Page 1 of 3 1 2 3
Test and tune..... Broke it.....Tranny #1852856
06/19/15 10:42 PM
06/19/15 10:42 PM
Portage,michigan
B3422W5 Offline OP
B3422W5  Offline OP
Portage,michigan
Get car sorted out, do burnout... Stage it.... Launch it( just off idle at 1500 and revs up like in neutral. And breaks.
904
No forward gears or reverse. No noises rolling it around. Not sure what I broke
First time out this year, made some nice changes, not meant to be... Lol
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Test and tune..... Broke it..... [Re: B3422W5] #1852860
06/19/15 10:48 PM
06/19/15 10:48 PM
baldwinsville new york
a493demon Offline
a493demon  Offline
Input shaft ?
Re: Test and tune..... Broke it..... [Re: B3422W5] #1852862
06/19/15 10:51 PM
06/19/15 10:51 PM
Portage,michigan
B3422W5 Offline OP
B3422W5  Offline OP
Portage,michigan
That or maybe pump ears?
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Test and tune..... Broke it..... [Re: B3422W5] #1852873
06/19/15 11:10 PM
06/19/15 11:10 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Was this a worked 904, or just clutches and shift kit?
Re: Test and tune..... Broke it..... [Re: B3422W5] #1852874
06/19/15 11:10 PM
06/19/15 11:10 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Re: Test and tune..... Broke it..... [Re: B3422W5] #1852897
06/19/15 11:32 PM
06/19/15 11:32 PM
Portage,michigan
B3422W5 Offline OP
B3422W5  Offline OP
Portage,michigan
Local guy built it who does most of the 904/727 stuff for US131 racers.
Billet servo's A&A footbbrake valve body. As far as I know otherwise stock internals.
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Test and tune..... Broke it..... [Re: B3422W5] #1852926
06/19/15 11:58 PM
06/19/15 11:58 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Major bummer. Get her fixed and go get em.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Test and tune..... Broke it..... [Re: B3422W5] #1852942
06/20/15 12:18 AM
06/20/15 12:18 AM
Maryland
340_Dart Offline
340_Dart  Offline
Maryland
My bet is the pump ears. Should be an easy fix with the trans out
Re: Test and tune..... Broke it..... [Re: 340_Dart] #1852963
06/20/15 12:45 AM
06/20/15 12:45 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Add me to the list, pump ears if it's stock.
Re: Test and tune..... Broke it..... [Re: B3422W5] #1852972
06/20/15 12:55 AM
06/20/15 12:55 AM
Portage,michigan
B3422W5 Offline OP
B3422W5  Offline OP
Portage,michigan
No park either. Car rolls easily and acts likes its in neutral in all gears
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Test and tune..... Broke it..... [Re: B3422W5] #1852977
06/20/15 01:03 AM
06/20/15 01:03 AM
PA.
"Little"John
"Little"John
PA.
Not pump ears then. Dig deeper
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Test and tune..... Broke it..... [Re: B3422W5] #1852979
06/20/15 01:06 AM
06/20/15 01:06 AM
Portage,michigan
B3422W5 Offline OP
B3422W5  Offline OP
Portage,michigan
Pushed it up on the trailer and put it in park... As it was flat didn't notice it didn't hold until started putting a little tension on straps..... Oops.
Back at my store in its bay safely, now have to figure out what's broke.
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Test and tune..... Broke it..... [Re: B3422W5] #1852987
06/20/15 01:21 AM
06/20/15 01:21 AM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
Maybe the shift lever broke.
Re: Test and tune..... Broke it..... [Re: B3422W5] #1853013
06/20/15 02:13 AM
06/20/15 02:13 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Sounds like the output shaft is FUBAR.
This is assuming the engine is turning but the driveshaft isn't.
Kevin
Re: Test and tune..... Broke it..... [Re: Twostick] #1853029
06/20/15 03:12 AM
06/20/15 03:12 AM
CA
crackedback Offline
crackedback  Offline
CA
Kevin
Agreed, sounds as though it broke aft of the parking pawl point
Re: Test and tune..... Broke it..... [Re: B3422W5] #1853060
06/20/15 09:26 AM
06/20/15 09:26 AM
Manheim PA.
mopardad Offline
mopardad  Offline
Manheim PA.
axle
Re: Test and tune..... Broke it..... [Re: B3422W5] #1853063
06/20/15 09:32 AM
06/20/15 09:32 AM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
Pinon on rear
Re: Test and tune..... Broke it..... [Re: B3422W5] #1853120
06/20/15 11:55 AM
06/20/15 11:55 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I think if it was the rear he might of felt it pushing the car ?
I'm done guessing popcorn
Re: Test and tune..... Broke it..... [Re: B3422W5] #1853379
06/20/15 08:13 PM
06/20/15 08:13 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Hopefully it's something fairly simple Don, breakage is no fun.
Re: Test and tune..... Broke it..... [Re: B3422W5] #1856053
06/24/15 05:47 PM
06/24/15 05:47 PM
Portage,michigan
B3422W5 Offline OP
B3422W5  Offline OP
Portage,michigan
Appears it broke the rear end, tore cap off. Will know for sure tomorrow 8.75, 489 case, solid spacer.
Funny I didn't hear any noticeable noise pushing it.
I pray Quicktree doesn't see this post........ Lol
1.41 best 60 foot
6.60 at 103.90 1/8
Page 1 of 3 1 2 3
