Stock Exhaust Manifold Question #1854903
06/23/15 01:05 AM
06/23/15 01:05 AM
Vesper,Wisconsin U.S.A
DusterJeff Offline OP
I,v been trying to locate stock exhaust manifolds for my 70 Duster....Motor is a mildly warmed up 318 and I don,t want the hassle of headers, mainly because of the heat soak troubles with the starter and on the left side,the tie rod passes through header pipes. I have a right side {Passenger} manifold that is casting #3418623...fits a 340 motor from 1971-1973.Left side I have 2 manifolds, 1st one is casting #3614395....fits a 318-1972-1973 Dart.2nd one is casting #2951123..fits a 318-1968-1969 Dart.The dilemma I have and this may sound like a dumb question is.....the right side 340 manifold is 1 and 7/8 inch inside diameter at the exhaust exit.The left side manifolds..both of them are 1 and 5/8 inch inside diameter at the exhaust exit.With a 1/4 inch difference exit diameters,would this adversely effect performance of the motor????? in addition to making exhaust pipes bolt up to the flanges on the manifold.the bolt centers on the 2 manifolds from side to side are 1/4 inch different also.. 3 and 3/4 for the right side versus 3 and 1/2 for the left side.Also, the left side manifolds "Swoop" up a bit before going back down....Information I have is I need either manifold casting # 2863553 for a 340 motor or manifold casting #2843953 for a 318 Dart...I,m thinking I need 2 matched pairs of manifolds with equal exhaust diameter exits...
Do Something..Lead..Follow..or get the {Beep} out of the way..
Re: Stock Exhaust Manifold Question [Re: DusterJeff] #1855043
06/23/15 10:26 AM
06/23/15 10:26 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I would be best to have a matching pair , look for a set of 73-74 340/360 A body manifolds and sell the right side 340 , it might almost pay for the later manifolds.
Also not all small block headers capture the steering linkage , it's mostly the cheap ones that do.
Re: Stock Exhaust Manifold Question [Re: DusterJeff] #1855120
06/23/15 12:55 PM
06/23/15 12:55 PM
P
Paul_Fancsali Offline
P
Consider the magnum manifolds I'm not sure they will fit but they are very efficient
Re: Stock Exhaust Manifold Question [Re: Paul_Fancsali] #1855299
06/23/15 04:44 PM
06/23/15 04:44 PM
you mentioned headers so I'm assuming you want more out the eng than just a low perf DD. I'd bite the bullet & get a set of 68-70 340 HP manifolds & they have a ~2&5/16" outlet(s) but they are pricey & might run you $400. The '92/early 93 mag manifolds also have a ~2&5/16" outlets and are a very good choice & will run you $100 + the ride. the later magnum manifolds have a 1&7/8" outlet the same as low po ones & are to be avoided. The very BEST iron mani setup is a 68-70 340 pass manifold and an early mag manifold on the Dr side (it'd be pricey cuz you using half of two different (pricey) sets). The absolute best would be a 68-70 340 HP passenger manifold on BOTH sides. On the DR side the outlet would be pointing forward a bit but its doable or a person MIGHT be able to cut the mani in two & reweld it to position the outlet rearward like the pass one is. As you know ex is the most restricted part of the air pump (the eng) & the 1&7/8 outlets ain't gonna cut it & you know sooner or later your gonna swap in a 360 stroked to 408, so to be proactive...
Re: Stock Exhaust Manifold Question [Re: JohnRR] #1855300
06/23/15 04:45 PM
06/23/15 04:45 PM
Yea,that was what I was thinking... I,ll try to find a "Mate" to either one or the other......or else find a "Matching Pair".... scope
Re: Stock Exhaust Manifold Question [Re: RapidRobert] #1855303
06/23/15 04:49 PM
06/23/15 04:49 PM
I "Hear" what your saying.....Eventually I would like to get my " Paws" on a 340 and drop it in the Duster.............The "Search" is on.... scope
Re: Stock Exhaust Manifold Question [Re: DusterJeff] #1855316
06/23/15 04:57 PM
06/23/15 04:57 PM
eBay (pricey) and local CL's are good sources
