapidRobert
A body 8&3/4. Landrum springs. all (4) corners of the leafs are at the same location (rear shackle mts were welded on). should I (1) raise each rear corner till each spring (at the locating nub for instance) is the same height as the other side then (2) center the housing (3) then rotate the housing till the pig face angle is correct (5 or 6 up iirc but I will check Docs email) then tack em OR should I weld the pads with the whole housing out of the car on a level pad (with the face angle correct). I thought this'd be easy but having second thoughts! What SHOULD I do? thank you for your time.
Re: welding perchs. procedure Q's
[Re: RapidRobert]
#1860749
06/30/15 07:18 PM
06/30/15 07:18 PM
Posts: 1,373 Rancho Cucamonga, CA
D_C
As best I recall, when I have done it in the past, I positioned the pads approximately where the old pads were, but placed new pads at the new spring-pad mount width. Next, made sure the housing was centered, then mounted the U-Bolts and Base Plates, snugged U-Bolts and lowered the car to the ground; Next, rotated the Pinion to the correct Pinion Angle, Tac-Welded the Spring Mount Pads, then lifted the car, removed the rear axle housing, then fully welded the spring pads to the axle housing tubes.
Finally, remounted the rear end housing into the car and verified that the pinion angle was still correct.
Worst case, I would add slim wedges to correct, but it should Not be necessary.
I've done it three times (8 3/4 and Dana 60 for my '71 Charger and the Dana 44 in my '79 CJ 5 Jeep) and only one needed a pair of thin wedges to get the angle spot on.
That said, there may be other or better methods.
[Re: D_C]
#1860826
06/30/15 09:17 PM
06/30/15 09:17 PM
Posts: 528 SW CO
HemiSportFury
SW CO
That's exactly how I have done it. You need the full weight of the car setting on the springs to set it correctly, then tack, remove and weld.
'64 Sport Fury, 528 Hemi, FiTech EFI, 4-speed, 4.10 Dana 60 '57 Belvedere 2dr sedan, current project in process '19 Cherokee Trail Hawk Elite '03 Ram 2500 CTD HO, 6-speed 214,000 miles and still going strong
[Re: HemiSportFury]
#1860992
07/01/15 12:38 AM
07/01/15 12:38 AM
RapidRobert
That's exactly how I have done it. You need the full weight of the car setting on the springs to set it correctly, Oh OK so I was off base thinking of doing it with a bare housing. I will go ahead & finish assembling the 8&3/4 then mockup loaded as you said. Thank you both!
[Re: Molloy]
#1861306
07/01/15 03:21 PM
07/01/15 03:21 PM
RapidRobert
Dog correct yes you picked up on that that there was more to it/didn't quite make sense, the speedway special pivoting (circle track) front pivots located the spring front end inward a bit from OE cuz they dont quite fit the OE front shackle brackets perfect & the rear shackle mt is not OE & wont be bolted in with the two bolts on each end like OE so I (my buddy) just welded em so the springs were parallel but I did not get the 43 C to C I would like to have so the rear could be used in another A body later on if need be but I decided to follow my own advice & go with what is in front of me right now as opposed to what might be on down the line. Molloy, it is a MIG welder & I will ask my welder about the warp potential when he comes over. I'd like to move the fronts out a bit & bend the rear shackle vertical down brackets so I can get 43" but I'm so far behind the way it is
[Re: Molloy]
#1861310
07/01/15 03:28 PM
07/01/15 03:28 PM
Posts: 25,785 Rio Linda, CA
John_Kunkel
Rio Linda, CA
I've heard several members here claim that welding perches won't warp the housing but I wonder how many of those actually checked with an alignment bar.
I don't claim to be a good welder, but every time I do any welding on a housing it warps.
[Re: John_Kunkel]
#1861318
07/01/15 03:33 PM
07/01/15 03:33 PM
RapidRobert
Yeah John it even seemed like when I was grinding the old perchs off that there was alot of heat being generated. Actually I have one of the centering kits with the pucks but I've never used it & I would have to get that 3/4" (iirc) long centering bar that the kit said was needed extra. Maybe I should go ahead with that. Almost gets tempting to send it in to Moser!
[Re: skicker]
#1861567
07/01/15 10:24 PM
07/01/15 10:24 PM
RapidRobert
Actually on this bare housing Moser shortened it way back & I have been sitting on it for several years so I am assuming it is square (right now). it was a truck housing & I spaced that the perchs were on the wrong side otherwise I coulda had them do them right then. I will get the bar and continue on with this. Thanks for the love guys.
[Re: dogdays]
#1861638
07/01/15 11:04 PM
07/01/15 11:04 PM
Posts: 22,696 Bitopia
jcc
Bitopia
"If you have the pucks for the bar, you are then one length of cold rolled steel away from your own setup."
But I would add, in this case, the bar MAINLY indicates if you have any warpage post welding, its not going to prevent it.
