97 Dodge Ram SS/T 5.9 header recommendation #1858466
06/27/15 10:37 PM
06/27/15 10:37 PM
Indiana
68Bee Offline OP
68Bee  Offline OP
Indiana
I recently purchased a 97 Dodge Ram SS/T (2wd short bed) it has the 5.9 Magnum and what appears the factory headers. The headers are starting to look pretty narly from there age and I just blew out the drivers side header gasket again on the drivers side (it was a Mr Gasket ultra-seal). I was curious if anybody has tried the various stainless steel headers on e-bay ones or has a recommendation on what I should buy. Its a daily driver. Thanks guys.
Re: 97 Dodge Ram SS/T 5.9 header recommendation [Re: 68Bee] #1858739
06/28/15 10:40 AM
06/28/15 10:40 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Avoid the ebay junk, those shorty headers are no better than the factory cast manifolds.
If you want the best drop in header, look at Spintechs. they are a mid-length header 4 into 1 design. Great performance and true drop in installation. (although you would have to re-do your entire downpipe, cross over and y-pipe set up, possibly the whole system)
**Photobucket sucks**
Re: 97 Dodge Ram SS/T 5.9 header recommendation [Re: 68Bee] #1859116
06/28/15 08:34 PM
06/28/15 08:34 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
The factory never installed headers. I would not waste $700 on a mid length header. Go long tube ceramic coated for that price since you got to redo the exhaust anyhow. For cheap I would get the 92-93 manifolds and call it good. They are 618 and 619 casting numbers.
Re: 97 Dodge Ram SS/T 5.9 header recommendation [Re: 68Bee] #1859146
06/28/15 09:12 PM
06/28/15 09:12 PM
Indiana
68Bee Offline OP
68Bee  Offline OP
Indiana
It kind of sounds like you guys don't think I would notice much performance loss from the present short headers if I just went back to manifolds to resolve this for good. I may entertain that since its my daily driver and and frankly it doesn't really feel anymore powerful then the stock 5.9 I have had in the past. Thanks guys for all your help!
Re: 97 Dodge Ram SS/T 5.9 header recommendation [Re: 68Bee] #1859701
06/29/15 03:46 PM
06/29/15 03:46 PM
dogdays Offline
dogdays  Offline
The ones you will feel are long tube headers as they increase torque below the torque peak as well as above. There will be plumbing problems so it's up to you to decide whether to do it or not.
R.
Re: 97 Dodge Ram SS/T 5.9 header recommendation [Re: 68Bee] #1861065
07/01/15 06:40 AM
07/01/15 06:40 AM
TX
Kotta390 Offline
Kotta390  Offline
TX
Get the pacesetter long tube headers they are cheaper than spintechs with the same performance.
