2010 Challenger rear spoiler install #1852966
06/20/15 12:48 AM
06/20/15 12:48 AM
St. Louis, Mo
3
318 Stroker Online content OP
318 Stroker  Online Content OP
St. Louis, Mo
I bought a used factory T/A style spoiler for my 2010 SE. Anyone know where I can get installation instructions or a template?
Re: 2010 Challenger rear spoiler install [Re: 318 Stroker] #1853051
06/20/15 08:49 AM
06/20/15 08:49 AM
dart1962_440 Offline
The guys on ChallengerTalk.com may be able to help.
Re: 2010 Challenger rear spoiler install [Re: dart1962_440] #1853602
06/21/15 01:25 AM
06/21/15 01:25 AM
St. Louis, Mo
3
St. Louis, Mo
Thanks for the tip, but I recently joined there, and they have been of no help either. It's frustrating, as I sure don't want to drill holes in the wrong place. I'll only have one shot at getting it right.
Re: 2010 Challenger rear spoiler install [Re: 318 Stroker] #1853667
06/21/15 09:28 AM
06/21/15 09:28 AM
I found this, maybe it helps. Appears there's a template. Maybe someone can duplicate it for you.
http://www.challengertalk.com/forums/f19/go-wing-install-pics-diy-really-long-part-1-a-16555/
Re: 2010 Challenger rear spoiler install [Re: 318 Stroker] #1853780
06/21/15 02:04 PM
06/21/15 02:04 PM
St. Louis, Mo
3
St. Louis, Mo
Thanks, but it's the T/A style lip spoiler that I have. That link shows the go-wing.
Re: 2010 Challenger rear spoiler install [Re: 318 Stroker] #1853787
06/21/15 02:18 PM
06/21/15 02:18 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
If it's a factory spoiler there will be holes in the under side of the trunk lid that are made to allow you to drill holes for the spoiler. Just take a quick measurement of the spoiler mounting area and see if there are corresponding holes in the deck lid. If not then Take some paper and tape it together so it's wide enough to stick out from under the spoiler. Put it down where you are going to place the spoiler and mark the edges of the trunk lid on the pattern to locate the pattern. Then put the spoiler where you want it and trace the out line on the paper. Remove the paper and using the tracing of the spoiler mark the spots for drilling then reinstall the pattern on the trunk and drill where you marked. A little work but it will get the job done right.
