street 360 la harmonic balancer
#1855558
06/23/15 10:50 PM
06/23/15 10:50 PM
Posts: 855 ontario canada kingston
aspenrt360
looking for a decent balancer for a 360 street engine external balance. would like to go aftermarket to get the fancy timing marks up to 60 degrees but would also like no hassle getting my pulleys on and aligned.what brand and part do you guy's recomend? thanks.
2013 Chrysler 300 touring 1974 Dodge Charger SE. 360-727-8.75-3.23 sure grip 1972 Dodge Dart Swinger 1995 Dodge Ram 1500 4x4
Re: street 360 la harmonic balancer
[Re: aspenrt360]
#1855564
06/23/15 10:55 PM
06/23/15 10:55 PM
Posts: 20,174 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Matt and I both had summit brand spin on us so for cheaper builds I bought a powerbond off amazon to give it a try. Ati goes on my higher HP, dollar builds
[Re: aspenrt360]
#1855578
06/23/15 11:08 PM
06/23/15 11:08 PM
aspenrt360
thanks for the info! did you like the powerbond?
[Re: aspenrt360]
#1855614
06/23/15 11:33 PM
06/23/15 11:33 PM
Posts: 20,174 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Its on the engine but not in use yet. Sorry.
[Re: aspenrt360]
#1855628
06/23/15 11:47 PM
06/23/15 11:47 PM
Posts: 8,026 Tulsa OK
Bad340fish
Tulsa OK
I think mine is a jegs non SFI if I remember right. Its been good, 450ish HP street 360 no troubles. I checked it against my fluidamper recently to make sure it hadn't turned and it was good after 4000 miles and a good amount of passes.
68 Barracuda Formula S 340
[Re: pittsburghracer]
#1855643
06/24/15 12:02 AM
06/24/15 12:02 AM
Posts: 1,267 North, Alabama
D-50
North, Alabama
Matt and I both had summit brand spin on us so for cheaper builds I bought a powerbond off amazon to give it a try. Ati goes on my higher HP, dollar builds I had the same thing happen to the Summit brand SFI balancer. I replaced it with a ATI.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
