68 roadrunner Spare tire & jack mounting #185353
01/06/09 12:49 AM
01/06/09 12:49 AM
Avondale AZ
Prodart440 Offline OP
Avondale AZ
I do not have the sticker in the trunk that shows how to mount the tire and jack assembly. Could someone post a picture, and maybe a copy of the sticker, so that I can mount my spare correctly. Thanks!!!
Aaron
68 Roadrunner 383/AT
69 Dart GT Conv. 383/AT
05 Dodge Ram 4x4 Cummins
06 GoManGo R/T Daytona #757
68 Coronet 440
Re: 68 roadrunner Spare tire & jack mounting [Re: Prodart440] #185354
01/06/09 01:27 AM
01/06/09 01:27 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
It uses a "J"-hook and the spare either face down or face up ("face" being the red or white line side). With the tire face down the hook and jack base are inside of the rear of the rim and would seem to be better and lower over all. None the less either direction the j-hook hooks to the welded in mount (click and see this thread here) goes through wheel center, through the base that centers the wheel then through the jack hook and held in place by wingnut.
MikeR
Re: 68 roadrunner Spare tire & jack mounting [Re: A12] #185355
01/06/09 01:34 AM
01/06/09 01:34 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
The jack and lug wrench (jack pump handle) should go under the spare with the jack in the groove of the welded in mount and held down by the plate and smaller wingnut.
Re: 68 roadrunner Spare tire & jack mounting [Re: A12] #185356
01/06/09 01:36 AM
01/06/09 01:36 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
This is a '69 but very similar..
Re: 68 roadrunner Spare tire & jack mounting [Re: A12] #185357
01/06/09 01:40 AM
01/06/09 01:40 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
I have a better photo of the instructions but for now here's this one, sorry.
Re: 68 roadrunner Spare tire & jack mounting [Re: A12] #185358
01/06/09 11:22 AM
01/06/09 11:22 AM
Avondale AZ
Avondale AZ
Thank you!!! That is just what I needed!!!!!
Aaron
68 Coronet 440
