440 bushing lifters holes what lifters ? #1853043
06/20/15 07:42 AM
06/20/15 07:42 AM
Sweden
Tobbe Offline OP
Tobbe  Offline OP
Sweden
have a block whit bushing lifterholes ,it the smooth comp 829-16 a good lifter for that apllication ?
//Tobbe
Re: 440 bushing lifters holes what lifters ? [Re: Tobbe] #1853117
06/20/15 11:52 AM
06/20/15 11:52 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Any lifter that fits the size of the hole should work fine . Does it have oil holes drilled in them , they be needed for hydraulic lifters
Re: 440 bushing lifters holes what lifters ? [Re: Tobbe] #1856601
06/25/15 01:28 PM
06/25/15 01:28 PM
Sweden
Tobbe Offline OP
Tobbe  Offline OP
Sweden
thanks its solid lifters ,still oilholes in the bushings
//Tobbe
Re: 440 bushing lifters holes what lifters ? [Re: Tobbe] #1856994
06/25/15 09:10 PM
06/25/15 09:10 PM
Oklahoma City OK
Cudajon Offline
Cudajon  Offline
Oklahoma City OK
We always bushed for GM lifters. Lots of options, weight, length, offset and the price is easier than the mopar stuff. Don't do it if going to hydraulic flat tappet or solid, the larger mopar lifter allows for a better ramp profile on the cam than the smaller GM. The GM roller will lighten up the valve train some with rollers.
Re: 440 bushing lifters holes what lifters ? [Re: Tobbe] #1857026
06/25/15 09:44 PM
06/25/15 09:44 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I use the 829 tappets in my bushed block. Over 200 passes at .800" lift@7100. Lash has been spot on at every check.
Doug
