Page 1 of 3 1 2 3
3D Printers are Fun! Gen 3 Hemi Roller Rockers #1856243
06/24/15 10:54 PM
06/24/15 10:54 PM
Smyrna, South Carolina
STEFF Offline OP
STEFF  Offline OP
Here's some pics of my latest project for my Gen 3 Hemi. I designed up some Roller Rockers. Designed them up in Solid works and a friend at work has a 3D printer. Unbelievably Cool to be able to print a working mock up prototype in 1 1/2 hrs. These are version 2. I have one more dimensional change to the intake rocker to try and next step will be FEA analysis to refine weak points, eliminate unnecessary material weight and then off to manufacture a full set of working prototypes. Material will be steel.
Re: 3D Printers are Fun! Gen 3 Hemi Roller Rockers [Re: STEFF] #1856248
06/24/15 11:03 PM
06/24/15 11:03 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
What advantages/improvements did you design into them?
Re: 3D Printers are Fun! Gen 3 Hemi Roller Rockers [Re: STEFF] #1856253
06/24/15 11:06 PM
06/24/15 11:06 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
Where's the "like" button? Very cool!
Re: 3D Printers are Fun! Gen 3 Hemi Roller Rockers [Re: WO23Coronet] #1856263
06/24/15 11:18 PM
06/24/15 11:18 PM
STEFF Offline OP
STEFF  Offline OP
Much improved geometry for larger lift cams. Changed the angle relationship between the valve typ contact to the pushrod cup by 12 degrees to get the pivot centerline to the valve and pivot centerline to pushrod to 90 degrees at mid lift.
Re: 3D Printers are Fun! Gen 3 Hemi Roller Rockers [Re: STEFF] #1856301
06/25/15 12:05 AM
06/25/15 12:05 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Schwing!
Mopar to the bone!!!
Re: 3D Printers are Fun! Gen 3 Hemi Roller Rockers [Re: STEFF] #1856352
06/25/15 01:08 AM
06/25/15 01:08 AM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Mid lift of what lift?
Re: 3D Printers are Fun! Gen 3 Hemi Roller Rockers [Re: STEFF] #1856360
06/25/15 01:30 AM
06/25/15 01:30 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Google you tube Joseph de Simone 3 -d printers are now antiques
Re: 3D Printers are Fun! Gen 3 Hemi Roller Rockers [Re: rowin4] #1856378
06/25/15 02:00 AM
06/25/15 02:00 AM
SoCal
Brian Hafliger Offline
SoCal
Don't forget an adjuster! What ratio are you planning?
Brian Hafliger
Re: 3D Printers are Fun! Gen 3 Hemi Roller Rockers [Re: STEFF] #1856419
06/25/15 03:50 AM
06/25/15 03:50 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Way too cool.
Re: 3D Printers are Fun! Gen 3 Hemi Roller Rockers [Re: STEFF] #1856420
06/25/15 03:55 AM
06/25/15 03:55 AM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
That is awesome! What's it cost to print something like that? What kind of tolerances can they produce?
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: 3D Printers are Fun! Gen 3 Hemi Roller Rockers [Re: rowin4] #1856433
06/25/15 07:46 AM
06/25/15 07:46 AM
pennsylvania
poboyengineering Offline
pennsylvania
Was that a Bucky Ball he made onstage?
Very cool stuff!
It may be ugly, but it sure is slow.
Girls comb their hair in rear view mirrors and the boys try to look so hard....
Re: 3D Printers are Fun! Gen 3 Hemi Roller Rockers [Re: poboyengineering] #1856449
06/25/15 09:23 AM
06/25/15 09:23 AM
Chicago, Illinois
donscuda Offline
donscuda  Offline
Chicago, Illinois
Great work on the design! thumbs
Re: 3D Printers are Fun! Gen 3 Hemi Roller Rockers [Re: STEFF] #1856463
06/25/15 10:02 AM
06/25/15 10:02 AM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
Very cool Steff. up adjusters?
"Just a Bracket car dressed up like a streetcar"
Re: 3D Printers are Fun! Gen 3 Hemi Roller Rockers [Re: Just-a-dart] #1856489
06/25/15 11:06 AM
06/25/15 11:06 AM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
Nice work! Since they will be made of steel, are you going to press in bronze bushings?
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: 3D Printers are Fun! Gen 3 Hemi Roller Rockers [Re: STEFF] #1856495
06/25/15 11:12 AM
06/25/15 11:12 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
A great concept but these guys are still a long way from having their product on the market.
3D printers will still be around for a while yet.
Re: 3D Printers are Fun! Gen 3 Hemi Roller Rockers [Re: STEFF] #1856496
06/25/15 11:12 AM
06/25/15 11:12 AM
Canada
onig Offline
onig  Offline
Canada
That is so cool.
Any design changes on your belt drive or updates?
69 Dart
Re: 3D Printers are Fun! Gen 3 Hemi Roller Rockers [Re: HotRodDave] #1856523
06/25/15 12:03 PM
06/25/15 12:03 PM
STEFF Offline OP
STEFF  Offline OP
Unless you want to run Jesel's Keyway or Dogbone Lifters, or until someone comes out with a less expensive aftermarket lifter for the Gen 3's, stock lifter travel is pretty much maxed out with .400 /.420 max lobe lift. These rockers are set up with a 1.65 rocker ratio. My solid lifter cam has a .410 lobe. .410 x 1.65 = .676. Then take away lash.... .676 - .014 (int)= .662. Mid valve lift = .331"
Re: 3D Printers are Fun! Gen 3 Hemi Roller Rockers [Re: DemonDust] #1856524
06/25/15 12:06 PM
06/25/15 12:06 PM
STEFF Offline OP
STEFF  Offline OP
Friend is doing them. I gave him few bucks. Printing Tolerance is +/-.005"
Re: 3D Printers are Fun! Gen 3 Hemi Roller Rockers [Re: Just-a-dart] #1856526
06/25/15 12:07 PM
06/25/15 12:07 PM
STEFF Offline OP
STEFF  Offline OP
No adjuster. Setting lash with Lash Caps like NASCAR has evolved to.
Re: 3D Printers are Fun! Gen 3 Hemi Roller Rockers [Re: DusterDave] #1856527
06/25/15 12:08 PM
06/25/15 12:08 PM
STEFF Offline OP
STEFF  Offline OP
Yes
Page 1 of 3 1 2 3
