Re: Thnkng of going to 18" wheels/tires, what do I need to know?
[Re: ahy]
#1851554
06/18/15 01:31 AM
06/18/15 01:31 AM
RapidRobert
the basic would be if the OD will clearance/ proper fit your wheelwells 3 to 9 o'clock and 6 to 12 o'clock and if the sidewall to sidewall bulge dimention (I forget what the tire people call it) will clear lock to lock both ways. then if it looks good in your wheelwell.
[Re: RapidRobert]
#1851599
06/18/15 03:08 AM
06/18/15 03:08 AM
Posts: 290 Dayton, WA
wesgtx440
Dayton, WA
When I installed the new rims on my 68 Charger I had to change the wheel studs to 9/16 x 18 and they are also significantly longer than stock due to the wheels being so much thicker. I went with the circle racing billet magnum 500s. 17x8 front and 18x9.5 rear.
68 Charger R/T 440 auto
[Re: wesgtx440]
#1851795
06/18/15 02:33 PM
06/18/15 02:33 PM
dogdays
[Re: cudabitten]
#1851802
06/18/15 02:42 PM
06/18/15 02:42 PM
Posts: 1,307 BC, Canada
Black_Bee
BC, Canada
I run 17s on the front and 18s on the rear of my Super Bee, and my personal opinion is that our old Mopars need to be lowered a bit to look best with 17 or 18 inch wheels and tires. I dropped mine approximately 2". Also, make sure that you run a tall enough tire on the rear to fill up the wheel well. There are actually not that many 18 inch tires that are both wide AND tall enough to fill those huge wheel wells.
Paul '69 Super Bee 383 EFI Turbo
[Re: Black_Bee]
#1851878
06/18/15 03:55 PM
06/18/15 03:55 PM
Posts: 1,377 Back In Iowa
belv2vert66
Back In Iowa
I run 17s on the front and 18s on the rear of my Super Bee, and my personal opinion is that our old Mopars need to be lowered a bit to look best with 17 or 18 inch wheels and tires. I dropped mine approximately 2". Also, make sure that you run a tall enough tire on the rear to fill up the wheel well. There are actually not that many 18 inch tires that are both wide AND tall enough to fill those huge wheel wells. I agree. I have room for a 275 wide tire that is pretty tall on my Newport. All I have found so far is very spendy or a drag radial.....or for a light truck.
[Re: ahy]
#1851925
06/18/15 04:50 PM
06/18/15 04:50 PM
Posts: 958 eastern, pa.
cudabitten
eastern, pa.
I think 18" is a nice size. I run 17's... done again I would do 18's.
I was able to borrow a test wheel and tire for fit measurements then ordered wheels with custom backspace (American Racing). If you are trying to fit the biggest rubber, that helps. Most aftermarket wheel manufacturers will make custom backspace to order.
Once you get close on a tire size and type, look at what is available. I used Tire Rack to explore options. More common sizes have several options which helps with cost. Did you work with American Racing? How were they?
[Re: cudabitten]
#1852007
06/18/15 07:03 PM
06/18/15 07:03 PM
Posts: 28,067 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
17" tires of the proper height are going away. There are still some out there but the selection is getting slim. When I went to 18s on the hot rod I grabbed a 295/45-18 for the rear and a matching 245/45-18 on the front. They worked great but I kinda wanted a taller tire up front. You might want to play around with tire sizes to find something at 27" tall in the front and 28" or 29" out back for a typical hot rod.
[Re: RapidRobert]
#1852628
06/19/15 04:57 PM
06/19/15 04:57 PM
feets
Senior Management
Senior Management
Irving, TX
I think section width is not the issue. That tells you how wide the tire is. Aspect ratio is a larger concern. That ratio gives you the tall or short sidewall. section width / aspect ratio - wheel diameter 275/60-15 275 is the section width. Nice and fat. 60 is the aspect ratio. 60% of the 275 mm width. 15 is the wheel diameter.
[Re: feets]
#1853279
06/20/15 05:07 PM
06/20/15 05:07 PM
cudabitten
eastern, pa.
I think section width is not the issue. That tells you how wide the tire is. Aspect ratio is a larger concern. That ratio gives you the tall or short sidewall. section width / aspect ratio - wheel diameter 275/60-15 275 is the section width. Nice and fat. 60 is the aspect ratio. 60% of the 275 mm width. 15 is the wheel diameter. OHHHHH.... This is good info. What about backspacing? and bolt pattern? I'm guessing the pattern on the 74 cuda is 5 lugs x 4.5" centers. What is my backspacing min/max spec? I dont want to use spacers. Thanks again.
[Re: cudabitten]
#1853432
06/20/15 09:31 PM
06/20/15 09:31 PM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
I think section width is not the issue. That tells you how wide the tire is. Aspect ratio is a larger concern. That ratio gives you the tall or short sidewall. section width / aspect ratio - wheel diameter 275/60-15 275 is the section width. Nice and fat. 60 is the aspect ratio. 60% of the 275 mm width. 15 is the wheel diameter. OHHHHH.... This is good info. What about backspacing? and bolt pattern? I'm guessing the pattern on the 74 cuda is 5 lugs x 4.5" centers. What is my backspacing min/max spec? I dont want to use spacers. Thanks again. You can use this thread as a guide, do the math on subtracting the spacers I have to figure out the backspacing. Keep in mind manufacturing variation can be pretty large on these cars, you mileage [and tire clearance] may vary. http://www.cuda-challenger.com/cc/index.php?topic=74307.0
[Re: feets]
#1853661
06/21/15 09:17 AM
06/21/15 09:17 AM
Posts: 3,577 Long Island, NY USA
BergmanAutoCraft
Long Island, NY USA
On E bodies we stay around 26". Usually we go 275 35 18 front and 295 35 18 rear on 18x9 or 9.5 and 18x10 rear.
