It should have a electronic iugnition in it, but you never know what the motor home makers used on parts on there builds
Look at the distributor with the cap and rotor off and see if it has points
If so take them with you to a good, not a cheap, parts store so you get the proper set of points on the first visit
The 413 motorhome motors are a completely different animal than the regular passenger car motors where, the industrial and motor home motors where designed and built to be used in severe duty appications with all long lasting H.D. parts
Not so after Mopar stopped making the 413 M.H. motors, the non 440-3 motorhome motors where probally the same as the standard non HP passenger car, van and pickup motor where
The 440-3 had better heads and valves along with extra cooling for substained heavy hauling like in a class A motorhome or larger truck sees
IHTHs
