Griner t-brake prob. #1858271
06/27/15 05:32 PM
06/27/15 05:32 PM
in front of the computer
8
80arrow Offline OP
80arrow  Offline OP
I just got my trans back from being freshened and got it in today. Put fluid in it and ran it through the gears. When I push my t-brake button, my t-brake solenoid doesn't work. I have power to the stud on the t-brake where it sticks out of the trans but it doesn't click or have reverse when I push the button. Where should I look????
Re: Griner t-brake prob. [Re: 80arrow] #1858272
06/27/15 05:33 PM
06/27/15 05:33 PM
8
80arrow Offline OP
80arrow  Offline OP
It did work before I pulled the trans.
Re: Griner t-brake prob. [Re: 80arrow] #1858277
06/27/15 05:45 PM
06/27/15 05:45 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
....and there's a spade terminal on the other side of that stud. Now you get to drop your trans pan and hook up that lonely wire dangling by itself.
Re: Griner t-brake prob. [Re: 80arrow] #1858281
06/27/15 05:46 PM
06/27/15 05:46 PM
New Smyrna Beach FL
scottb Offline
scottb  Offline
New Smyrna Beach FL
Do you have power to the wire when the switch is pushed if you do the the problem is inside the Trans if not ck for a blown fuse or a broken wire
Re: Griner t-brake prob. [Re: 80arrow] #1858282
06/27/15 05:53 PM
06/27/15 05:53 PM
8
80arrow Offline OP
80arrow  Offline OP
Thanks J Body, just what I want to do, lol. I'll go drop the pan and see. Crap
Re: Griner t-brake prob. [Re: scottb] #1858284
06/27/15 05:54 PM
06/27/15 05:54 PM
8
80arrow Offline OP
80arrow  Offline OP
Yes it has power when the button is pushed.
Re: Griner t-brake prob. [Re: 80arrow] #1858298
06/27/15 06:09 PM
06/27/15 06:09 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
If u have power inside the trans, check the plunger on the solenoid. Had that happen to me a while ago.
Re: Griner t-brake prob. [Re: 80arrow] #1858308
06/27/15 06:21 PM
06/27/15 06:21 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I think they just forgot to plug on the wire when they
put the valve body back on... hope you have a drain
plug on the pan
wave
Re: Griner t-brake prob. [Re: 80arrow] #1858310
06/27/15 06:28 PM
06/27/15 06:28 PM
8
80arrow Offline OP
80arrow  Offline OP
Yup, they forgot to hook the wire up inside. I have a drain plug in the pan so it wasn't that big of deal I guess. It was an easy fix, thanks guys.
