rear shock bolts #1850828
06/17/15 12:06 AM
06/17/15 12:06 AM
Shelby, Ohio
2
2abodymcodes Offline OP
Shelby, Ohio
69 cuda. where can I get the upper bolts for the rear shocks ? it takes a special bolt that goes thru the upper crossmember.I checked Napa and the other local part stores. nobody has a listing for them.
Re: rear shock bolts [Re: 2abodymcodes] #1850846
06/17/15 12:42 AM
06/17/15 12:42 AM
not likely avail new or even a repop (no demand). I'd put an ad in the A body parts wanted section here. A little bit of money to the right person would get you a pair to your mailbox
Re: rear shock bolts [Re: RapidRobert] #1850992
06/17/15 11:46 AM
06/17/15 11:46 AM
64MAX Offline
64MAX  Offline
Take a look at Bill Rolik Enterprises. He shows upper shock bolts on his site. Good luck.
Re: rear shock bolts [Re: 2abodymcodes] #1851039
06/17/15 01:14 PM
06/17/15 01:14 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
I think I have 2 put away to go to Carlisle. If your going to make the trip stop over and we'll try to match them up. Good luck... I forgot the spot spaces off the top of my head but its up by gate 7 in Row P...4 spots from the corner of the fence.
...FAFO...
Re: rear shock bolts [Re: 64MAX] #1851049
06/17/15 01:38 PM
06/17/15 01:38 PM
None
71rm23 Offline
71rm23  Offline
None
Contact Bill, R-T Specialties, or Frank Baldeson (partner with Roger Gibson). I got a set from Frank for my car. Someone sure should be able to help.
