Re: Size a budget built turbo small block. [Re: roadrunner7020] #1859630
06/29/15 12:53 PM
06/29/15 12:53 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
My car has a PTC 9.5" converter in it. They make a REAL nice one that works for moderate power for about $475.
I run a 3.55 gear in a Dana, but my car went 10.60's before with only a 2.76 gear in it. You don't need a ton of gear.
Here is the vid...
https://www.youtube.com/watch?v=vqJoG_2wdMQ
Re: Size a budget built turbo small block. [Re: roadrunner7020] #1859671
06/29/15 02:16 PM
06/29/15 02:16 PM
Houston, Texas
TheOtherDodge Offline
Houston, Texas
Same answer on mine as Diz...
Re: Size a budget built turbo small block. [Re: roadrunner7020] #1861811
07/02/15 02:52 AM
07/02/15 02:52 AM
kentucky
roadrunner7020 Offline OP
kentucky
Dizuster and other dodge, how much compression is too much? With forged I beams and forged pistons 9.6-1 with good quench with an air to water intercooler on 93 or race fuel mix (as e 85 isn't available here) possible? Obviously locked timing around 12-15...
Re: Size a budget built turbo small block. [Re: roadrunner7020] #1862037
07/02/15 01:41 PM
07/02/15 01:41 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
9.6:1 isn't too much at all. You will be boost limited on pump gas, but on race gas you'll be totally find with a decent intercooler.
Timing will just depend on what fuel you have in it, and how much boost you run.
I ran as much as 26 degree's on 20psi with non-intercooled E85, with iron heads at 9.2:1.
You won't want to lock it at 12 for sure, it will drive awful off boost. Need to have something that pulls timing as boost increases.
Re: Size a budget built turbo small block. [Re: dizuster] #1862281
07/02/15 06:46 PM
07/02/15 06:46 PM
kentucky
kentucky
Thanks my holley pro strip ignition has a boost retard feature so that should do it if i dont go ms3
Re: Size a budget built turbo small block. [Re: roadrunner7020] #1865623
07/07/15 12:49 AM
07/07/15 12:49 AM
kentucky
kentucky
Anyone have a good recommendation for ring packs?
Re: Size a budget built turbo small block. [Re: roadrunner7020] #1865860
07/07/15 01:10 PM
07/07/15 01:10 PM
Houston, Texas
Houston, Texas
Put the top ring as low as you can...
Re: Size a budget built turbo small block. [Re: roadrunner7020] #1865910
07/07/15 02:34 PM
07/07/15 02:34 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I went with a stainless top ring on Total Seals advice.
