Re: 440 Rear Main Seal Leak--Almost Suicidal!! (Long)
[Re: quickd100]
#1851651
06/18/15 08:59 AM
06/18/15 08:59 AM
Posts: 1,051 The Great White North
RAMM
I've seen the rear main studs interfere with the seal retainer. (Actually hit the seal retainer holding it off it's mating surface.)Dave Dave, I am fully aware of the studs and the havoc they can wreak on a Mopar. ex ( enlarging thrust cap bolt holes to 17/32" for thrust cap alignment) So yes, I have scalloped the retainer out around studs and nuts. The Mancini cap was also relieved as it extra material in that vicinity, and would definitely hang up there. Furthermore, when I take this apart I always witness the mating surface and how the thin layer of sealant is completely squeezed out and leaves the shape of the retainer. Pics on the way. Thanks though, J.Rob
2009 PHR\EMC Competitor 2010 PHR\EMC Competitor 2011 PHR\EMC Competitor 2012 PHR\EMC Competitor 2013 PHR\EMC Competitor 2014 HotRod/EMC Competitor 2015 HotRod/EMC NoShow 2016 HotRod/EMC 3rd place SPEC Bigblock 2018 HotRod/EMC 7th place G3
[Re: Monte_Smith]
#1851652
06/18/15 09:03 AM
06/18/15 09:03 AM
RAMM
Do you offset the seal so it doesn't line up with the split between the block and retainer ? I would try this. DON'T glue the seal in the block, nor in the cap. Only glue bottom and sides of seal retainer. Seal joints 90* from retainer surface. Never had one leak done this way. And of course I HATE to ask an obvious question.....but you are turning the lip on the seal the right way? Monte, So you turn the seal 90* so the seam/parting line will be at the 12 0'clock and 6 o'clock position? I am willing to try anything at this point but fail to see how this helps. The seal lips are facing inward-believe me when I first took it apart I was hoping I had it backwards for an easy explanation. Thanks though, J.Rob
[Re: Big D A12]
#1851657
06/18/15 09:30 AM
06/18/15 09:30 AM
RAMM
RAMM....Welcome to my hell. I feel your pain. What is the cast date of the block you are having issues with? My saga is documented in the following thread. http://a12mopar.com/yabb/YaBB.pl?num=1424822394/15I finally gave up and am just going to deal with it as a maintenance item on the car. D Wow just read through all of it. Is your crank an Eagle?(Nevermind I see it is OEM) My block is a '68 that was cast on Hallowe'en! WTF? J.Rob
[Re: rickraw]
#1851663
06/18/15 09:55 AM
06/18/15 09:55 AM
RAMM
I'm sure u did this, but I'll ask anyway. Is the seal retainer flush with the back of the block? Maybe there is a misalignment issue. Last one I did, I put the seal & retainer in with no crank & checked to see how the parting lines lined up. Did this. No crank in block, seals in, everything was nice and round. Parting lines almost not detectable by finger. Did this twice actually. Thanks, J.Rob
[Re: RAMM]
#1851687
06/18/15 11:07 AM
06/18/15 11:07 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I'm sure u did this, but I'll ask anyway. Is the seal retainer flush with the back of the block? Maybe there is a misalignment issue. Last one I did, I put the seal & retainer in with no crank & checked to see how the parting lines lined up. Did this. No crank in block, seals in, everything was nice and round. Parting lines almost not detectable by finger. Did this twice actually. Thanks, J.Rob When you put it in the block with no crank.. did you have the side seals in it.. I have seen where the retainer was cut shallow on one side.. it forces the retainer over... this was a after market retainer
[Re: MR_P_BODY]
#1851688
06/18/15 11:11 AM
06/18/15 11:11 AM
RAMM
I'm sure u did this, but I'll ask anyway. Is the seal retainer flush with the back of the block? Maybe there is a misalignment issue. Last one I did, I put the seal & retainer in with no crank & checked to see how the parting lines lined up. Did this. No crank in block, seals in, everything was nice and round. Parting lines almost not detectable by finger. Did this twice actually. Thanks, J.Rob When you put it in the block with no crank.. did you have the side seals in it.. I have seen where the retainer was cut shallow on one side.. it forces the retainer over... this was a after market retainer No side seals were in, but I also fill the side channels with RightStuff when I install--so no side loading is present in this case. J.Rob
[Re: RAMM]
#1851750
06/18/15 01:15 PM
06/18/15 01:15 PM
Posts: 10,035 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I used phosphorescent dye (works with a black light) to check a set of heads. They lit up like a Christmas tree at every crack. If there is a dye like this that can be safely used with motor oil, you could trace the leak easily.
[Re: RAMM]
#1851770
06/18/15 01:39 PM
06/18/15 01:39 PM
Posts: 417 reynoldsburg,ohio
poppaj
reynoldsburg,ohio
There is a small oil pressure relief hole drilled in the block in the rear. It relives full pressure from the rear seal. Went thru the same problems a couple of years ago on a low deck motor, fought it all year found relief hole and cleaned it out Problem solved
AA/NSS 65'Coronet "Whompin Wedge" Pop & Son Performance 557" B-1 power John Holt Chassis
[Re: poppaj]
#1851784
06/18/15 02:08 PM
06/18/15 02:08 PM
Posts: 447 NJ
JCCuda
NJ
There is a small oil pressure relief hole drilled in the block in the rear. It relives full pressure from the rear seal. Went thru the same problems a couple of years ago on a low deck motor, fought it all year found relief hole and cleaned it out Problem solved I am not aware of this hole. Does anyone have a picture that shows the location of this hole?
[Re: poppaj]
#1851788
06/18/15 02:20 PM
06/18/15 02:20 PM
RAMM
There is a small oil pressure relief hole drilled in the block in the rear. It relives full pressure from the rear seal. Went thru the same problems a couple of years ago on a low deck motor, fought it all year found relief hole and cleaned it out Problem solved I just checked a '70 440 block I had bare here. There is no hole that I can find? J.Rob
[Re: Monte_Smith]
#1851839
06/18/15 03:12 PM
06/18/15 03:12 PM
dartman366
Mt. Vernon, Ohio
plug at the cam tunnel just above the rear main seal seeping?, damhik especially the welch plugs.
[Re: 9secondsatellite]
#1851887
06/18/15 04:02 PM
06/18/15 04:02 PM
RAMM
I know this might be a stretch but what are the odds of the seal journal on the crank not being in line with the rest of the crank? or the other way. the crank seal retaining area not in line with the line bore? i wouls at least try to check that part on the crank, seeing that that might be the 1 thing that has changed in the previous setup. I would think this would show up when I lay crank in mains and set dial indicator on seal journal and it displays .0009" out of round. I called Eagle today and they say they keep it at .0005" or 5 tenths. They were of no help of course. Also when I have had the crank out and installed the retainers-the seal halves line up nicely and I mean round and inline with each other. J.Rob
[Re: RAMM]
#1851933
06/18/15 05:04 PM
06/18/15 05:04 PM
Posts: 527 alaska,usa
9secondsatellite
alaska,usa
I know this might be a stretch but what are the odds of the seal journal on the crank not being in line with the rest of the crank? or the other way. the crank seal retaining area not in line with the line bore? i wouls at least try to check that part on the crank, seeing that that might be the 1 thing that has changed in the previous setup. I would think this would show up when I lay crank in mains and set dial indicator on seal journal and it displays .0009" out of round. I called Eagle today and they say they keep it at .0005" or 5 tenths. They were of no help of course. Also when I have had the crank out and installed the retainers-the seal halves line up nicely and I mean round and inline with each other. J.Rob yeah that should have been good at that point. another thought would be to look at the oil feed hole on the crank for that main. is it pointed to that direction? maybe drilled incorrectly so that it would direct oil flow towards seal? seems at this point like oil is aiming directly at the seal instigating the problem.
[Re: sasquatch]
#1851944
06/18/15 05:29 PM
06/18/15 05:29 PM
9secondsatellite
alaska,usa
Plug the valve covers up and put some air in it and try soap bubbling the seal area. I know of several top shelf mopar engine builders who are ready to rip their hair out right now over these dang seals. Todd i like that idea. i'll try to remember that one in the future.
