Page 22 of 26 1 2 20 21 22 23 24 25 26
Re: 71 cuda pro touring project [Re: johnscudashop] #860254
02/03/15 11:22 AM
02/03/15 11:22 AM
Mrytle Beach SC
johnscudashop Offline OP
Mrytle Beach SC
Brake lines and suspension assembly
Re: 71 cuda pro touring project [Re: johnscudashop] #860255
02/05/15 04:20 PM
02/05/15 04:20 PM
Maryland
rhamson Offline
rhamson  Offline
Maryland
How did you affix them to the roof? Epoxy?
Re: 71 cuda pro touring project [Re: johnscudashop] #860256
02/05/15 04:21 PM
02/05/15 04:21 PM
Maryland
rhamson Offline
rhamson  Offline
Maryland
I added some 3/8 diameter metal rods to the inside of the roof to stiffen it up a bit. If you have ever had a E-body , you know they are very weak in this area , You can push the roof in with your hand ,Hense without it the car sound like a bass drum going down the road.
Re: 71 cuda pro touring project [Re: rhamson] #860257
02/07/15 12:10 PM
02/07/15 12:10 PM
Mrytle Beach SC
Mrytle Beach SC
They are welded to the side roof supports , bent upward with a Daynamat and seam sealer sandwiched between the rods and the inner roof
Re: 71 cuda pro touring project [Re: johnscudashop] #860258
02/12/15 10:57 AM
02/12/15 10:57 AM
Mrytle Beach SC
Mrytle Beach SC
even though the lower doors were solid , I replaced the lower metal in the doors with new, since there is no access to the pinch weld area, I didn't want any rust to haunt me after its painted..
Re: 71 cuda pro touring project [Re: johnscudashop] #860259
02/17/15 02:48 PM
02/17/15 02:48 PM
Mrytle Beach SC
Mrytle Beach SC
Lowered the front valance 1 1/2 inches . I extended the lower front fender 1 1/2 in ,All the mounting tabs were modified as the space under the bumper.
Re: 71 cuda pro touring project [Re: johnscudashop] #860260
02/17/15 02:49 PM
02/17/15 02:49 PM
Mrytle Beach SC
Mrytle Beach SC
Lowered front fender mods
Re: 71 cuda pro touring project [Re: johnscudashop] #860261
02/17/15 02:55 PM
02/17/15 02:55 PM
Mrytle Beach SC
Mrytle Beach SC
As you can tell , I'm getting a little closer to paint. I have a couple more things to finish , but I am hoping for paint sometime this spring.
Re: 71 cuda pro touring project [Re: johnscudashop] #860262
02/19/15 11:11 AM
02/19/15 11:11 AM
Maryland
rhamson Offline
rhamson  Offline
Maryland
Thanks, I noticed that too with my car. Without that support I was worried if I could sand the top and get anything flat with the flexing of the metal. I think I will try this too.
Re: 71 cuda pro touring project [Re: rhamson] #860263
03/08/15 09:38 AM
03/08/15 09:38 AM
Mrytle Beach SC
Mrytle Beach SC
You will notice a difference on how your car sounds like in the interior. I was thinking on adding a reinforcement rod along the rear valance to keep the valance from vibrating with the exhaust too, the sheet metal is not supported well there either,
Re: 71 cuda pro touring project [Re: johnscudashop] #860264
04/05/15 05:10 PM
04/05/15 05:10 PM
Mrytle Beach SC
Mrytle Beach SC
Working on several things while the Cuda is in the body shop. Already a great suspension, Bill Reilly has a New Rack (made from Flaming River) to replace the ARG rack on the Alterkation , with a closer ratio, 2 1/2 turns lock to lock (235 bar) with over 6 inches of stroke and campatible with the new hemi P/S pump. The new rack top of the picture as the ARG rack is at the bottom
Re: 71 cuda pro touring project [Re: johnscudashop] #860265
04/05/15 05:13 PM
04/05/15 05:13 PM
Mrytle Beach SC
Mrytle Beach SC
Installed
Re: 71 cuda pro touring project [Re: johnscudashop] #860266
04/05/15 07:50 PM
04/05/15 07:50 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Sweet
Re: 71 cuda pro touring project [Re: jcc] #1842489
06/05/15 10:43 PM
06/05/15 10:43 PM
Mrytle Beach SC
Mrytle Beach SC
Well its been a long road. This time next week the car should be painted Indigo Black..[img:center]http://s1187.photobucket.com/user/custom...s9hi7y.jpg.html[/img] [img]http://https://plus.google.com/photos/115623640270256278682/albums/6157720988615529393/6157720997438815810?pid=6157720997438815810&oid=115623640270256278682[/img]
Re: 71 cuda pro touring project [Re: johnscudashop] #1853174
06/20/15 01:19 PM
06/20/15 01:19 PM
Mrytle Beach SC
Mrytle Beach SC
3 coats of Base and 6 coats of clear. Wet sand and buff next week. There light at the end of the tunnel. LOL
Re: 71 cuda pro touring project [Re: johnscudashop] #1853176
06/20/15 01:21 PM
06/20/15 01:21 PM
Mrytle Beach SC
Mrytle Beach SC
Some more
Re: 71 cuda pro touring project [Re: johnscudashop] #1853177
06/20/15 01:22 PM
06/20/15 01:22 PM
Mrytle Beach SC
Mrytle Beach SC
3
Re: 71 cuda pro touring project [Re: johnscudashop] #1853180
06/20/15 01:24 PM
06/20/15 01:24 PM
Mrytle Beach SC
Mrytle Beach SC
Re: 71 cuda pro touring project [Re: johnscudashop] #1853333
06/20/15 06:36 PM
06/20/15 06:36 PM
Maryland
K
Keepat Offline
Keepat  Offline
K
Maryland
Congrats, paint looks absolutely awesome!
Good luck with your biuld!
Pat
Re: 71 cuda pro touring project [Re: johnscudashop] #1863391
07/04/15 11:07 AM
07/04/15 11:07 AM
Mrytle Beach SC
Mrytle Beach SC
Tail light panel finished in hot rod black
