oil slinger #1855684
06/24/15 01:04 AM
06/24/15 01:04 AM
Eastern ohio
Alexdodge Offline OP
Eastern ohio
Is a oil slinger on a big block necessary?
Re: oil slinger [Re: Alexdodge] #1855690
06/24/15 01:14 AM
06/24/15 01:14 AM
no but if you have one I'd use it. there was a debate awhile back whether it is an oil slinger or there to help protect the seal & seal material is much better than decades ago. If you need one I'll get you one in your mailbox for a ten dollar bill!
Re: oil slinger [Re: RapidRobert] #1855694
06/24/15 01:19 AM
06/24/15 01:19 AM
Eastern ohio
Eastern ohio
After I installed the motor back in the car and reinstalled everything I realised I had left out the slinger. Just dont want to undo it all. Its just going to be for cruisin and touring. Thanks
Re: oil slinger [Re: Alexdodge] #1855695
06/24/15 01:22 AM
06/24/15 01:22 AM
You'll be fine
Re: oil slinger [Re: Alexdodge] #1855778
06/24/15 09:38 AM
06/24/15 09:38 AM
N
NITROUSN Offline
NITROUSN  Offline
N
Don't worry about it. The factory quit installing them without changing anything else. It will be just fine.
Re: oil slinger [Re: Alexdodge] #1855780
06/24/15 09:41 AM
06/24/15 09:41 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I have always had good intentions to put them in and somehow have always left them on the bench, never had any problems. When I built the stroked 4.0 for my Jeep I did the same thing. I cleaned the oil slinger and put it in line to be installed, ended up on the bench just like my small block ones always have LOL. Its got 50K miles on over 11 years, I think its going to be OK.
68 Barracuda Formula S 340
