Top end oil restrictors #1860699
06/30/15 06:15 PM
06/30/15 06:15 PM
Sidney,Ohio
challenger1320 Offline OP
Sidney,Ohio
Indy Maxx block B1 originals single shaft T&D rockers full time oiling what size restictors should I start with going to put them in the block.
Re: Top end oil restrictors [Re: challenger1320] #1860761
06/30/15 07:38 PM
06/30/15 07:38 PM
I'm building a B1 motor using a World 4.500 cast iron block, it has .042 restrictors in the full time oiling passage to the rockers shruggy I'm going to start with them in place up If it is to much I'll add another restrictor in the heads. If to little I'll take the heads off and increaase the size .015 and try again. I do run .039 oil restrictors on all my BB Mopar Indy head motors work That has work well so far with both T&D single shaft and Harland Sharp single shaft roller rockers up work Plenty of oil to the valve springs for cooling and not enough flooding to limit the oil return to the pan on those motors so far on the street and strip applications shruggy This B1 build is going to be a eye opener on the oil return lines from the heads to the oil pan work
