Hughes B.B. roller rocker noise? update with video
#1859429
06/29/15 01:33 AM
06/29/15 01:33 AM
Posts: 742 Oak Harbor, WA
Wicked49670dart
Oak Harbor, WA
Just finished freshening up my 496 and notice I now have a lot of rocker noise/chatter. Had the same noise before but with a lot less chatter. Had a valve job and new springs but all the same valve train. My only issue was the heads were resurfaced ( just cleaned up) which made my push rods tips at the rocker about .025 to .030 gap from contacting the rocker. Is this o.k.? Any other ideas why they are louder now? Rechecked the valve lash hot .018/.020 2 times using EOIC method. Noise is coming from both Banks. Oil pressure hot 70 pounds in park and 50 pounds in gear. Have no ticking at all just this chatter type noise. Thanks Matt
Re: Hughes B.B. roller rocker noise?
[Re: Wicked49670dart]
#1859639
06/29/15 02:08 PM
06/29/15 02:08 PM
Posts: 43,308 Bend,OR USA
Cab_Burge
When in doubt, check it out ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) Remove the valve covers and see if you can locate the problem by turning the motor over on the starter with the spark plugs out and valve covers off ![scope scope](/ubbthreads/images/graemlins/custom/scope.gif) If that is not successful try running it with one valve cover off ![twocents twocents](/ubbthreads/images/graemlins/custom/twocents.gif) All things mechanical(motors especially ![whistling whistling](/ubbthreads/images/graemlins/custom/whistling.gif) :)) that make noise after working on the parts that where quite before the work usually are making noise for a reason ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) Let us know what you find ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif)
Re: Hughes B.B. roller rocker noise? update with video
#1860154
06/30/15 12:56 AM
06/30/15 12:56 AM
Wicked49670dart
Oak Harbor, WA
Removed both valve covers and found no issues. Valve adjustment good, rocker side clearance .010, spec from Hughes .005/.015. All roller tips centered on valve stems, plenty of push rod tunnel clearance, retainer and spring has plenty of clearance, plenty of oil on both banks and rockers do not come close to hitting valve covers. Yet it sounds like a sewing machine at idle, you could here the noise 3ft from the fender on both sides! Again no ticking noise at all. The other possibility is I installed a new timing chain with the old gears from Hughes. The engine had 40 passes and some street miles I thought the chain had some play and Hughes sells the chain individually so I changes it. Any possibility this is making noise and echoing up thru the engine? Thanks for the help, very frustrating trying to pin point new problems you did not have before. Matt Here's a video of the noise! https://www.youtube.com/watch?v=fjGtqFFFo6k&list=FLxMcxF_Q-VbADT0Ty2QRn6w&index=1
#1860408
06/30/15 12:00 PM
06/30/15 12:00 PM
Posts: 75,095 A Banana Republic near you.
JohnRR
Just finished freshening up my 496 and notice I now have a lot of rocker noise/chatter. Had the same noise before but with a lot less chatter. Had a valve job and new springs but all the same valve train. My only issue was the heads were resurfaced ( just cleaned up) which made my push rods tips at the rocker about .025 to .030 gap from contacting the rocker. Is this o.k.? Any other ideas why they are louder now? Rechecked the valve lash hot .018/.020 2 times using EOIC method. Noise is coming from both Banks. Oil pressure hot 70 pounds in park and 50 pounds in gear. Have no ticking at all just this chatter type noise. Thanks Matt What kind of cam lifters ? I'm lost on this .025 to .030 gap from contacting the rocker ? is that the gap between the pushrod cup and the rocker body at full lift ?? ????? ?????? Also how about a video that doesn't make one dizzy ?? if you want someone to hear the engine noise just a video of the engine running would be more helpful ...
#1860890
06/30/15 10:24 PM
06/30/15 10:24 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
It sounded like loose valve lash to me. Lash adjustment procedures are all over this website right now. Maybe a different procedure will yield significantly different results.
[image][/image]
#1860919
06/30/15 10:49 PM
06/30/15 10:49 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
Did you get new retainers with the springs? Check to see if the retainers are hitting the rockers. The rockers may need reliefs cut into them. You will never get the lash right if they are hitting each other.
#1860921
06/30/15 10:52 PM
06/30/15 10:52 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
Oil to thin. Pushrods not getting enough oil/ to close to rocker. More lash than you think it has
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
