magnum rt heads #1854793
06/22/15 11:01 PM
06/22/15 11:01 PM
ontario canada kingston
aspenrt360 Offline OP
hey guy's i have a chance to buy some super low time big valve magnum rt heads. i have no experience with them. how would they be for a decent 360 street engine that will see some track time but mostly street. the engine has flat tops at zero deck and a 530 lift cam in a heavy 74 charger.
thanks
2013 Chrysler 300 touring 1974 Dodge Charger SE. 360-727-8.75-3.23 sure grip 1972 Dodge Dart Swinger 1995 Dodge Ram 1500 4x4
Re: magnum rt heads [Re: aspenrt360] #1854831
06/22/15 11:42 PM
06/22/15 11:42 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
I have them on my 318, times thus far in my signature. Ported with 2.02 valves.
I have no doubt it wouldn't take a very radical combination at all to run in the 10's with them.
I suspect this 318 will run 11.50's soon with a hydraulic cam, street gears and over 3400 pounds.drive it everywhere, it's 10.5 compression.
Get them.
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: magnum rt heads [Re: aspenrt360] #1854858
06/23/15 12:10 AM
06/23/15 12:10 AM
nice thanks for the info
Re: magnum rt heads [Re: aspenrt360] #1855544
06/23/15 10:36 PM
06/23/15 10:36 PM
anyone else want to chime in?
Re: magnum rt heads [Re: aspenrt360] #1855981
06/24/15 03:52 PM
06/24/15 03:52 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Great heads, if you pass let me know.
Re: magnum rt heads [Re: HotRodDave] #1856005
06/24/15 04:15 PM
06/24/15 04:15 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
X2
