MUSCLE MOTORS 30 MIN ENGINE
#1855490
06/23/15 08:52 PM
06/23/15 08:52 PM
Posts: 289 Lowes
steve660
Lowes
[size:23pt][/size]In April 2014 I contacted MM to build an engine. Told them I wanted a big CI pump gas engine. After talking to the owner (Mike Ware) he sold me on a 1000 hp 622 w/PSO heads and a Callies crank. Told me most racers don't want a big CI pump gas engine and he has personally wanted to do one but never had the time. We agreed on a price and I was told I would have it by June. July comes around, no engine. Am told all machine work is done, just waiting to be assembled. August....no engine. Tells me "This isn't a simple 500 hp 451 that I could have a less experienced person assemble and that he (Mike Ware) was personally going to assemble it."
Early Dec I get a picture of short block. Late Dec am told heads need pushrod tubes. 3 weeks later get picture of engine on dyno minus intake,only to discover intake and spacers need epoxied. Engine comes off dyno. 2 weeks later back on dyno and after initial startup am told its over oiling top end and it filled vacuum pump puke tank with oil. I personally think it also sucked the pan dry. Their fix was have pushrods made with restricters. Engine comes back off dyno. 2 weeks later back on dyno and HP numbers are low. Checked cylinder pressure and it only has 140 psi cylinder pressure. Said he was being conservative with compression.....uh huh. Now have to mill heads. Engine comes back off dyno. Back on dyno for the 3rd time after heads get milled and now has 150 psi. Mid March Sends me email saying its ready.
Once I get it first thing I notice is they put a Powerbond balancer on a 1000 horse engine with a Callies crank. Also has wrong oil pump cover. 4 weeks later they send correct pump cover and I buy proper balancer. Once I get it running engine gets to 150 degrees and only has 15-20 psi oil pressure at 1200rpm. That's cause they didn't bush lifter bores and why it over oiled the top end. I shut it down for 1/2 hour, restart it and hear all kinds of clatter under valve cover. Pull cover and find exhaust valve locked up in the guide. I contact them and am told it was good when it left there, I said no it wasn't. Then they told me send it back and they will fix all issues for free. Im thinking I was just told it was good when it left, now they are going to fix all issues for free???? Told them they had their chance and f-ed it up. And How could an engine with 150 psi cyl pressure make 1000hp??? If Mike is so proud and sure of his engine he could buy it back. Said they cant do that. ...Personally Im tired of sinking cash into this and am going to part it out. Im scared to run it for fear it'll grenade itself and destroy bottom end. Never even made it on the trailer. Already got some one local interested in heads.
Others on here warned me about MM, but I trusted them and got shafted.
Edit....The bitterness of poor quality remains long after the sweetness of low price is forgotten
PSO headed 632 from MM. Cracked cylinder, loose valve seats, low oil pressure, low cylinder pressure. ..... Now its a door stop....
Re: MUSCLE MOTORS 30 MIN ENGINE
[Re: fullmetaljacket]
#1855517
06/23/15 09:47 PM
06/23/15 09:47 PM
Posts: 289 Lowes
steve660
Lowes
I have been in contact with Best Machine and found it very enlightening. I should have used them from the get go. Obviously MM never has built a wedge headed World block with PSO heads. If they had they would have known about restricting the oil and heads needing push rod tubes. Im scared to think what else is scabbed together in the bottom end. I will check clearances when i start tearing down for parting it out.
[Re: steve660]
#1855594
06/23/15 11:22 PM
06/23/15 11:22 PM
Posts: 11,722 Portage,michigan
B3422W5
Portage,michigan
Muscle Motors is a flat out joke. I honestly don't understand anybody spending a dime with them. Chuck Senatore used to run/ own? It years ago and did great work. Unfortunately he is long gone. I can personally vouch for Best Machine, they built a bulletproof motor for me with never an issue from day one. MM I wouldn't have build a lawnmower engine. They did a 30 minute" shine job" on Eddie heads for a good friend of mine few years ago and charged him for a stage two port. Car was a dog. Had them done by a professional and the car ran like it should( 12.5 to 1 408 in a Demon)
[Re: steve660]
#1855611
06/23/15 11:31 PM
06/23/15 11:31 PM
Posts: 20,188 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Pump gas is a "very flexible" request. To me pump gas is 93-94 but others look at it differently.
[Re: steve660]
#1855612
06/23/15 11:32 PM
06/23/15 11:32 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Engine should live regardless of power expectations IMO.
Mopar to the bone!!!
[Re: AndyF]
#1855620
06/23/15 11:41 PM
06/23/15 11:41 PM
Posts: 289 Lowes
steve660
Lowes
A 1000 hp pump gas engine is way off the charts in terms of what engine builders usually build. I would say that your experience is exactly what I'd expect would happen if someone called up an engine builder and told them to build a 1000 hp pump gas engine.
Muscle Motors has a King Krate 622 that makes 915 hp on pump gas so they know how to build these things. Sounds like you pushed the envelope a bit by asking for 1000 hp. Anytime you push the boundary you have to accept the R&D aspect of the project. And R&D projects rarely stay on schedule or budget. Andy, I did not ask them to build me a 1000hp engine. That's what they said they could build. So I trusted them to do what they said. Their King Crate does not have the PSO heads.
[Re: AndyF]
#1855639
06/23/15 11:59 PM
06/23/15 11:59 PM
B3422W5
Portage,michigan
Muscle Motors has a King Krate 622 that makes 915 hp on pump gas so they know how to build these things. Sounds like you pushed the envelope a bit by asking for 1000 hp. Anytime you push the boundary you have to accept the R&D aspect of the project. And R&D projects rarely stay on schedule or budget. I read the OP again...... He didn't say he " pushed the envelope" he said he wanted a big inch pump gas mill....... " he sold me on a 1000 horse PSO headed engine" I for one can't let you slide misquoting what the OP said, not to mention the quality issues that have nothing to do with horsepower level... But poor machining, thought, and knowledge. Oiling issues, low cylinder pressure, promising and not delivering... Heard this tons of times from this place.... As I am sure you have. Try again Andy... Sorry dude.
[Re: steve660]
#1855641
06/24/15 12:02 AM
06/24/15 12:02 AM
Posts: 1,954 Blairsden, CA
Triggerfish
Blairsden, CA
Man, I really feel for ya. Been there, too. My 1st 440, hyd roller, ported eddy heads, all 1st class parts & custom paint. Loaded it up from the engine builder's shop & took it to Mallory's dyno & produced some good numbers. Was really stoked until a friend pointed out the bolt hole in the curved bell housing mount on the block was sheared off at the hole. Builder says block was that way when we brought it in... Then my bro spent a ton on a roller cammed 472 Hemi that was ready to dyno & he had a gut feeling it wasn't up to snuff after a valve tip sheared off on his 440 built by the same guy that did his Hemi. Shipped the Hemi to Arruzza & John documented enough stuff that said it wouldn't have lasted 2 minutes on the dyno. No cam button & tons of other bonehead mistakes. John built him a killer, reliable 518 that'll fry the tires at 50. Muscle Motors should never have taken your money if they knew they couldn't deliver or never did one before with those heads. I can imagine the bill was huge & now you've got to eat it or trust these boneheads to make it right. I'd ship it to Best & have them assess the motor & see what they can do to. Best wishes in whatever happens.
[Re: steve660]
#1855771
06/24/15 09:17 AM
06/24/15 09:17 AM
Posts: 10,011 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I agree on shipping it to Best or any shop with a very good rep building BB Mopar motors. Either way, parting it or fixing it, is not going to be cheap, but you have the basics for about as much hp as can be had on pumpgas. If you part it out, the huge loss will leave you with no big motor, and you might wind up spending the same as this one to get a decent motor done.
[Re: B1Johnny]
#1855910
06/24/15 02:08 PM
06/24/15 02:08 PM
Posts: 289 Lowes
steve660
Lowes
I would love to have Best go thru it. But my cash is tapped out right now. Still paying on the loan i got last April for it. Im sure Best Machine would like to see the heads since MM copied their design, and prob made them worse. So for now its either part it out or set it in the corner and look at it. It ran 30 min....That works out to $733 a minute.
[Re: AndyF]
#1855952
06/24/15 03:12 PM
06/24/15 03:12 PM
Posts: 289 Lowes
steve660
Lowes
A 1000 hp pump gas engine is an R&D project, especially a Mopar wedge one. You might be able to find a few engine builders who build BB Chevy based pump gas engines that make 1000 hp, but I doubt that there are very many (if any) Mopar (NA) wedge engines that make 1000 hp on pump gas.
I wouldn't attempt to build a 1000 hp pump gas Mopar wedge myself and I've been designing and building Mopar bb wedge motors for over 30 years. I'm surprised it only cost you $22K. My 514 dyno mule makes 930 hp with 15:1 compression and cost more than $25K. Making more horsepower with less compression on a smaller budget is hard to imagine.
If someone asked me to build them a NA Mopar wedge that made 1000 hp on pump gas I'd ask them for $30K down payment and tell them to call back in a year to see how close I was. I'm not sure it is even possible since you would need something on the order of 600 inches that make 1.7 hp/inch. It isn't easy to make 1.7 hp/inch on pump gas in a big engine. 1.7 hp/inch for a 440 is 750 hp. Not very many 750 hp 440 pump gas engines running around.
I'm building a pump gas 470 engine at the moment using some really good parts and I'm shooting for 675 hp or 1.44 hp/inch. I just can't see a reasonable way to get to 1.7 hp/inch with pump gas. I didnt ask for a 1000 hp pump gas engine. I asked for a big CI pump gas engine. They told me thats what they can do. If it was a R&D project and not sure when it would be done they should have told me that...its that simple. According to their Land and Sea dyno it made 1004 hp. 1000 divided by 622 equals 1.6 horse per inch.So i guess it can be done. Maybe you should be telling MM this ....
[Re: pittsburghracer]
#1855958
06/24/15 03:17 PM
06/24/15 03:17 PM
Thumperdart
State of confusion
Pump gas is a "very flexible" request. To me pump gas is 93-94 but others look at it differently. Lucky you....................we get 87,89 and 91 which I drive on but would never even consider racing it that way.
[Re: AndyF]
#1855975
06/24/15 03:42 PM
06/24/15 03:42 PM
Posts: 2,128 Salt Lake City
camastomcat
Salt Lake City
I'm building a pump gas 470 engine at the moment using some really good parts and I'm shooting for 675 hp or 1.44 hp/inch. I just can't see a reasonable way to get to 1.7 hp/inch with pump gas. Am I missing something? I didn't see a figure of 22k. If it was only going to cost 22k, I would have been sceptical from the start. I agree with Andy, you can't build anything like that for under 35k unless it's a GM deal, and even then, I'm not sure. And let's not get started an what people advertize, because that's BS almost always.
[Re: steve660]
#1855977
06/24/15 03:44 PM
06/24/15 03:44 PM
B3422W5
Portage,michigan
It shouldn't be impossible to get 1.7 per cube on pump. It's pretty easy with a non exotic build to do it with more compression, challenged heads, and less than ideal headers. My old W5 motor @ 422 inches went 140@ 3220 pounds with a crude suspension, shelf tti headers, and likely a non optimal carb tune. That should be 1.7, or mighty close, and the heads were definately too small. Good heads for engine size, optimal headers and optimized A/ F's even with pump gas shouldn't be challenging I wouldn't think.
[Re: steve660]
#1855982
06/24/15 03:55 PM
06/24/15 03:55 PM
B3422W5
Portage,michigan
I see where Scott Brown built a 496 pump gas Hemi 6 or 7 years ago that made 851 horse 1.71
[Re: steve660]
#1855992
06/24/15 04:06 PM
06/24/15 04:06 PM
Posts: 10,555 Rittman Ohio
fourgearsavoy
Rittman Ohio
It's very frustrating for me to read these posts and it's not even my engine.I was fortunate enough to learn engine building skills when I worked in a heavy equipment component room when I was 14 years old. I really don't understand why people entrust their tens of thousands of hard earned money to someone they hardly know to build a bomb like that. Engine building is not that hard but it does take a fair amount of time and a well equipped tool box.I think some of these engine shops get behind the 8 ball and with too many irons in the fire and hurry the builds and the customer gets something that hasn't been completely inspected. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: camastomcat]
#1855993
06/24/15 04:06 PM
06/24/15 04:06 PM
Posts: 1,106 Quebec, Canada
Diablo
Quebec, Canada
Much easier to get 1.7 from a smaller engine. Apples and Oranges. I see where Scott Brown built a 496 pump gas Hemi 6 or 7 years ago that made 851 horse 1.71 600ci is still apple and oranges to a 496ci. I think if we talked to enough people we will find horror stories coming from many engine builders.
[Re: B3422W5]
#1855999
06/24/15 04:09 PM
06/24/15 04:09 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I see where Scott Brown built a 496 pump gas Hemi 6 or 7 years ago that made 851 horse 1.71 Was that on a dyno or track proven numbers... I dont have a lot of faith in dyos lately.. I would really doubt that the OP engine made 1004 hp on MM dyno... we have seen other engines that came off that dyno and the numbers were NO WHERE NEAR what the track showed
[Re: steve660]
#1856002
06/24/15 04:12 PM
06/24/15 04:12 PM
Posts: 4,457 Washington
madscientist
Washington
The fact that you took out a loan for an engine is big mistake. The engine builder knows the buyer is tapped out so any unforseen costs get ate by the builder (and ther ARE unforseen costs on ANY build).
You are better off putting it in the corner, sitting on it until you are finacially able to fix it correctly (I would figure 10k minimum) and then finish the project.
I know it's a bitter pill but it is what it is.
Shame on Muscle Motors for bidding WAY too low on an engine like that. I would like to hear their side of the story.
A good friend told me decades ago this little phrase. It has proven true many times. It goes like this: race you wage.
Best of luck to you.
[Re: MR_P_BODY]
#1856010
06/24/15 04:20 PM
06/24/15 04:20 PM
B3422W5
Portage,michigan
I see where Scott Brown built a 496 pump gas Hemi 6 or 7 years ago that made 851 horse 1.71 Was that on a dyno or track proven numbers... I dont have a lot of faith in dyos lately.. I would really doubt that the OP engine made 1004 hp on MM dyno... we have seen other engines that came off that dyno and the numbers were NO WHERE NEAR what the track showed Lol..... You don't have to convince me to not believe anything they say.
[Re: steve660]
#1856015
06/24/15 04:33 PM
06/24/15 04:33 PM
Posts: 13,376 Marion, South Carolina [><]
an8sec70cuda
Steve...Like I told you before, I'm very sorry for what you've gone through, but you're better off sitting on it and having it fixed by someone professional when you have the financial means to do so. I'd suggest Dwayne Porter at Porter Racing Heads or Todd Marsh at Marsh Performance.
I'm pretty sure Tig's 600+ inch motor that Todd Marsh built for him made well over 1000 hp on pump gas. I don't see it as impossible at all. My 572 hemi is pretty mild and makes over 800 hp N/A on pump 93 (140 mph at 3800+ lbs.). With a much more aggressive cam, bigger heads, and a tunnelram w/ a pair of dominators...I feel pretty confident it could make 4 digit power. I decided to leave the motor mild and spray it into 4 digit territory. My last outing proved it to be making around 1080 hp w/ a very mild tune up.
[Re: madscientist]
#1856030
06/24/15 05:03 PM
06/24/15 05:03 PM
Posts: 289 Lowes
steve660
Lowes
Best of luck to you. I would like MM to tell their side too. The loan was in my budget. Just wasn't planning taking out another to make engine useable.
[Re: steve660]
#1856035
06/24/15 05:09 PM
06/24/15 05:09 PM
Posts: 289 Lowes
steve660
Lowes
This isn't a thread about how much the engine cost or how much hp/ci it can make. Honestly I wasn't expecting it to make 1000. Regardless of price what I was expecting was an engine that was assembled properly: Clearances checked, good oil control, good oil psi, good cylinder psi. At least it would be a solid foundation to build upon. Ive raced almost 40 yrs and never had a valve lock up in the guide.
[Re: B3422W5]
#1856036
06/24/15 05:12 PM
06/24/15 05:12 PM
Posts: 289 Lowes
steve660
Lowes
I see where Scott Brown built a 496 pump gas Hemi 6 or 7 years ago that made 851 horse 1.71 Scott built me 2 engines. The 1st one was ready to rock right outta the crate. The 2nd one needed a little work done to it.
[Re: steve660]
#1856040
06/24/15 05:23 PM
06/24/15 05:23 PM
madscientist
Washington
I agree 100%. Basic machining procedures are not hard to follow, regardless of brand (contrary to popular belief, the engine does not know what brand it is).
What is remarkable is the fact that certain technology trickles down from Pro Stock and Comp and some engine builders want to incorporate that crap into bracket engines. While most builders shy away from tunnel rams, roller cam bearings, 1200 plus pound valve springs, aluminum rods and rings with no tension they are quick to adapt incredibly tight tolerances and things of that nature. Not considering that PS has coated everything, impressive oil control and relatively short strokes.
It seems if you stuck a valve I would want to measure the ones that didn't stick. Slow timing is a guaranteed stuck valve even with .005 clearance on it. I would also want to measure the bearing clearances as well. Long stroke/short rod combos tend to make the crank flex and bend (Dart is working on LS blocks with bigger mains to increase overlap to stop some of the flexing issue) and maybe MM thought more clearance was appropriate for you application.
Also as a last thought......guys trying to run what I consider low oil pressure are doing the most damage to roller lifters, scuffing pushrods and grabbing bearings. I would rather have 50 at idle than 20. But that is me.
I think keep what you have, take some time off and regroup. this kind of thing is as bad for our hobby as is unavailable parts and crooked suppliers. Trust your gut. Most times it's right.
[Re: B3422W5]
#1856052
06/24/15 05:47 PM
06/24/15 05:47 PM
Posts: 701 Northern California
lilcuda
Northern California
MM I wouldn't have build a lawnmower engine. LOL! I've said the exact same thing about MM. Some of the worst quality work I've ever seen. We sent everything back.
'67 is an abbreviation of 1967 67' is an abbreviation of 67 feet They are not interchangeable.
[Re: steve660]
#1856085
06/24/15 06:34 PM
06/24/15 06:34 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
Sometimes engines DO care what brand they are... a strictly chevy guy may not be familiar with chryslers core shift problems (probably why I have a 318 block in here with a 4.070 bore), or a ford guy messing with a chevy or dodge with siamese ex ports and the way the heat can build up there, or oiling differences are vast between different engines and can be very critical, or a dodge guy wondering why the heck chevy BBs have good ports and bad ports (one dumps in the middle of the cylinder and one dumps into the cylinder wall) and the best way to cam around it... thats just a few examples I can think of and I am just a little peon engine builder, there are tons of different engines that do have little quirks that a specialist engine builder may know where a "build everything" guy could not possibly know them all, he may build an adequate engine but a specialist should be able to wring a tad more and probably cheaper. Think you should take your SB mopar to John Kass? Or 351 windsor to Ray Barton? Those guys have incredible mad skills but probably better people out there for those engines.
[Re: madscientist]
#1856098
06/24/15 06:50 PM
06/24/15 06:50 PM
Posts: 5,111 Western Md.
skicker
"The Champ"
"The Champ"
Western Md.
I had a former engine builder that had "Speed costs money...how fast do you want to go??" Make no mistake...he meant it...
...FAFO...
[Re: HotRodDave]
#1856110
06/24/15 07:25 PM
06/24/15 07:25 PM
madscientist
Washington
Kaase or Barton could build anything for me anytime. The engine has no idea what name is on the valve cover.
Who doesn't know that BBC intake ports are different? I knew that the first time I looked at one in 1978.
It's plain silly to think that quality machining and engine building is dependent on brand name. The ENGINE HAS NO IDEA WHAT NAME IS ON THE VALVE COVER.
[Re: AndyF]
#1856142
06/24/15 08:32 PM
06/24/15 08:32 PM
Posts: 2,928 A shed in England
Tig
A shed in England
I'm building a pump gas 470 engine at the moment using some really good parts and I'm shooting for 675 hp or 1.44 hp/inch. I just can't see a reasonable way to get to 1.7 hp/inch with pump gas. https://board.moparts.org/ubbthreads/ubbthreads.php/topics/1622793/1.html
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: steve660]
#1856148
06/24/15 08:45 PM
06/24/15 08:45 PM
Tig
A shed in England
Top of the mountain
[Re: dizuster]
#1856475
06/25/15 10:21 AM
06/25/15 10:21 AM
an8sec70cuda
Since when do customers pay for someone else's R&D?
Either a shop can deliver what's promised at a agreed price, or they can't.
[Re: MR_P_BODY]
#1856485
06/25/15 10:58 AM
06/25/15 10:58 AM
Posts: 456 corpus christi tex
Cheatham
corpus christi tex
I see where Scott Brown built a 496 pump gas Hemi 6 or 7 years ago that made 851 horse 1.71 Was that on a dyno or track proven numbers... I dont have a lot of faith in dyos lately.. I would really doubt that the OP engine made 1004 hp on MM dyno... we have seen other engines that came off that dyno and the numbers were NO WHERE NEAR what the track showed In 1978 my dad bought a Prototype Racing engine 331ci for his circle track car that was dyno @ 585 HP @ 8500rpm, car was fast, now today the same size engines are going the same speeds and times around the track but are claiming the engines are making 750-800 + HP lol
[Re: steve660]
#1856497
06/25/15 11:14 AM
06/25/15 11:14 AM
Posts: 289 Lowes
steve660
Lowes
I dont consider this engine an R&D experiment. They offer a pumpgas 622 with Brodix heads on their site. They also have a story on their site about building a set of PSO heads for a customer with a dragster. So they have built engines using World blocks. They have built pumpgas 622's. They have built PSO heads.
[Re: dizuster]
#1856509
06/25/15 11:44 AM
06/25/15 11:44 AM
madscientist
Washington
Happens all the time. When I learn new thing I incorporate them into the next opportunity I have. If that didn't happen, we'd all still be doing 3 angle valve jobs with a stone (for just one small example). Economics 101: the CUSTOMERS pays it all, no matter what. Taxes go up, the customer eats it. Costs go up, the customer eats it. R&D time is no different either. And, not to bash the OP here (because that is NOT my intent) we do not know how many times a customer changes his mind during a build. Some of the most costly engines I have done have been a customer who is like a fart in a skillet. Constantly going on the web, getting the new trick of the week part or procedure and wanting to change something in mid stream. That costs big money and lots of time.
[Re: madscientist]
#1856514
06/25/15 11:53 AM
06/25/15 11:53 AM
B3422W5
Portage,michigan
Happens all the time. When I learn new thing I incorporate them into the next opportunity I have. If that didn't happen, we'd all still be doing 3 angle valve jobs with a stone (for just one small example). Economics 101: the CUSTOMERS pays it all, no matter what. Taxes go up, the customer eats it. Costs go up, the customer eats it. R&D time is no different either. And, not to bash the OP here (because that is NOT my intent) we do not know how many times a customer changes his mind during a build. Some of the most costly engines I have done have been a customer who is like a fart in a skillet. Constantly going on the web, getting the new trick of the week part or procedure and wanting to change something in mid stream. That costs big money and lots of time. That's all well and good. But it has nothing to do with the machining errors and lack of attention to detail assembling the engine. No matter the engine, paying a professional should result in professional results. Not backyard mistakes
[Re: B3422W5]
#1856518
06/25/15 11:57 AM
06/25/15 11:57 AM
madscientist
Washington
Happens all the time. When I learn new thing I incorporate them into the next opportunity I have. If that didn't happen, we'd all still be doing 3 angle valve jobs with a stone (for just one small example). Economics 101: the CUSTOMERS pays it all, no matter what. Taxes go up, the customer eats it. Costs go up, the customer eats it. R&D time is no different either. And, not to bash the OP here (because that is NOT my intent) we do not know how many times a customer changes his mind during a build. Some of the most costly engines I have done have been a customer who is like a fart in a skillet. Constantly going on the web, getting the new trick of the week part or procedure and wanting to change something in mid stream. That costs big money and lots of time. That's all well and good. But it has nothing to do with the machining errors and lack of attention to detail assembling the engine. No matter the engine, paying a professional should result in professional results. Not backyard mistakes I 100% agree and did, infact, post that very same thing several posts ago.
[Re: madscientist]
#1856519
06/25/15 11:58 AM
06/25/15 11:58 AM
Posts: 289 Lowes
steve660
Lowes
Happens all the time. When I learn new thing I incorporate them into the next opportunity I have. If that didn't happen, we'd all still be doing 3 angle valve jobs with a stone (for just one small example). Economics 101: the CUSTOMERS pays it all, no matter what. Taxes go up, the customer eats it. Costs go up, the customer eats it. R&D time is no different either. And, not to bash the OP here (because that is NOT my intent) we do not know how many times a customer changes his mind during a build. Some of the most costly engines I have done have been a customer who is like a fart in a skillet. Constantly going on the web, getting the new trick of the week part or procedure and wanting to change something in mid stream. That costs big money and lots of time. Nothing was changed or added to the build. ...Wait a minute. I did ask for a vacuum pump fitting be put on drivers side valve cover.
[Re: steve660]
#1856521
06/25/15 11:59 AM
06/25/15 11:59 AM
madscientist
Washington
Happens all the time. When I learn new thing I incorporate them into the next opportunity I have. If that didn't happen, we'd all still be doing 3 angle valve jobs with a stone (for just one small example). Economics 101: the CUSTOMERS pays it all, no matter what. Taxes go up, the customer eats it. Costs go up, the customer eats it. R&D time is no different either. And, not to bash the OP here (because that is NOT my intent) we do not know how many times a customer changes his mind during a build. Some of the most costly engines I have done have been a customer who is like a fart in a skillet. Constantly going on the web, getting the new trick of the week part or procedure and wanting to change something in mid stream. That costs big money and lots of time. Nothing was changed or added to the build. ...Wait a minute. I did ask for a vacuum pump fitting be put on drivers side valve cover. Just for fun...was the vaccuum pump included in the original discussions or did the pump come in later. Not doing anything but trying to get background information.
[Re: steve660]
#1856534
06/25/15 12:17 PM
06/25/15 12:17 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
Personally, I think MOPAR guys believing that a MOPAR shop HAS to build, or knows more about MOPAR motors, is one of the stupidest things I have ever heard. Sorry to sound harsh, but a motor is simply an air pump and that does NOT change based on what the valve covers say it is. All the MOPARs has "nuances" stuff is a bunch of crap. Power is power and you know how to make it or you don't. Proper machining is proper machining and you can do it or you can't. Period, end of story.
Wescott is a prime example. LONG time Chevy guy and was immediately a top player with a HEMI. Why, because he KNOWS how to make power and how the pump works.
And look at it this way, if your primary business is wedge Mopars, lets face it, you have been exposed to NO cutting edge stuff in years. So what have you learned about making power. On the other hand, if you build EVERYTHING, you see what is out there and what works. Then you try and apply what you learn to other makes.MM works on everything by the way
And dyno numbers are just that, numbers. Correction factors can be incorporated to make that sheet say whatever you want it to. I am with Andy...........a 1000hp, pump gas, Mopar wedge.......that's a TALL order. And guys can claim they have whatever, but me personally, have NEVER seen one of these "1000 hp pump gas" deals perform like that is what it has for power. MPH doesn't lie........dyno sheets do
And no way I would "part the motor out".........you will get .25 cents on the dollar that way. Probably a simple fix. Set it aside until you can have someone look at it
[Re: madscientist]
#1856538
06/25/15 12:24 PM
06/25/15 12:24 PM
Posts: 289 Lowes
steve660
Lowes
Happens all the time. When I learn new thing I incorporate them into the next opportunity I have. If that didn't happen, we'd all still be doing 3 angle valve jobs with a stone (for just one small example). Economics 101: the CUSTOMERS pays it all, no matter what. Taxes go up, the customer eats it. Costs go up, the customer eats it. R&D time is no different either. And, not to bash the OP here (because that is NOT my intent) we do not know how many times a customer changes his mind during a build. Some of the most costly engines I have done have been a customer who is like a fart in a skillet. Constantly going on the web, getting the new trick of the week part or procedure and wanting to change something in mid stream. That costs big money and lots of time. Nothing was changed or added to the build. ...Wait a minute. I did ask for a vacuum pump fitting be put on drivers side valve cover. Just for fun...was the vaccuum pump included in the original discussions or did the pump come in later. Not doing anything but trying to get background information. Yes it was included in original discussion. It was my fault for not telling them which valve cover i needed it on. ...They charged me an extra $150 to weld it in too.
[Re: Monte_Smith]
#1856648
06/25/15 02:18 PM
06/25/15 02:18 PM
madscientist
Washington
And no way I would "part the motor out".........you will get .25 cents on the dollar that way. Probably a simple fix. Set it aside until you can have someone look at it You are probably correct on the simple fix thing Monte, I just threw the 10k number out there because evidently, the OP says the whole thing is [censored] and needs to be fixed. So I ASSume the cam is wrong, all the machining needs corrected and things like that. The OP will most certainly make it WAY more painful parting it out. I am going to ask my engine if it knows what brand it is. If it does, I guess I need to find a MoPar guru to finish it because I'm not a qualified MoPar expert. BTW, it is an impossiblibilty for a dyno to lie. Dyno's do not lie. Flow benches do not lie. It is the CROOKS that run them who lie. I HATE liars. There is NO EXCUSE in this day and age why you can't get on the phone and learn enough to know that a 1k PG MoPar is a damn big cat to skin. And, while your bullet is on the pump, the customer SHOULD be standing there watching and learning. And ask every question that comes to mind. If the question is not answered to your satisfaction, ask it again. If the builder can't answer it, you can figure you are getting a big ten inch (lie).
[Re: madscientist]
#1856662
06/25/15 02:34 PM
06/25/15 02:34 PM
Posts: 289 Lowes
steve660
Lowes
Madscientist, your right. It is a big cat to skin. Like I said earlier, I didn't expect it to make the number. I did expect it to last longer than 30 min, correct cylinder psi and good oil psi. Just remembered, I was told static comp came in at 12:1 with 150psi cylinder pressure.
[Re: steve660]
#1856696
06/25/15 03:23 PM
06/25/15 03:23 PM
Posts: 232 Lansing, MI
MuscleMike
Lansing, MI
Mr Edwards contacted us about a pump gas shortblock. We had a World block in inventory so we offer to build him a King Krate (at normal pricing) with an upgraded crankshaft. We then offered him (if he was interested) in a set of PSO heads that we were developing. Based on the early flow numbers we anticipated an engine that could make 1000 HP on pump gas. Because it was a development deal we offered him the top half of the engine at cost over a set of original B1 heads. We would also dyno the engine for free. The value of this extra work is approximately $7000 Because the top half of the engine was at cost it was not #1 priority to finish. The engine was on and off the dyno a few times and we had made over 15 dyno pulls with no valve train issues. Mr Edwards contacted us and said that the engine had been idleing for a long time a grabbed a valve. Because of the inconvience and delays I had eric send this e-mail On Monday, June 1, 2015 5:31 PM, Eric Budden <ericbudden@yahoo.com> wrote:
Please let me know when the engine is in the crate and ready for pick-up. Mike figures turnaround time to be 2 weeks. Please forward any areas of concern other than bushing the lifter bores.
Eric@M/M After a day of no response I sent this e-mail. It the adjuster is tight where did the extra play come from?
I had Eric contact you and offer for us to have the engine picked up. We have the BHJ fixture and can bush the block immediately. We would address any other concerns you may have and return it to you all at no cost.
Let me know your thoughts.
Mike @MM
Yes, there have been issues. Should there have been, no. Still we offered to stand behind it, bring the engine back, address any and all concerns, give an exact timeline for repairs and return it at no cost. Mr Edward s has refused this offer.
[Re: MuscleMike]
#1856733
06/25/15 04:03 PM
06/25/15 04:03 PM
Posts: 1,563 Janesville, WI
SpareParts
Janesville, WI
I've been in his shoes, there is a HUGE part of the customer that is scared to send it back to the shop that murdered it the first time around. I'm not saying who's right or wrong but its important to consider the emotions involved here.
The "low priority for at cost parts" thing is BS, nobody put a gun to your head you offered that. Shouldn't penalize the customer based on your offer.
[Re: MuscleMike]
#1856738
06/25/15 04:11 PM
06/25/15 04:11 PM
madscientist
Washington
Mike @MM
This clears up some of it, as was pointed out by camastomcat and Monte (and others) 22k is on the light side for something of that nature. As for the stuck vale, I know of 3 issues that can cause it. Obviously, one of them is too little clearance. Closely related to that is when a supplier changes materiel and it requires more clearance than the SAME part number did before. Some brands of guide that I use/have used get no less the .0025 on the intake and .0035 on the exhaust. I always hone bronze guides as reaming them is a PITA, and sometimes they are not very round. The third thing is a common one that comes around from time to time. It's caused by myth and old wives tales. When starting an engine, I would rather see too much timing than not enough. To some, that is counter intuative. They think you need to "break in" an engine so dial everything down and back, when in reality, the only thing that needs a break in period is a HFT or SFT cam. Anything else is bull crap. When you run the timing retarded, the EGT's go through the roof. Then the valve has to deal with all the heat. When it can't, the stem grows larger than the clearance and it grabs a guide. It won't matter if it has .005 on it. As for the oil pressure issue, the OP has not yet stated what the oil pressure is, what filter he used or the brand and grade of oil. If you did what you say you did, and your offer stands, then the rest of it is on the OP. I would like to see stem diameters, guide diameters, crank dimensions and housing bore measurements posted. If the numbers are posted the math is simple enough but I would think .0028-.0032 on the rods (ASSuming Chrysler rod throws...take about .0003 off for BBC throws) and .0035-.0035 on the mains. Much tighter than that and you can grab a bearing. Tha is, of course, my opinon. Others may think otherwise.
[Re: SpareParts]
#1856742
06/25/15 04:15 PM
06/25/15 04:15 PM
madscientist
Washington
The "low priority for at cost parts" thing is BS, nobody put a gun to your head you offered that. Shouldn't penalize the customer based on your offer. Who says it was murdered? That's not right. It stuck a valve and the OP says the oil pressure is low. Time to put on our big boy pants and take emotion out of it. It's possible the stuck valve was customer induced. And if I'm doing something at cost, and doing the R&D on it, I damn sure ain't moving your stuff to the front while profit making customers wait. MM is in business to MAKE MONEY. This isn't a hobby. It's not fun. It is work. As I said earlier and will do so again ALL R&D IS PAID FOR BY THE CUSTOMER. One way or the other. The only people who give away free crap is the government, and that is because they took it from someone else first.
[Re: SpareParts]
#1856745
06/25/15 04:27 PM
06/25/15 04:27 PM
an8sec70cuda
[Re: madscientist]
#1856752
06/25/15 04:38 PM
06/25/15 04:38 PM
Thumperdart
State of confusion
The "low priority for at cost parts" thing is BS, nobody put a gun to your head you offered that. Shouldn't penalize the customer based on your offer. Who says it was murdered? That's not right. It stuck a valve and the OP says the oil pressure is low. Time to put on our big boy pants and take emotion out of it. It's possible the stuck valve was customer induced. And if I'm doing something at cost, and doing the R&D on it, I damn sure ain't moving your stuff to the front while profit making customers wait. MM is in business to MAKE MONEY. This isn't a hobby. It's not fun. It is work. As I said earlier and will do so again ALL R&D IS PAID FOR BY THE CUSTOMER. One way or the other. The only people who give away free crap is the government, and that is because they took it from someone else first. I like the way you think man..................
[Re: Thumperdart]
#1856760
06/25/15 04:50 PM
06/25/15 04:50 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
it could be one bad a$$ 87 octane motor when fixed
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: madscientist]
#1856777
06/25/15 05:04 PM
06/25/15 05:04 PM
Posts: 289 Lowes
steve660
Lowes
Mike @MM
This clears up some of it, as was pointed out by camastomcat and Monte (and others) 22k is on the light side for something of that nature. As for the stuck vale, I know of 3 issues that can cause it. Obviously, one of them is too little clearance. Closely related to that is when a supplier changes materiel and it requires more clearance than the SAME part number did before. Some brands of guide that I use/have used get no less the .0025 on the intake and .0035 on the exhaust. I always hone bronze guides as reaming them is a PITA, and sometimes they are not very round. The third thing is a common one that comes around from time to time. It's caused by myth and old wives tales. When starting an engine, I would rather see too much timing than not enough. To some, that is counter intuative. They think you need to "break in" an engine so dial everything down and back, when in reality, the only thing that needs a break in period is a HFT or SFT cam. Anything else is bull crap. When you run the timing retarded, the EGT's go through the roof. Then the valve has to deal with all the heat. When it can't, the stem grows larger than the clearance and it grabs a guide. It won't matter if it has .005 on it. As for the oil pressure issue, the OP has not yet stated what the oil pressure is, what filter he used or the brand and grade of oil. If you did what you say you did, and your offer stands, then the rest of it is on the OP. I would like to see stem diameters, guide diameters, crank dimensions and housing bore measurements posted. If the numbers are posted the math is simple enough but I would think .0028-.0032 on the rods (ASSuming Chrysler rod throws...take about .0003 off for BBC throws) and .0035-.0035 on the mains. Much tighter than that and you can grab a bearing. Tha is, of course, my opinon. Others may think otherwise. Ask MM for the dimensions and clearances.
[Re: MuscleMike]
#1856789
06/25/15 05:13 PM
06/25/15 05:13 PM
Posts: 289 Lowes
steve660
Lowes
Mike @MM
Mike, why would I send it back now, you had 11 months to "make it right." You had your chance..All I wanted was a mechanically sound engine. I offered to send it back to you, just give me a refund. So far you have refused.
Giving me a discount doesn't mean much when engine is poorly assembled. Its basic engine building, not rocket science. Was it a developmental deal to figure out cylinder pressure? How about oil control? Checking guide clearances?? You never said anything about this being a developmental deal and that the heads were not a #1 priority. If you had , why did you tell me I'd have the engine in 2 months?
[Re: steve660]
#1856802
06/25/15 05:32 PM
06/25/15 05:32 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
If Muscle Motors is willing to stand behind the problem that the OP thinks he has I can't think of any reason not to have them go through the engine again. What's he got to loose, he's not doing anything with the engine anyway. It's not like he gave them a special engine that went to a rare car that can't be replaced. It was a pieced together POS or was that pso.
[Re: rowin4]
#1856809
06/25/15 05:45 PM
06/25/15 05:45 PM
Posts: 289 Lowes
steve660
Lowes
If Muscle Motors is willing to stand behind the problem that the OP thinks he has I can't think of any reason not to have them go through the engine again. What's he got to loose, he's not doing anything with the engine anyway. It's not like he gave them a special engine that went to a rare car that can't be replaced. It was a pieced together POS or was that pso. If i did send it to them they would find something to charge me for and if i dont pay they got the engine...thats what i have to lose. And i dont know if what they repair would be the right way.
[Re: steve660]
#1856812
06/25/15 05:53 PM
06/25/15 05:53 PM
Posts: 19,377 Las Vegas
Al_Alguire
Las Vegas
So basically you are unwilling to give them a chance t make things right at all based on past dealings. We have to respect your opinion on that. But you are assuming they will hold the engine for "ransom" to bilk you for more money. I can also understand why you want a "refund" but in this business that is pie in the sky thinking honestly. Not saying you were not treated correctly but not allowing them to fix the situation when they apparently have offered IMO is a mistake.
[Re: steve660]
#1856814
06/25/15 05:56 PM
06/25/15 05:56 PM
Al_Alguire
Las Vegas
As for using a "mopoar" shop thing, this is something I will NEVER understand. Round is round, square is square. Any GOOD shop can produce a quality power making piece, it is not about the make it is about knowledge. I for one have seen some stuff from "mopar" shops that was not done very well at all. Personally I use the best I can afford to do my stuff.
[Re: Al_Alguire]
#1856830
06/25/15 06:07 PM
06/25/15 06:07 PM
Posts: 289 Lowes
steve660
Lowes
So basically you are unwilling to give them a chance t make things right at all based on past dealings. We have to respect your opinion on that. But you are assuming they will hold the engine for "ransom" to bilk you for more money. I can also understand why you want a "refund" but in this business that is pie in the sky thinking honestly. Not saying you were not treated correctly but not allowing them to fix the situation when they apparently have offered IMO is a mistake. I understand what your saying but, they had their "chance." My decision is not solely based on MY experience but ALL the others who have told me nightmare stories from MM. Havent heard one bad story about Best Machine though. Heres my offer, I will have it repaired locally and MM can reimburse me.
[Re: steve660]
#1856858
06/25/15 06:44 PM
06/25/15 06:44 PM
madscientist
Washington
So basically you are unwilling to give them a chance t make things right at all based on past dealings. We have to respect your opinion on that. But you are assuming they will hold the engine for "ransom" to bilk you for more money. I can also understand why you want a "refund" but in this business that is pie in the sky thinking honestly. Not saying you were not treated correctly but not allowing them to fix the situation when they apparently have offered IMO is a mistake. I understand what your saying but, they had their "chance." My decision is not solely based on MY experience but ALL the others who have told me nightmare stories from MM. Havent heard one bad story about Best Machine though. Heres my offer, I will have it repaired locally and MM can reimburse me. I can tell you that I wouldn't refund the money either. And I wouldn't pay you to have someone else go through it. I say that because most engine builders think their [censored] don't stink and their way is the only way. Doesn't make MM right or wrong. It's hard for me to believe that MM is as incompetent as is portrayed here. That would mean that the guys at MM can't even read a micrometer. I don't even think that for a nano second. You keep saying that the oil pressure was low. What was the oil pressure? What oil and grade did MM use on the dyno? Did you ask them what oil to run? What oil and filter did you use, as that has a huge effect on pressure. As for the stuck valve, that can happen to anyone. I find it hard to believe that MM didn't size the guides. I would suspect a slow timing issue. I couldn't care less what MM says the clearances are. You seem like a pretty sharp guy. Take it apart and measure them yourself. Then post what you have. Unless you have the correct dial bore gauge it will be hard to measure the ID of the guide but some shop near you could do that. MM has already publically stated they would fix it for free. Print a copy and let them fix it. If they hold the engine for ransom you would have an easy court case. EDIT: just re-read the OP and he is saying 15-20 psi oil pressure at 1200 RPM. To some, that is not low. For me, it's too low.But that still doesn't say if the oil was too thin or the oil filter was junk. Both of those will cause low oil pressure.
[Re: steve660]
#1856868
06/25/15 06:48 PM
06/25/15 06:48 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
I understand your apprehension, But Id give them one more chance. Im sure they will get it right this time, their in the spotlight. Get it in writing that they wont hold your motor hostage for more money, unless its something YOU want to add.
JMO , and I also understand your frustation at this point. We all want it done right the first time, but that doesn't always happen with any shop IMO. These engines can all have their issues, from any shop.
Letting them fix it is Your best bet, IMO
[Re: steve660]
#1856885
06/25/15 07:07 PM
06/25/15 07:07 PM
Al_Alguire
Las Vegas
Well trust me I have seen bad stuff from all of the shops listed here. Don't feel that ANYONE is immune believe me. Having been in and around the business for a long time you are not gonna find anyone that will pay for someone else to "repair" the motor and likely will not find many that would be willing to refund the money either. Most people and courts would see the offer being made by the builder and would leave the ball in your court. Don't get me wrong I understand your frustration and frankly can see you did not have a ton of experience at this kind of thing. As pointed out $21Kis dirt cheap for something like that. I usually have in excess of that in parts for something that will make 4 digit power. Juts saying not trying to bash at all BTW and way off topic but been in North Carolina this week and seems like a nice state to be from. Been downing Cheerwine as fast as I can find it
[Re: Sport440]
#1856895
06/25/15 07:15 PM
06/25/15 07:15 PM
crabman173
crabman173
I understand your apprehension, But Id give them one more chance. Im sure they will get it right this time, their in the spotlight. Get it in writing that they wont hold your motor hostage for more money, unless its something YOU want to add. JMO , and I also understand your anger at this point. You never know until you get a look at it when they come back. I know of another big name shop--sent out a $30K Mopar that dynoed like a champ! Customer complains about this and that poor ET etc--the old--"It just don't run like it should" Builder pays to get it back--AFTER over a year of phone work etc--engine comes in and on teardown-- Thrust ate out of it from converter hub and issues, pushrods bent, on and on and on--a half dozen UN-related issues all done at intervels over the months--None ever addressed--just kept on running it down the strip and complaining. That customer had zero idea about a race car, race engine, or any other thing--they were clueless--so....that unit will not be repaired until customer agrees to pay in full for not knowing what the heck he was doing and damaging a truly great unit. The kicker was that the throttle "linkage" only opened the blades about half way--good speed secret there So.....It ain't always the builder boys and...it ain't always the customer either but.....every tale spread out online in a way as this is always fishy to me--NOT the way to handle issues. I have always aimed to do right but if ever the issues are flashed online like this I usually just walk away. I bet MM will take another swipe at it --but that making promises before looking at it is a non starter for our shop. Retarded timing at fire up is an engine KILLER
[Re: steve660]
#1856898
06/25/15 07:18 PM
06/25/15 07:18 PM
Posts: 4,209 New York
polyspheric
New York
X2 Seen this happen with cars and bikes for 50 years. Not addressing MM specifically, but in the past once a shop has the engine back, the clock stops - it won't get any work unless they stop booking new work - the same reason it didn't get done on time. They'll find something wrong that's your fault and you have to ransom the engine back.
I noticed that MM's remarks didn't address all the issues you raised - like 150 psi at 12:1 CR...
Boffin Emeritus
[Re: steve660]
#1856899
06/25/15 07:18 PM
06/25/15 07:18 PM
Posts: 984 San Diego CA
65 Hemi
San Diego CA
It's a shame that bad news travel so fast when there are so many variables in performance motors. I would buy it and have it fixed if I didn't have so many motors already. I have a hemi built by Muscle motor and a wedge built by Best machine and a couple of others that are all good motors. Things can happen to any of these motor due to the variables. Most the time with any of these reputable builder they are fine when the leave. I would sure HATE to be a builder and have somebody put a motor in their car with the issues that can arise like oil, filter, timing, fuel, fuel systems, crank thrust from spacing the convertor wrong and so on!
Doug
MOPAR or NO CAR!!! 1965 Dodge Coronet soon a 6.1 Hemi with a Magnson blower 810 hp on pump gas 1964 Dodge Polara 582" Indy alum Block 426-1RA heads, 1933 Plymouth PE all Steel, LT1 4L60E 1959 Plymouth Savoy 33,000 mile survivor Old cars are never done. They are ongoing projects!
[Re: steve660]
#1856900
06/25/15 07:20 PM
06/25/15 07:20 PM
Al_Alguire
Las Vegas
Guess the point is the motor had less oil pressure than you think it should have, but was that something talked about during the build? I agree I might want a bit more but that does not mean necessarily it is bad. I do agree the valve issue certainly needs fixing, should not have happened but perhaps it is something that got overlooked, or could be a parts issue. Assuming you have not had it torn down to determine the exact cause of course, as I did not see that it had been. But you yourself admit you have not run it at all much really, and while we can all speculate and be skeptical about the power numbers is made you do not have anything to show different. Just trying to play a little devils advocate here..
[Re: steve660]
#1856938
06/25/15 07:50 PM
06/25/15 07:50 PM
Posts: 791 Bama
Randy..
Bama
[Re: steve660]
#1856940
06/25/15 07:52 PM
06/25/15 07:52 PM
Al_Alguire
Las Vegas
I have no dog in this fight at all but I don't know what else Mike and MM can do to try and make this right honestly.
[Re: steve660]
#1856975
06/25/15 08:51 PM
06/25/15 08:51 PM
B3422W5
Portage,michigan
I definately sympathize with the OP feeling uncomfortable with sending the motor back to someone who displayed shoddy workmanship and created the problem in the first place. It's always much more respectable to do the right thing the first time, until having to when peer pressure forces your hand. Kinda like having a dentist appointment to get a tooth pulled that is bad and they pull the wrong one, novocaine wears off at home and you notice you still have the toothache...... You probably go to another dentist next time.
[Re: rickraw]
#1856987
06/25/15 09:04 PM
06/25/15 09:04 PM
Posts: 13,603 md
mopars4ever
md
I definately sympathize with the OP feeling uncomfortable with sending the motor back to someone who displayed shoddy workmanship and created the problem in the first place. It's always much more respectable to do the right thing the first time, until having to when peer pressure forces your hand. Kinda like having a dentist appointment to get a tooth pulled that is bad and they pull the wrong one, novocaine wears off at home and you notice you still have the toothache...... You probably go to another dentist next time. I agree plus your not talking about a couple bucks here. That is a lot of money in my book for it not to be done correctly the first time. Trust is a major issue here from what I see.
[Re: rickraw]
#1857011
06/25/15 09:28 PM
06/25/15 09:28 PM
Posts: 653 Fredericksburg Va
plycuda
Fredericksburg Va
Now that is what I call standing up. Way to go Mike. If the op doesn't take that offer, hate to say it, he is an a-hole. well they did a predator head motor for me that couldn't fall out of a tree. the back yard mechanic of me tore it down and found the valves hitting the pistons and the pistons hitting the head. after alot of help from boat racer I had some one else notch the pistons and cutting them for clearance on the head. put it back together myself and it picked up 6 miles an hour in the 1/8. mike offered for me to send it back but after everything I had been through just to get it hell no they had there chance. I had bought a ton of stuff through them before this.
[Re: steve660]
#1857123
06/25/15 11:17 PM
06/25/15 11:17 PM
Monte_Smith
North Alabama
There is not an engine builder alive, that hasn't at one time or another, let something slip through the cracks........... So let them fix it for free and move on, or don't, then take a huge loss parting it out, or PAY someone else to fix it. Seems to be your choices. I think I would try the FREE one first.
Stuff happens. I built a motor for a member on this board. Took me WAY too long to get it done, but when it was, I ran it on the dyno and it make good power, was sealed up good, made good vacumn, no blowby. He gets it in the car, makes a few passes and it is oiling a plug....BAD. Checks the usual things, so we narrow it to the rings. I send him some rings for that hole, puts it back together, no change. Now by this time, he is pretty darned upset with me. I offered to have it shipped down at my cost and have a look, but he elects to have somebody else look at it. I tell him, if it is something I did wrong, we will TALK about the bill, but I won't guarantee anything...........Well turns out the head developed a crack where it was ported so thin, by another VERY well known and VERY respected Mopar guy on a previous build and was oiling the cylinder. So as I said, ANYTHING can happen to ANYBODY.
[Re: MuscleMike]
#1857141
06/25/15 11:31 PM
06/25/15 11:31 PM
Posts: 289 Lowes
steve660
Lowes
All I want is for Mr. Edwards to be enjoying his car. That being said, you don't buy something from Home Depot, have an issue and take it to Lowes to have it fixed and send Home Depot the bill. Obviously We are under a micro scope and it is in our best interest to bring this situation to a speedy conclusion. For the record: I, Michael Ware, owner of Muscle Motors will bring the engine back here, replace the bent valve, verify and adjust guide clearance if necessary.
I suspect that the lifters may have excessive clearance causieng the low oil pressure at idle. We will completely disassemble the engine and using a BHJ fixture install lifter bushings and hone for correct sizing again no charge. Mr Edwards also wanted a different type of retainer, We will change those at no cost to Mr Edwards. We will then have the engine shipped back to Mr Edwards and we will absorb the shipping charges. I believe this a fair and amicable offer. Mike, Im very apprehensive about this but I will give your offer some thought. If you bush lifter bores it will also require diff pushrods without restricters. I would also like to know how you will address the low cylinder pressure issue. My thinking is to spec out a custom cam. I've used Scott Brown before and know he's really good at pump gas cams.
[Re: B3422W5]
#1857154
06/25/15 11:42 PM
06/25/15 11:42 PM
Posts: 18,425 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
I definately sympathize with the OP feeling uncomfortable with sending the motor back to someone who displayed shoddy workmanship and created the problem in the first place. It's always much more respectable to do the right thing the first time, until having to when peer pressure forces your hand. Kinda like having a dentist appointment to get a tooth pulled that is bad and they pull the wrong one, novocaine wears off at home and you notice you still have the toothache...... You probably go to another dentist next time. No worse than selling someone a car that is not 100% to their expectations. You offer for them to bring it back so you can determine what the issues are and they have already decided the trust is not there.
[Re: steve660]
#1857202
06/26/15 01:12 AM
06/26/15 01:12 AM
Monte_Smith
North Alabama
I suspect that the lifters may have excessive clearance causieng the low oil pressure at idle. We will completely disassemble the engine and using a BHJ fixture install lifter bushings and hone for correct sizing again no charge. Mr Edwards also wanted a different type of retainer, We will change those at no cost to Mr Edwards. We will then have the engine shipped back to Mr Edwards and we will absorb the shipping charges. I believe this a fair and amicable offer. Mike, Im very apprehensive about this but I will give your offer some thought. If you bush lifter bores it will also require diff pushrods without restricters. I would also like to know how you will address the low cylinder pressure issue. My thinking is to spec out a custom cam. I've used Scott Brown before and know he's really good at pump gas cams. I'm not sure why you seem so concerned about the cylinder pressure issue. Not sure where you think it needs to be, but this is a big motor, with a very efficient head, that is going to run on pump gas. Lots of pumping pounds will NOT be your friend
[Re: steve660]
#1857236
06/26/15 03:35 AM
06/26/15 03:35 AM
Posts: 3,245 Between a rock & a hard place
cudadoug
I suspect that the lifters may have excessive clearance causieng the low oil pressure at idle. We will completely disassemble the engine and using a BHJ fixture install lifter bushings and hone for correct sizing again no charge. Mr Edwards also wanted a different type of retainer, We will change those at no cost to Mr Edwards. We will then have the engine shipped back to Mr Edwards and we will absorb the shipping charges. I believe this a fair and amicable offer. Mike, Im very apprehensive about this but I will give your offer some thought. If you bush lifter bores it will also require diff pushrods without restricters. I would also like to know how you will address the low cylinder pressure issue. My thinking is to spec out a custom cam. I've used Scott Brown before and know he's really good at pump gas cams. Then you're continuing to be part of the problem, not the solution. The owner of the shop has agreed to fix the issues at his cost, and I'm sorry...but it doesn't get any better than that. Guess what? EVERY engine builder has had something not turn out they way they wanted. It take a true, dedicated business man to stand behind his build which is appears what's going on here. Put your man-pants on and WORK WITH THE OFFER TO FIND THE SOLUTION. Better than bashing a well established shop who HAS OFFERED TO FIX IT. PS: Being that you're NOT an engine builder why do you care about cylinder pressure as long as it's a solid motor and makes the power?? Sounds like you're continuing to LOOK FOR "issues". If "your thinking is to spec a custom cam", then maybe you should have "been thinking" to build it yourself. Right?
Re: MUSCLE MOTORS 30 MIN ENGINE
[Re: cudadoug]
#1857271
06/26/15 09:30 AM
06/26/15 09:30 AM
Posts: 159 australia
charger410
australia
I suspect that the lifters may have excessive clearance causieng the low oil pressure at idle. We will completely disassemble the engine and using a BHJ fixture install lifter bushings and hone for correct sizing again no charge. Mr Edwards also wanted a different type of retainer, We will change those at no cost to Mr Edwards. We will then have the engine shipped back to Mr Edwards and we will absorb the shipping charges. I believe this a fair and amicable offer. Mike, Im very apprehensive about this but I will give your offer some thought. If you bush lifter bores it will also require diff pushrods without restricters. I would also like to know how you will address the low cylinder pressure issue. My thinking is to spec out a custom cam. I've used Scott Brown before and know he's really good at pump gas cams. Then you're continuing to be part of the problem, not the solution. The owner of the shop has agreed to fix the issues at his cost, and I'm sorry...but it doesn't get any better than that. Guess what? EVERY engine builder has had something not turn out they way they wanted. It take a true, dedicated business man to stand behind his build which is appears what's going on here. Put your man-pants on and WORK WITH THE OFFER TO FIND THE SOLUTION. Better than bashing a well established shop who HAS OFFERED TO FIX IT. PS: Being that you're NOT an engine builder why do you care about cylinder pressure as long as it's a solid motor and makes the power?? Sounds like you're continuing to LOOK FOR "issues". If "your thinking is to spec a custom cam", then maybe you should have "been thinking" to build it yourself. Right? I agree
Peter. Australian Charger, alloy block injected 410in, w9 na 9.03@148 leafs 3000lb
1967 barracuda 605 hemi Stage5 millennium 8.2@170
[Re: charger410]
#1857284
06/26/15 10:13 AM
06/26/15 10:13 AM
Posts: 1,845 Tampa
DusterDave
Tampa
If I were steve660, I'd bring this public discussion to a close, and deal with MM on a one to one basis. There's nothing more to be gained by playing out this saga publicly.
Gone to the dark side with an LS3 powered '57 Chevy 210
[Re: DusterDave]
#1857292
06/26/15 10:39 AM
06/26/15 10:39 AM
gregsdart
If I were steve660, I'd bring this public discussion to a close, and deal with MM on a one to one basis. There's nothing more to be gained by playing out this saga publicly. I originally posted to send it to Best or another Mopar shop, but after reading Mikes response you have to give him a chance to fix it. This is his bread and butter hear, not some used car deal that went sour. Also diagnosing what is wrong with a big project like this isn't easy. There may be many things a novice misses that an experienced engine builder would know. As far as the time line, a custom engine is always going to be hard to deliver on time, and almost never on budget. OP, good luck with this deal, and I hope it turns out the best for both.
[Re: steve660]
#1857300
06/26/15 10:52 AM
06/26/15 10:52 AM
Posts: 2,422 Pittsburgh PA
Eric
Pittsburgh PA
You have nothing to lose in sending it back at this point. The laundry has been aired and if the results aren't right everyone will know. I'm sure Mike will take extra care to make sure it goes out right this time. If it does'nt it's obvious to him he will lose some future business.
5.53 @ 125 1/8th on the launch control..more left in her!
[Re: Eric]
#1857314
06/26/15 11:17 AM
06/26/15 11:17 AM
Posts: 20,188 PA.
pittsburghracer
"Little"John
"Little"John
PA.
You have nothing to lose in sending it back at this point. The laundry has been aired and if the results aren't right everyone will know. I'm sure Mike will take extra care to make sure it goes out right this time. If it does'nt it's obvious to him he will lose some future business. I agree 100%. He threw a very nice offer out there in writing for all to see. Go for it.
#1857380
06/26/15 01:23 PM
06/26/15 01:23 PM
skicker
"The Champ"
"The Champ"
Western Md.
There's not too many shops in this day and age who will make the offer that's been given. It's ultimately your decision alone...but I personally have never thought that "burning bridges" is a good message to send to the next shop you may want to work with...
...FAFO...
#1857384
06/26/15 01:30 PM
06/26/15 01:30 PM
Posts: 289 Lowes
steve660
Lowes
I will give MM the opportunity to make things right. Once I get it back I will let everyone know the results.
As far as the comments regarding cylinder pressure goes, Mike is the one that told me that 150 was lower than what he anticipated. That's why I mentioned it.
PSO headed 632 from MM. Cracked cylinder, loose valve seats, low oil pressure, low cylinder pressure. ..... Now its a door stop....
[Re: steve660]
#1857385
06/26/15 01:34 PM
06/26/15 01:34 PM
madscientist
Washington
Good decision on your part. Give them the same shot you would expect if you made a mistake. BTW...did MM provide a build sheet with the engine? If so, it would have all the measurements and dimensions on it. Just curious.
[Re: madscientist]
#1857440
06/26/15 03:18 PM
06/26/15 03:18 PM
Posts: 289 Lowes
steve660
Lowes
Good decision on your part. Give them the same shot you would expect if you made a mistake. BTW...did MM provide a build sheet with the engine? If so, it would have all the measurements and dimensions on it. Just curious. PM SENT......
[Re: madscientist]
#1857619
06/26/15 07:53 PM
06/26/15 07:53 PM
Quicktree
Good decision on your part. Give them the same shot you would expect if you made a mistake. BTW...did MM provide a build sheet with the engine? If so, it would have all the measurements and dimensions on it. Just curious. that depends on how long he takes to get his motor back to him and if he tries any additional charges and how well he takes care of the issues. this could turn into another motor prison...
[Re: steve660]
#1858034
06/27/15 10:53 AM
06/27/15 10:53 AM
polyspheric
New York
A 12:1 motor with good ring seal needs the intake closing way up in the 80's ABDC to show 150 psi on a gauge,
Does it?
Boffin Emeritus
[Re: polyspheric]
#1858101
06/27/15 01:00 PM
06/27/15 01:00 PM
Posts: 289 Lowes
steve660
Lowes
quote=polyspheric]A 12:1 motor with good ring seal needs the intake closing way up in the 80's ABDC to show 150 psi on a gauge,
Does it? [/quote]
Cam card shows:
IO @ 31.5
IC@ 71.5
EO@ 85.5
EC@ 29.5
[Re: steve660]
#1858153
06/27/15 02:23 PM
06/27/15 02:23 PM
HotRodDave
Kalispell Mt.
Is that at .050?
Is it installed that was or advanced or retarded?
[Re: HotRodDave]
#1858201
06/27/15 03:28 PM
06/27/15 03:28 PM
Posts: 289 Lowes
steve660
Lowes
Is that at .050?
Is it installed that was or advanced or retarded? Yes, That's at .050. I'm not sure how MM installed it. I was going to check how it was installed and If it was installed straight up I was going to try advancing it to increase cylinder pressure. I will be pulling engine next week and get it ready to return to MM.
[Re: steve660]
#1858317
06/27/15 07:13 PM
06/27/15 07:13 PM
Sport440
Canton, Ohio
Is that at .050?
Is it installed that was or advanced or retarded? Yes, That's at .050. I'm not sure how MM installed it. I was going to check how it was installed and If it was installed straight up I was going to try advancing it to increase cylinder pressure. I will be pulling engine next week and get it ready to return to MM. If your correct on your specs your @ 4* advanced installed at a 110 ICL with a 114 LSA cam with a intake duration of 283 @ .050 and a exhaust duration of 295 @ .050
[Re: Sport440]
#1858687
06/28/15 03:31 AM
06/28/15 03:31 AM
Posts: 289 Lowes
steve660
Lowes
Is that at .050?
Is it installed that was or advanced or retarded? Yes, That's at .050. I'm not sure how MM installed it. I was going to check how it was installed and If it was installed straight up I was going to try advancing it to increase cylinder pressure. I will be pulling engine next week and get it ready to return to MM. If your correct on your specs your @ 4* advanced installed at a 110 ICL with a 114 LSA cam with a intake duration of 283 @ .050 and a exhaust duration of 295 @ .050 Yes. Cam card reads .050 duration at 283/295 on a 114 LSA installed at 110 . Duration at .020 is 314/330.
[Re: steve660]
#1858697
06/28/15 05:42 AM
06/28/15 05:42 AM
EJ440
[Re: MuscleMike]
#1932081
10/14/15 04:08 PM
10/14/15 04:08 PM
Posts: 289 Lowes
steve660
Lowes
I suspect that the lifters may have excessive clearance causieng the low oil pressure at idle. We will completely disassemble the engine and using a BHJ fixture install lifter bushings and hone for correct sizing again no charge. Mr Edwards also wanted a different type of retainer, We will change those at no cost to Mr Edwards. We will then have the engine shipped back to Mr Edwards and we will absorb the shipping charges. I believe this a fair and amicable offer. UPDATE...MM recieved engine early July and as of Oct 14th still have it . So much for a speedy conclusion... Heres what we agreed on doing / have corrected. Replace Retainers Repair dropped valve seat and inspect heads New cam, hoping to increase cylinder pressure Replace REV valves with Ferrera ( my choice and I will pay for) Bush and hone lifter bores to fit Endura X lifters ( my choice and I will pay for) Reassemble and dyno
[Re: steve660]
#1932119
10/14/15 05:04 PM
10/14/15 05:04 PM
Posts: 20,188 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I suspect that the lifters may have excessive clearance causieng the low oil pressure at idle. We will completely disassemble the engine and using a BHJ fixture install lifter bushings and hone for correct sizing again no charge. Mr Edwards also wanted a different type of retainer, We will change those at no cost to Mr Edwards. We will then have the engine shipped back to Mr Edwards and we will absorb the shipping charges. I believe this a fair and amicable offer. UPDATE...MM recieved engine early July and as of Oct 14th still have it . So much for a speedy conclusion... WOW!!!!!!!!!!! This is just a plan crazy amount of of time for an issue someone wants to get off the books. This may be apples to oranges in comparison but went I build a 8-9 second drag race engine my local machine shop has the block for 7-10 days max (sometimes quicker) and it takes me approximately 3 days to check all clearances, file fit rings, degree in the cam, assemble the short block, and set up the heads and finish the block. And I'm a one man shop doing it for enjoyment. Get the man his engine back as this is really making you and your business look BAD.
[Re: steve660]
#1932122
10/14/15 05:16 PM
10/14/15 05:16 PM
HotRodDave
Kalispell Mt.
My local machine shop has had my stuff nearly a year, I did finally get the block back now just waiting on the crank. I have rarely seen any machine shop get stuff done when they are supposed, almost never is anything done quickly.
[Re: steve660]
#1932174
10/14/15 07:01 PM
10/14/15 07:01 PM
an8sec70cuda
That is ridiculous Steve. You would think Muscle Motors would want to resolve this quickly and try to make you happy. Hope you can get your stuff back and it is in decent enough shape to at least have some fun w/ it. Then, when you recover financially, you can let a shop that knows what they're doing go through it.
[Re: HotRodDave]
#1932175
10/14/15 07:03 PM
10/14/15 07:03 PM
Posts: 4,693 Wichita
GY3
Wichita
My local machine shop has had my stuff nearly a year, I did finally get the block back now just waiting on the crank. I have rarely seen any machine shop get stuff done when they are supposed, almost never is anything done quickly. Wow! Makes me happy with my machinist! Smith Machine here in Wichita had my stuff for less than a month and that included a week lost due to a vendor sending the wrong crank. He hot tanked, bead blasted, decked, bored, align honed the mains and balanced the rotating assembly in less than 3 weeks. On top of all that he is meticulous in his prep and made sure I knew a few nuances and how to handle them.
[Re: steve660]
#1932177
10/14/15 07:05 PM
10/14/15 07:05 PM
Triple Threat
Renton Washington
I suspect that the lifters may have excessive clearance causieng the low oil pressure at idle. We will completely disassemble the engine and using a BHJ fixture install lifter bushings and hone for correct sizing again no charge. Mr Edwards also wanted a different type of retainer, We will change those at no cost to Mr Edwards. We will then have the engine shipped back to Mr Edwards and we will absorb the shipping charges. I believe this a fair and amicable offer. UPDATE...MM recieved engine early July and as of Oct 14th still have it . So much for a speedy conclusion... WOW, That's unacceptable.
[Re: an8sec70cuda]
#1932179
10/14/15 07:09 PM
10/14/15 07:09 PM
Posts: 289 Lowes
steve660
Lowes
Miracusley, 2 hours after my update i get this..
Everythings ok...Eric and dyno guy have been sick with the flu and are here now and will be making pulls shortly.
[Re: steve660]
#1932193
10/14/15 07:41 PM
10/14/15 07:41 PM
Posts: 6,906 IL, Aurora
ademon
IL, Aurora
Ask for a video or fly out there to see this engine going through the paces on the dyno!! I would want to see it on that dyno for a solid hour at various rpm's and idle before I accept it.
[Re: fullmetaljacket]
#1932209
10/14/15 08:14 PM
10/14/15 08:14 PM
Posts: 289 Lowes
steve660
Lowes
No excuses and a FLU that lasted three months? PPPPPPPPPlllllllllllleeeeeeease.
They haven't had the flu for 3 months. Engine was on dyno but HP and TQ nose dived with new cam. Was suppose to be back on dyno last Friday with old cam. Still, too long.... Maybe all is happy now and it will be ready to ship.
[Re: steve660]
#1932721
10/15/15 05:57 PM
10/15/15 05:57 PM
polyspheric
New York
and the dog ate my homework.
They're busy filling orders that came in AFTER your engine arrived.
Boffin Emeritus
[Re: ccdave]
#1934423
10/18/15 07:12 PM
10/18/15 07:12 PM
Thumperdart
State of confusion
This is why I build my own motors. I only have myself to blame when things go south. DITTO..........
[Re: steve660]
#1934437
10/18/15 07:42 PM
10/18/15 07:42 PM
polyspheric
New York
Someone we all know and love, but whose permission I don't have to identify him, had MM build a mild stroker B short block decades ago. In assembling the engine, it won't turn over.
The rods hit the block...
During the last stages of MM's work not one person tried to rotate the engine. Does that tell you something?
All the previous post were correct - every shop has a bad day, myself included. Now, explain this one?
Boffin Emeritus
[Re: B5 Bee]
#1934463
10/18/15 08:28 PM
10/18/15 08:28 PM
Eric
Pittsburgh PA
I don't buy this story. How do you assemble an engine and not rotate it? Definitely not BGR but my last mill came to me that way. The rod exited on the fifth pass. I thought it was tight but I figured he does this for a living....silly me.
[Re: steve660]
#1934999
10/19/15 04:18 PM
10/19/15 04:18 PM
polyspheric
New York
Sorry, should have been more clear. IIRC he got the assembled short block, and in the process of buttoning it up he discovered it won't make a full turn.
Boffin Emeritus
[Re: steve660]
#1935377
10/20/15 02:13 AM
10/20/15 02:13 AM
polyspheric
New York
Of course, you're too clever for me, I made the whole thing up.
Let me unravel this: you don't understand how it happened, therefore I'm lying?
Boffin Emeritus
[Re: polyspheric]
#1935544
10/20/15 02:05 PM
10/20/15 02:05 PM
Monte_Smith
North Alabama
Sorry, should have been more clear. IIRC he got the assembled short block, and in the process of buttoning it up he discovered it won't make a full turn. Seems the shortblock was assembled............but you never know for sure with some of his posts, as he seems to just want to send out clever remarks and cryptic comments at times instead of real information.
[Re: Monte_Smith]
#1935568
10/20/15 02:49 PM
10/20/15 02:49 PM
BradH
I just asked how you put 8 rod and piston assemblies in a motor and not turn it over... Still a legit question to ask, since I don't know how either.
[Re: steve660]
#1935715
10/20/15 06:47 PM
10/20/15 06:47 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
On my Gen III I got all the way to put #7 and #8 in when I found out the block needed clearancing under the #8 hole to clear the #7 rod cap. Had to go all the way back apart, make the clearance, then get it re-hot tanked and re-painted. Small price to pay for an education.
Mopar to the bone!!!
[Re: DusterDave]
#1935720
10/20/15 07:04 PM
10/20/15 07:04 PM
Posts: 75,070 U.S.S.A.
JohnRR
U.S.S.A.
If I were steve660, I'd bring this public discussion to a close, and deal with MM on a one to one basis. There's nothing more to be gained by playing out this saga publicly. Sure there is , the MOPARTS DOGPILE gets to continue ...
[Re: JohnRR]
#1935756
10/20/15 07:53 PM
10/20/15 07:53 PM
Posts: 1,145 Arizona, USA
gsmopar
Arizona, USA
If I were steve660, I'd bring this public discussion to a close, and deal with MM on a one to one basis. There's nothing more to be gained by playing out this saga publicly. Sure there is , the MOPARTS DOGPILE gets to continue ... I'd like to see it stay open and regular updates on the progress. I have a nice size down payment at MM on a pump gas hemi that should be done early next year. Hopefully my experience is better than the OPs.
[Re: DusterDave]
#1935765
10/20/15 08:11 PM
10/20/15 08:11 PM
Quicktree
If I were steve660, I'd bring this public discussion to a close, and deal with MM on a one to one basis. There's nothing more to be gained by playing out this saga publicly. if he hadn't started this post he would probably be still dealing with a motor he can't use. so hopefully it will inspire them to get done. if one on one would accomplish anything we probably wouldn't be seeing this at all....
[Re: JohnRR]
#1935767
10/20/15 08:13 PM
10/20/15 08:13 PM
Posts: 289 Lowes
steve660
Lowes
If I were steve660, I'd bring this public discussion to a close, and deal with MM on a one to one basis. There's nothing more to be gained by playing out this saga publicly. Sure there is , the MOPARTS DOGPILE gets to continue ... This saga is my only documentation for MM to do what they said they would do. And for the record.... I AM, and HAVE been dealing with MM, on a one on one basis, SINCE EARLY JULY!! This build started April 2014...2014!!! This isn't YOUR engine, nor YOUR money were talking about. Its not Your time and energy put in trying to get YOUR car set up with new engine. Only to have to tear it back apart again, crate it, drop it off at trucking company and wait....then have to listen to excuse after excuse why its not done. Whenever I do get it back I will post on here letting everybody know. Then...I get to start putting it back together again.
[Re: gsmopar]
#1935808
10/20/15 09:27 PM
10/20/15 09:27 PM
Posts: 289 Lowes
steve660
Lowes
If I were steve660, I'd bring this public discussion to a close, and deal with MM on a one to one basis. There's nothing more to be gained by playing out this saga publicly. Sure there is , the MOPARTS DOGPILE gets to continue ... I'd like to see it stay open and regular updates on the progress. I have a nice size down payment at MM on a pump gas hemi that should be done early next year. Hopefully my experience is better than the OPs. Hey gsmopar, When did they start your build and what kind of a time line did they give you and is it on track to be completed on time?
[Re: steve660]
#1935810
10/20/15 09:32 PM
10/20/15 09:32 PM
Posts: 11,722 Portage,michigan
B3422W5
Portage,michigan
Kudo's to you Steve for bringing this up and letting people know. I am most always very complimentary regards vendors. In the case of Muscle Motors( and I live very close to them) I can honestly state from buddies and local racers who have used them, most all either know better or won't again. I have used two shops( both further, and much further) away.... Best Machine and Hensley racing, with great results and service after the sale. I intentionally avoided using Muscle Motors.
[Re: steve660]
#1935888
10/20/15 11:25 PM
10/20/15 11:25 PM
polyspheric
New York
Let's all keep in mind that there are (at least) 2 different grievances here: #1. how could you screw that up? Everyone has a bad day. The Joint Chiefs of Staff would be happy to have only screwed up once. There's an old saying in private aviation, "there are only 2 kinds of pilots, those who have landed with the wheels still up, and those who haven't done it yet". #2. when the damage is known, what did you do about it? This part is inexcusable.
Boffin Emeritus
[Re: steve660]
#1935930
10/21/15 01:04 AM
10/21/15 01:04 AM
gsmopar
Arizona, USA
I don't have anything to say positive or negative yet. They've been very helpful on the phone and have a size able down payment (hemi's aren't cheap). I asked for a longer build time to allow me to get into a new house (early next year). This is my first experience with paying someone to do an engine. Hopefully I don't get burned. Either way, you guys will get the pics and videos. With any luck I'll be a happy customer with a FAST Hemi at Drag Week 2017. I have a sabbatical that year (8-weeks paid time off). Do you think a bright orange Pro-Street '69 Charger will get much ink in HRM?
[Re: B3422W5]
#1936256
10/21/15 05:29 PM
10/21/15 05:29 PM
Thumperdart
State of confusion
Kudo's to you Steve for bringing this up and letting people know. I am most always very complimentary regards vendors. In the case of Muscle Motors( and I live very close to them) I can honestly state from buddies and local racers who have used them, most all either know better or won't again. I have used two shops( both further, and much further) away.... Best Machine and Hensley racing, with great results and service after the sale. I intentionally avoided using Muscle Motors. Man, this and these other post`s are sure to nail the coffin shut on any future sales on here for MM I would think.......
[Re: steve660]
#1936619
10/22/15 10:50 AM
10/22/15 10:50 AM
Posts: 10,220 Someplace you aren't
SomeCarGuy
This bs is still going on? C'mon. Fix the damn thing. Plenty enough time has passed. When you have a follow up, that person goes to the front, if you are a reputable business.
I want my fair share
[Re: steve660]
#1936839
10/22/15 05:29 PM
10/22/15 05:29 PM
Monte_Smith
North Alabama
There is not an engine builder out there, that has not had a thread similar to this, on the internet somewhere. I have seen Reher-Morrison, Sonny's, Schmidt, Shaffiroff and plenty of others, bashing threads. So regardless of what has been posted here, there is likely MORE to the story somewhere in the log pile.
As to the comments about THIS thread being the END of MM........hardly. They have been in business for a LONG time and there are WAY more people who have good things to say, than there are that bash them. Plus lots of bashers have zero personal experience. They may have read a thread like this, or have a buddy, who has a buddy, who has a cousin and he HEARD this from a friend of his. As a business, especially a racing oriented business, you will NEVER make EVERY person happy. It's just the nature of the business. Be it differences in vision, anticipated end results, money required.....whatever, it does NOT go as planned 100% of the time and somebody will not be happy.
Lots of people, me included, have used MM and never had the first complaint. Some haven't had good results.........This is a common trend in the industry and will continue. We see INDY bashing threads everyday.........they seem to be doing just fine and appear to be in no danger of having to lock the doors
[Re: Monte_Smith]
#1936874
10/22/15 06:33 PM
10/22/15 06:33 PM
gsmopar
Arizona, USA
Lots of people, me included, have used MM and never had the first complaint. Some haven't had good results.........This is a common trend in the industry and will continue. We see INDY bashing threads everyday.........they seem to be doing just fine and appear to be in no danger of having to lock the doors Thanks!
[Re: polyspheric]
#1936878
10/22/15 06:42 PM
10/22/15 06:42 PM
Posts: 4,457 Washington
madscientist
Washington
You don't need an attorney to draw up a contract (not a work order) that lists in detail every operation, every component, and delivery time. Specify time payments by date (not interval). Now add penalties for late delivery: X dollars for every day/week/month. It becomes binding when it is notarized as an "acknowledgement*" (in the manner required for a deed to be recorded, not sworn, not witnessed) by both parties. If it's a corporation it must include a statement that the signer had the authority to bind the corporation to contracts. What it does: it permits you to sue him for very specific damages (the penalties) rather than hair-pulling he-said-she-said about how much is worth what. When he lawyer sees this, he screams "what the fook is wrong with you!!!" It doesn't need to be filed with the Court, but most County Clerks will accept a copy for a small fee (it's $25. here), so his lawyer knows you're serious.
* I'm sorry to say that although all notaries and attorneys are required to know what this is, very few of them do. You can Google it and copy the language. Are you for real? I know you have way too much experience to post garbage like this. No one with the IQ of a grape fruit would EVER agree to this, because of all the variables in engine building, the number 1 variable being the CUSTOMER (pointing out that in no way was this a dig at Steve, the OP, as I have PM's him several times with my thoughts). Abosolutely rediculous.
[Re: steve660]
#1936967
10/22/15 09:40 PM
10/22/15 09:40 PM
Posts: 246 Cranberry Twp PA (North of Pit...
rumblefish72
OK - I've been following this thread since it first showed up. I've been working (directly) with MM for about 10 years now. Overall, I've been happy and continue to use them for my high-end stuff. Has it been a perfect relationship? No, there have been bumps in the road. But bottom line, MM has made good on everything I've done with them. I've worked with all the big dogs ... Indy, Barton, FHO, Hughes, MM, MCH, etc. I've been a Mopar only type guy since 1979. I don't have a required delivery date for any of my stuff and I only spend the cash that is in my play money account. I have a wife, three kids (two in college) and a mortgage so I have to save up and spend wisely.
I decided to build a big inch street Hemi several years ago. MM has been advising me and helping me acquire parts. The biggest wait was for the World Aluminum Block. I think it took 18 months between when I put my money down and when MM told me that they had received it. That was several years ago. It will probably take me another year to assemble it and get it on the MM Dyno. I'll post my results and video when the time comes. I'm a pretty reasonable guy and I'm expecting a positive outcome. If things go bad, I'll work with MM to get it ironed out. If I'm unhappy, I'll vote with my feet and start working with another builder. In any event, don't look for a bashing thread from me. MM has been in business for 25+ years ... you can't do that without lots or repeat customers. If most people were unhappy, they'd be out of business.
1972 Pro-Street 'Cuda, 500" Eagle stoker B Block, Eddy RPM heads, Victor Manifold, 850 Mighty Demon, Hemi 4 Speed, Dana 60 w/4.88 gears - Built by Hansen Racing Middlesex - NJ
[Re: steve660]
#1936979
10/22/15 10:06 PM
10/22/15 10:06 PM
polyspheric
New York
I was going to say something helpful, but after making that same mistake many times I think I'll just watch and laugh.
Boffin Emeritus
[Re: steve660]
#1936985
10/22/15 10:16 PM
10/22/15 10:16 PM
B3422W5
Portage,michigan
Muscle Motors indeed did have an excellent reputation at one time. It was primarily because Chuck Senatore ran the place. He left a long time ago.
[Re: B3422W5]
#1937048
10/22/15 11:37 PM
10/22/15 11:37 PM
Posts: 728 mi usa
old yeller
mi usa
Muscle Motors indeed did have an excellent reputation at one time. It was primarily because Chuck Senatore ran the place. He left a long time ago. Have you ever had work done on your motor when chuck owed the business?
[Re: old yeller]
#1937157
10/23/15 07:40 AM
10/23/15 07:40 AM
Posts: 2,412 Weatherford, Texas
RapidusMaximus
Weatherford, Texas
Started not to weigh in on this because I hate keyboard wars...oh well...I am a LONG time MM customer as well as Mancini and sometimes Hughes but for my "serious" stuff I have always gone to MM, Eric has always treated me right, heads, cams, short blocks, tech advice, etc. I've been using them since the late 80's I think, still have an old ported set of Stage 6's I got from them years and years ago that have thousands of passes of them, have a brand new 512 short block sitting on the stand right now waiting to be installed, it took approx. 6 months to get but I ordered it knowing when I needed it and gave them plently of time. Maybe my story is different from the op's but it is what it is, I hope the op gets his issues worked out with them, best of luck to you.
1968 Plymouth GTX 1974 Dodge P/U Long Bed Stepside 318 2019 Ram 2500 6.4, auto, 4WD
[Re: steve660]
#1937204
10/23/15 11:12 AM
10/23/15 11:12 AM
65 Hemi
San Diego CA
I have used muscle motors for a long time also and they are willing to take the time to discuss cam profiles on my B1. One thing to keep in mind is that this build being discussed is a very custom build with a lot of R&D. It's not a run of the mill B1 or Indy head motor. Not to discount the time it has taken but communication is important if things are delayed in the R&D phase.
Doug
[Re: 65 Hemi]
#1937401
10/23/15 05:44 PM
10/23/15 05:44 PM
madscientist
Washington
I have used muscle motors for a long time also and they are willing to take the time to discuss cam profiles on my B1. One thing to keep in mind is that this build being discussed is a very custom build with a lot of R&D. It's not a run of the mill B1 or Indy head motor. Not to discount the time it has taken but communication is important if things are delayed in the R&D phase. While true about the R&D time, the OP says they are way past that phase now. IIRC it had low oil pressure and the cam was not what the OP thought it should be. MM said they would get it handled in short order. I guess there is a difference of opinion on short order.
[Re: Monte_Smith]
#1937546
10/23/15 10:09 PM
10/23/15 10:09 PM
Thumperdart
State of confusion
Lots of people, me included, have used MM and never had the first complaint. Some haven't had good results.........This is a common trend in the industry and will continue. We see INDY bashing threads everyday.........they seem to be doing just fine and appear to be in no danger of having to lock the doors I hear ya and am sure I`ll get bashed eventually about my crappy carb work and you`re right, you can`t please everybody. What I said was this MAY put the final nail in the coffin for them w/members on HERE.........Maybe maybe not.......
[Re: justinp61]
#1937650
10/24/15 06:34 AM
10/24/15 06:34 AM
Posts: 921 Long Island, NY
shocktrp
Long Island, NY
Everyone in business has problems and at times unhappy customers. It's how you handle those problems that show your true character. On 6/25/15 MM posted in this thread (top of page 2) that they would take care of it with an estimated 2 week turnaround. Four months later this thread is still going. They're not doing themselves any favors with the members on this board (or anyone who will Google them prior to making a purchase in the future).
[Re: justinp61]
#1937653
10/24/15 07:17 AM
10/24/15 07:17 AM
Posts: 1,770 Pa
Wv68charger
Pa
Everyone in business has problems and at times unhappy customers. It's how you handle those problems that show your true character. Nothing more needs to be said after this.
