1963 Chrysler 300 horn not working. Help with ground #1858973
06/28/15 04:44 PM
06/28/15 04:44 PM
Northern NJ
68 Sat Offline OP
68 Sat  Offline OP
Northern NJ
I have figured it out that the steering shaft is not ground. Can anyone help me with how to ground the column?
1963 Chrysler 300 Pace Setter Convertible 21K mile survivor 1969 Dodge Coronet 500 1956 Desoto Hemi 1955 Chrysler C300
Re: 1963 Chrysler 300 horn not working. Help with ground [Re: 68 Sat] #1859221
06/28/15 10:26 PM
06/28/15 10:26 PM
I think OE uses a short pigtail with a ring terminal on each end & iirc one end goes to the col and the other to the dash frame. (from one of the large bolts on that seperate "plate" to one of the thin vertical bolts that hold the plate/col up in position) If a jumper wire with alligator clips lets the horn sound I would just duplicate that. piece of wire/2 terminals/crimp/solder
Re: 1963 Chrysler 300 horn not working. Help with ground [Re: 68 Sat] #1859397
06/29/15 12:56 AM
06/29/15 12:56 AM
Northern NJ
68 Sat Offline OP
68 Sat  Offline OP
Northern NJ
I will try this and look for the pigtail. Thanks.
