Wiper refills #1853586
06/21/15 12:45 AM
06/21/15 12:45 AM
Kentucky
dfsmopars Offline OP
Kentucky
Isn't there a member on here who had an inventory of wiper refills for sale?
Re: Wiper refills [Re: dfsmopars] #1853646
06/21/15 05:59 AM
06/21/15 05:59 AM
PA
Sir Valiant Offline
Sir Valiant  Offline
PA
What size do you need? Amazon has wiper refills.
http://www.amazon.com/Trico-43-160-Steel-Blade-Refill/dp/B000CB3X88/ref=sr_1_3?s=automotive&ie=UTF8&qid=1434873489&vehicle=1972-43-2307-20-----15022------29-0&sr=1-3&ymm=1972%3Aplymouth%3Acuda
Re: Wiper refills [Re: Sir Valiant] #1853655
06/21/15 08:56 AM
06/21/15 08:56 AM
IN
ahy Offline
ahy  Offline
IN
My local AZ keeps ANCO brand behind the counter.
Re: Wiper refills [Re: Sir Valiant] #1853669
06/21/15 09:36 AM
06/21/15 09:36 AM
Kentucky
Kentucky
I have hit all of our local stores including AZ and all of them have gotten rid of their inventory. The 43-160 Trico set on Amazon, are they the wide type? These need to fit original '64 arms. I have ordered three different sets from three different sources and they all are narrow.
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring
‘14 Big Horn, Quad Cab, 4x4, 1500
Re: Wiper refills [Re: dfsmopars] #1853764
06/21/15 01:32 PM
06/21/15 01:32 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Napa shows them for my 71 demon, I'll let you know today i have a $15 off coupon
Re: Wiper refills [Re: dfsmopars] #1853818
06/21/15 03:17 PM
06/21/15 03:17 PM
Cruising!
Q
QuickDodge Offline
QuickDodge  Offline
Q
Cruising!
Wiper refills are becoming more difficult to find. The only place I've found that still stocks the refills in my area is the local dealer. These cost more, but also last longer than parts store's refills. I have NO idea if they have or could order refills for a 1960's car.
Re: Wiper refills [Re: dfsmopars] #1853826
06/21/15 03:30 PM
06/21/15 03:30 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
I got them, but they don't fit. May be due to my demon having the anco frame with the red little botton. I may need a anco refill???
Re: Wiper refills [Re: dfsmopars] #1853842
06/21/15 04:00 PM
06/21/15 04:00 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
This was a couple of years ago, but for my 65 I found that the rubber was the same as modern ones and by reusing everything else but the rubber the fit was perfect. I did take the rubber part and matched it up at the parts store.
Re: Wiper refills [Re: markz528] #1853847
06/21/15 04:07 PM
06/21/15 04:07 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
I looked it up - I bought them from Autozone and they were part number 91-18. These were for 18" Anco red dot wiper arms.
Re: Wiper refills [Re: markz528] #1853881
06/21/15 05:17 PM
06/21/15 05:17 PM
Kentucky
Kentucky
ademon. Sorry that didn't work out.
markz528 I'll see if you info helps. The arms on the New Yorker are Anco and have the red dot. They also have the air diverters.
Re: Wiper refills [Re: dfsmopars] #1853885
06/21/15 05:26 PM
06/21/15 05:26 PM
Kentucky
Kentucky
markz528 the 91-xx series are the whole blade looks like. They can be bought for sure. The blade is fine as long as the refill in it is 3/8" wide. Are the 91-18s you bought 3/8" wide?
Re: Wiper refills [Re: dfsmopars] #1853954
06/21/15 08:04 PM
06/21/15 08:04 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
Not sure - I would have to check. But I can tell you they fit my 18 inch Anco red dots very well. Just the rubber part - I discarded the rest that came with it.
Re: Wiper refills [Re: dfsmopars] #1854019
06/21/15 11:08 PM
06/21/15 11:08 PM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
I found a bunch at Rock Auto - check Trico in the part catalog search section. There is a method to their part numbers - numbers ending in 150 is 15", 160 is 16" and so on. I think the last sets I bought began with 43, like 43-150, 43-160, etc.
TRICO Part # 43-150 Long Frame Metal Refill; 15" (380mm) For Trico and Anco Long Frame Metal Blades
Category: 15" Blade Refill
