Re: 285/70R15 B body pics wanted
[Re: 383man]
#1857293
06/26/15 10:40 AM
06/26/15 10:40 AM
Posts: 701 Southern Maryland
preddy
Southern Maryland
Joe I dont know if this is any help but theses Hoosier radial slicks I run are 30 x 9 and I could fit a 31" tall tire in my stock rear wheelwell on my 63. Ron
I *think* the early B-Bodies have smaller wheel wells than my 69 so if they fit for you guys, that's an encouraging sign. I was thinking about the 285/70R15s to help reduce my final drive ratio for the street. I currently have BF Goodrich 275/60R15s with a 28" diameter and the 285/70R15s have a 30.75" diameter - which is huge. I measured and it looks like the taller tires would fit but its going to be close. I'd sure hate to buy them only to find out later (when I can't return them) that they rub. Thanks
[Re: preddy]
#1857299
06/26/15 10:52 AM
06/26/15 10:52 AM
Posts: 11,836 Florida
mopar346
Let me tell ya about fat chicks!
I don't think the top or inside/outside will be the issue, look closely at the front and rear where the tire meets the rocker and lower quarter. Be sure to think about flex and rebound. If you cant get a store to test fit, which probalby isn't gonna happen nowdays, just buy one and test it. At least you wont be out all the money. Please report back how it works.
Careful, your character's showing!
[Re: mopar346]
#1857325
06/26/15 11:35 AM
06/26/15 11:35 AM
Posts: 3,896 St. Louis, MO
Blues_Cuda
St. Louis, MO
Depending on your wheel size, I don't think you are going to have a problem. My Dad had a buddy that ran 285/70's on his '70 Charger. I believe they were on 15x7 Rallyes. A buddy of mine ran 295/65/15 drag radials on his '68 Satellite convertible with zero issues. 15x8 with 4.5" backspace. Those tires are around 30-30.5" tall. If you were closer, I'd let you borrow my spare 285/70's.
[Re: Blues_Cuda]
#1857369
06/26/15 01:06 PM
06/26/15 01:06 PM
Posts: 5,107 Western Md.
skicker
"The Champ"
"The Champ"
Western Md.
I've got 275/60/17's on my 70 Satellite. They are a full 30" tall. The front of the tire at the bottom of the 1/4 panel was a little too close for comfort for me. I moved the front spring hangers back 3/4". On your Plymouth Body you should be able to use Dodge leaf spring hangers and do the same thing. Be sure to check the driveshaft length if you do relocate them... My self I like the look of the taller tire much better...
...FAFO...
