I have a 93 Dakota with a 5.2 currently. I would like to install a Tach and a Two Step. I bracket race and I do not trust the factory Tach. I would like the two step so I can have a consistent RPM when waiting for the tree. Does anybody have any ideas which one would be the easiest to hook up or the best one to use. I still have factory wiring harness and have not put in an aftermarket ignition box yet.
Thank you,
Chris
