Cuda deck lid torsion spring #1850585
06/16/15 05:27 PM
06/16/15 05:27 PM
Finally a HUSKER again
Moparnut426 Offline OP
Is there only one torsion spring on a 73 Cuda?
DO I need to add a second if I put a wing on it?
Re: Cuda deck lid torsion spring [Re: Moparnut426] #1851068
06/17/15 02:16 PM
06/17/15 02:16 PM
No body has any info on this one??
Re: Cuda deck lid torsion spring [Re: Moparnut426] #1851102
06/17/15 03:06 PM
06/17/15 03:06 PM
California
1970mopar Offline
1970mopar  Offline
California
To the best of my knowledge,
1970, 72-74 all should have 2 torsion springs
71 was a single torsion spring
Re: Cuda deck lid torsion spring [Re: Moparnut426] #1851137
06/17/15 03:52 PM
06/17/15 03:52 PM
What was the reasoning behind this? My 73 Has 1 only, its fine with no spoiler on it, but I am scared to put a spoiler on it, don't know if it will stay up.
Re: Cuda deck lid torsion spring [Re: Moparnut426] #1851168
06/17/15 04:28 PM
06/17/15 04:28 PM
S. Il. U.S.A.
5spdcuda Offline
5spdcuda  Offline
S. Il. U.S.A.
I have a '72 that I know has the original spring set up. It only has one spring. It does have four holes for the spring end, so you can have different levels of preload. I also have a generic Go Wing that is fairly heavy. My spring is set in the second hole from the rear and it holds the deck lid up OK. Once you start to lower the deck lid it does come down rather quickly and with some force. In any case one spring with the right preload will work.
Re: Cuda deck lid torsion spring [Re: Moparnut426] #1851189
06/17/15 04:50 PM
06/17/15 04:50 PM
Thanks That's what I needed!!
