Ok so here is how I read it
when using a solid cam or solid roller and Harland Sharp rockers we want to restrict or control the amount of oil going to the heads.
One way of doing this is to groove No4 cam journal for full time oiling then drill and tap the oil passage in the head and screw in a .070 holley main jet into it?
correct?
That is one way, I have bought and am using some of the World blocks, they oil the rocker full time by the rocker arm oiling passage fed directly from the right side lifter oil galley,not through the cam
They have a .040 restrictor in them stock
I have used .039 restrictors successfully on several stock blocks with full time oiling to the rockers like your suggesting on Harlnad Sharp rockers, same size(.039) on several other motors with Indy heads with external full time oiling with H.S. rockers also
On a extruded aluminum or any non needle bearing rockers I may end up using a bigger restrictor(.080) to start with and then decde to change it up or down on the size dependent on the results
IHTHs
