Acid dipping to lighten steel bumpers.. #1852799
06/19/15 09:09 PM
06/19/15 09:09 PM
SHELBY TWP,,MICHIGAN
72N96RR Offline OP
I LOVE WEDGIES
72N96RR  Offline OP
I LOVE WEDGIES
I had the information for a place that can acid dip bumpers/ brackets ect in Michigan.. I cannot find them or maybe they went out of business..Anyone know a place in Michigan that does this kind of work??...thanks in advance..
1972 Road Runner / GTX 440 4spd Dana 3.54 Just about to turn 26K original miles..
A boat, a GMC truck, some Craftsman Tools, LOTS of Zombie Protection, and a few Goldfish..
If you love someone set them free..
If they come back it means nobody else wanted them either..!!
Re: Acid dipping to lighten steel bumpers.. [Re: 72N96RR] #1852997
06/20/15 01:38 AM
06/20/15 01:38 AM
fullmetaljacket Offline
I'll get his info tomorrow for you, He did excellent work on a few large and small pieces including delicate interior trims and braces.
Re: Acid dipping to lighten steel bumpers.. [Re: 72N96RR] #1853022
06/20/15 02:48 AM
06/20/15 02:48 AM
Mo.
racerx Offline
racerx  Offline
Mo.
How much weight can you expect to lose on a typical bumper that has been dip? wave
Re: Acid dipping to lighten steel bumpers.. [Re: racerx] #1853138
06/20/15 12:34 PM
06/20/15 12:34 PM
Realistically, I believe that any more than half the weight off the items in question become almost unusable.
I had to instruct the dipper on how much percentage could/should be taken off even though he had a good idea of how much could be safely taken off. I gave him interior trim off my car, radiator support for my friends Stingray and various brackets. Some were half off their weight and others were only a quarter off to make up for strength.
It's a detail and time consuming process to do it properly with out it coming out of the vat looking like a skeleton.
Be careful what you ask for, but it is indeed super trick and lots more guys in classes are using the method more than you think.
In the case of the Bumper, I went with a custom built thin 321 stainless that came out at 7 lbs or so from its 21 lbs or so IIRC
lots of work but light in the long term of things.
Re: Acid dipping to lighten steel bumpers.. [Re: 72N96RR] #1853189
06/20/15 01:35 PM
06/20/15 01:35 PM
Mo.
racerx Offline
racerx  Offline
Mo.
Thaxs.............. Oz's equal pounds. If I knew of a dipper here locally I probably will try it.
Re: Acid dipping to lighten steel bumpers.. [Re: racerx] #1853198
06/20/15 01:55 PM
06/20/15 01:55 PM
The big dipper is in Detroit.
If needed, E-mail me and I'll get you in touch.
absolutleestudio@yahoo.com
