Re: '70 Challenger T/A Hood Install
[Re: challenger70]
#1851832
06/18/15 03:06 PM
06/18/15 03:06 PM
Posts: 29,652 Hamtramck, PA
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
1 - Yes, you need a kit with the rivets for a 'glass hood. 2 - Yes, lighter springs, hinges are the same. 3 - Same rear seal. 3.5 - Front seal to radiator support has the ends trimmed off. 4 - Same molding, but you use longer studs. R/T Specialties has them. 5 - No emblem. 6. Same as any other 1970 hood. 7 - www.fpap.com has them for sale. 8 - See 3.5 above. 9 - Pins only, no center latch or pop up spring.
[Re: challenger70]
#1852016
06/18/15 07:16 PM
06/18/15 07:16 PM
Posts: 4,051 Connecticut
jeff968
Connecticut
And even though it is new, it will bow. I have a AAR T/A hood on my T/A with teh correct hinge springs and it has bowed. I got it 7 years ago. If you don't want it to bow, don't use the springs.
1970 Dodge Challenger T/A
[Re: jeff968]
#1852035
06/18/15 07:36 PM
06/18/15 07:36 PM
Posts: 4,852 KENTUCKY
69CHARGERMD
KENTUCKY
I used the light weight springs from Year One They worked out great,,,, I know some people fab up a "prop rod" that also seems to work well... I just installed a AAR T/A hood on my 70 Challenger..
[Re: 69CHARGERMD]
#1854387
06/22/15 03:55 PM
06/22/15 03:55 PM
Posts: 3,358 Berwyn, IL
challenger70
Berwyn, IL
I used the light weight springs from Year One They worked out great,,,, I know some people fab up a "prop rod" that also seems to work well... I just installed a AAR T/A hood on my 70 Challenger.. Nice, I am excited about mine, I have had a crappy 6pack knockoff hood on my Challenger since I got it. Do you recall how long the hood pin cables are? Where did you get your hardware? Looks like I can find 2-3 things at 3 different places, just wondering if anyplace has everything?
[Re: Alaskan_TA]
#1854473
06/22/15 05:27 PM
06/22/15 05:27 PM
challenger70
Berwyn, IL
3420 000 was for the molding package, which did include the fasteners. Fastener number is 6002 320
Steel hood molding package was 3549 699 & the fastener part number is 6002 170.
The only difference is the length of the fasteners & the nuts, the molding itself is the same. Thanks again, I had bought a molding many years ago and I was hoping it was ok to use. I should have known better than to question you.
[Re: joes68340s]
#1854603
06/22/15 07:30 PM
06/22/15 07:30 PM
challenger70
Berwyn, IL
Since its not a show car or matching numbers just a nice driver it dosent matter how well it looks underneath. Glad you and others like there hoods. Underside looks good too, here is a pic of it laying in place on my car as delivered.
[Re: joes68340s]
#1854761
06/22/15 10:16 PM
06/22/15 10:16 PM
Posts: 18,157 Mass
DAYCLONA
Mass
How do you all like the AAR, T/A hoods how do they compare to original. I have an AAR Cuda and I need a new hood and I was considering a Year One wasn't sure about the AAR hoods. Go with the Year One hoods, they are made by ASC&P International in Eagle, Pa. you won't find a better repro currently on the market
