Page 1 of 3 1 2 3
Denso upgrade prob #1850655
06/16/15 08:33 PM
06/16/15 08:33 PM
MNobody Offline OP
MNobody  Offline OP
Must have done something stupid again, where should the sense wire be hooked up to? I fuse protected it and ran it to the starter relay,now i have power to the ignition and eveything else with the key off. Pull the fusr and everythings fine?
Re: Denso upgrade prob [Re: MNobody] #1850779
06/16/15 11:17 PM
06/16/15 11:17 PM
I ain't up on the Denso schematic but shouldn't the sense wire be switched 12V (not hot all the time?). I do have a Denso blem coming from 440 source for $25 & I'm gonna see if I can fix what ever ails it. Post what you find
Re: Denso upgrade prob [Re: RapidRobert] #1850796
06/16/15 11:35 PM
06/16/15 11:35 PM
IN
ahy Offline
ahy  Offline
IN
Here is a post in the archives. If you scroll through, you will find a wiring diagram in the post. Should help and apply to any "3 terminal" or "dual field" alternator. As RR said, the "sense" wire needs to be an ignition switched source (either directly or through an ignition switch triggered relay would work as well).
http://www.moparts.org/Tech/Archive/elec/24.html
Re: Denso upgrade prob [Re: MNobody] #1851122
06/17/15 03:29 PM
06/17/15 03:29 PM
Tucson, AZ
cruzin Offline
cruzin  Offline
Tucson, AZ
I ran both the "Sense and the Bat +" wires to the main lug on the starter relay. The alternator's "Ign" I ran to car's Ignition run wire at the bulkhead. Not using the "Lamp" wire coming off of the Denso alternator.
Re: Denso upgrade prob [Re: MNobody] #1851129
06/17/15 03:39 PM
06/17/15 03:39 PM
MNobody Offline OP
MNobody  Offline OP
Thanks guys, much appreciated. Looking around for a place to hook it under there, how about the switched wire to the MSD box? Should be able to sense something there eh?
Re: Denso upgrade prob [Re: cruzin] #1851131
06/17/15 03:46 PM
06/17/15 03:46 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Originally Posted By cruzin
I ran both the "Sense and the Bat +" wires to the main lug on the starter relay. The alternator's "Ign" I ran to car's Ignition start wire at the bulkhead. Not using the "Lamp" wire coming off of the Denso alternator.
This is interesting. I just put a Denso alternator on my tractor and it had only three connections, ignition (or sense), the output (battery), and the idiot light. With this alternator if you don't switch the ignition wire, the battery goes dead. DAMHIK.
Re: Denso upgrade prob [Re: 6PakBee] #1851178
06/17/15 04:35 PM
06/17/15 04:35 PM
Tucson, AZ
cruzin Offline
cruzin  Offline
Tucson, AZ
Here is the pigtail for a Denso that Hughes has.
http://www.hughesengines.com/Index/produ...mp;partid=27112
Re: Denso upgrade prob [Re: MNobody] #1851197
06/17/15 05:16 PM
06/17/15 05:16 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Not all Denso's are the same, the Mopar version of the Denso wires just like a roundback/flatback Mopar alternator.
Re: Denso upgrade prob [Re: MNobody] #1851294
06/17/15 08:22 PM
06/17/15 08:22 PM
IN
ahy Offline
ahy  Offline
IN
Sounds like a good spot...
Re: Denso upgrade prob [Re: MNobody] #1851374
06/17/15 10:18 PM
06/17/15 10:18 PM
MNobody Offline OP
MNobody  Offline OP
Yeah 6pack, with it hooked like that theres power to the ignition drawing the juice. I had my kill switch off when i did all this last winter so i had no clue there was an issue. Sounds like an easy fix though i'll try tomorrow on mine, the battery charger will appreciate it i'm sure. Thanks again everyone!
Re: Denso upgrade prob [Re: MNobody] #1851375
06/17/15 10:21 PM
06/17/15 10:21 PM
MNobody Offline OP
MNobody  Offline OP
OH, the denso i used is out of my scrapped 98 plymouth voyager
Re: Denso upgrade prob [Re: MNobody] #1851738
06/18/15 12:42 PM
06/18/15 12:42 PM
MNobody Offline OP
MNobody  Offline OP
Ok got the green wire with the tracer hooked to the msd switched wire, but still no charging. I hooked the solid green wire to the red wire in the harness that goes to the voltage regulator that i unplugged cause it was no longer needed oops it dead ended at the plug. Do i just jump the 2 terminals in the plug?
Re: Denso upgrade prob [Re: MNobody] #1852948
06/20/15 12:24 AM
06/20/15 12:24 AM
MNobody Offline OP
MNobody  Offline OP
Anyone
Re: Denso upgrade prob [Re: MNobody] #1853045
06/20/15 07:50 AM
06/20/15 07:50 AM
ohio
ruderunner Offline
ruderunner  Offline
ohio
The alternator is not internally regulated. You need to connect the regulator wiring like stock, just change the terminals to fit the alternator. IIRC two small ring connectors and one large charge wire.
Angry white pureblood male
Re: Denso upgrade prob [Re: John_Kunkel] #1853070
06/20/15 09:52 AM
06/20/15 09:52 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
The Denso I used had the internal regulator. If this is the stock '98 Mopar Denso John had the answer all along.
Re: Denso upgrade prob [Re: MNobody] #1853135
06/20/15 12:32 PM
06/20/15 12:32 PM
MNobody Offline OP
MNobody  Offline OP
No kiddin i"ll plug it back in and try it
Re: Denso upgrade prob [Re: MNobody] #1853137
06/20/15 12:34 PM
06/20/15 12:34 PM
MNobody Offline OP
MNobody  Offline OP
I thought all denso's were internally regulated, shame on me
Re: Denso upgrade prob [Re: MNobody] #1853387
06/20/15 08:23 PM
06/20/15 08:23 PM
MNobody Offline OP
MNobody  Offline OP
Yeah still not working, got a fuzz over 12 volts showing on the voltmeter. Bout ready to put the old one back in.
Re: Denso upgrade prob [Re: MNobody] #1853410
06/20/15 08:54 PM
06/20/15 08:54 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
How do you have it wired?
Re: Denso upgrade prob [Re: MNobody] #1853558
06/20/15 11:24 PM
06/20/15 11:24 PM
MNobody Offline OP
MNobody  Offline OP
The green wire in the harness is hooked to the B. other wire is hooked to the switched wire for my 6al box, heavy black to the big lug. I have done the amp gauge bypass, installed a voltmeter and have a heavy jumper from the alternator straight to the starter relay with a 100 fuse wired in.
Page 1 of 3 1 2 3
