DASH AND STEERING COLUMN USE SAME PAINT??? #185724
01/06/09 03:36 PM
01/06/09 03:36 PM
NW Ohio
6pkaar Offline OP
6pkaar  Offline OP
NW Ohio
Does a '70 'Cuda use the same "suede" paint for the dash frame and steering column? should the old paint be blasted off or can you just sand and recoat with lacquer. The paint is OK on it now with no rust...I just thought I'd "freshen up" the paint with a new coat.qk
Re: DASH AND STEERING COLUMN USE SAME PAINT??? [Re: 6pkaar] #185725
01/06/09 04:22 PM
01/06/09 04:22 PM
California
1970mopar Offline
1970mopar  Offline
California
yes, dash and steering column are both Suade finish in 1970'
Re: DASH AND STEERING COLUMN USE SAME PAINT??? [Re: 6pkaar] #185726
01/06/09 07:31 PM
01/06/09 07:31 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
If the original paint is still nice I'd just scuff it and shoot the fresh coat right over the original stuff...
